08-03-2023, 09:57 AM | #1 |
Drop springs for a '68
Looking for a set of drop springs for a 68 fleetside Right now I have two in the front and three in the back. Looking to take it lower. Any suggestions on how to do that or a company that sells a kit?
08-03-2023, 02:31 PM | #2 |
Re: Drop springs for a '68
I used a Western Chassis 3/5 spring lowering kit.
I would, if I had it to do over, I would have went with a 2.5 drop spindle in the front and 5 in the back. The springs put you on the bumpstops nearly.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
08-03-2023, 04:19 PM | #3 |
hello, will 3'' or 4'' springs work with original hardware ?
08-03-2023, 05:37 PM | #4 | |
I went with 2.5" spindles in the front with stock replacement springs and 4" springs in the rear. In reality, I'd like the front of my truck about 1" lower and may attempt that at some point in the future.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
08-03-2023, 06:28 PM | #5 |
I was thinking about dropping it another 2 in in the front. Just wondering if I have to replace the A arm?
08-03-2023, 07:06 PM | #6 |
If you want another 2" lower in the front, and you already have 2" drop springs, your best course of action will be spending the money for drop spindles. Your front suspension geometry will thank you. Now, if you already have 2" drop spindles, going with a 2"drop spring will be a good combo without having to replace the A arms
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-03-2023, 09:37 PM | #7 |
I had 2.5 drop spindles and 2 inch springs up front, with 6 inch rear springs and shock relocators. It was a little too low for me and all the places i went. But it was a good driver. You do have to watch hard bumps or dips as reR would bottom out. If it had c-notches it would have been ok. It did bring way to much gravel and rocks home from dragging on a lot of places i went.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 08-05-2023 at 01:47 PM. |
08-05-2023, 12:36 PM | #8 |
As others have commented, at this point Dropped Spindles would be the way to go. Much more than a 2" dropped spring in the front and you will start to have alignment issues and the overall geometry will change somewhat.
What these companies don't tell you is, a new 2" dropped spring is measured against a NEW stock spring. These trucks are 50yrs + old and most of them were used on farms, hauling stuff, and of course just time causes the stock springs to sag a little. So a 50yr old stock height truck won't be much lower than a 50yr old truck with 2" dropped springs. You might see .50-.75" difference. If you go with dropped spindles, a 2" drop is going to net a full 2" lower. Regardless of the spring. Spindles won't change your steering or spension geometry .. it's just a better option to go ahead and spend the money and get some spindles. Replace the ball joints while you have them out.. etc. It's like a disease man, once you tear into it there's a bunch of stuff you can do to make these trucks drive so much better. Good luck with it.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
