09-16-2023, 11:07 PM | #1 |
lokar shifter hitting dash. slips out of park
I have a 1972 k20 that the pervious owner put in a lokar shifter on the floor. The shifter is a little sloppy with the movements. it goes all the way to and hits the dash when i try to put it in park. a couple times when i have tried to start the truck it jerks in reverse because it is in gear. is there a way to move the shifter or angle it back? i looked at the instal instructions it didnt say much. also is the supposed to be some kind of kill switch that wont let the truck start in gear?
09-16-2023, 11:26 PM | #2 | |
Re: lokar shifter hitting dash. slips out of park
As for the shifting problems, you may have to pull the hump panel and tighten up some of your transmission control connections. As there are several makers of aftermarket shifters, we need pix of your set up. I'm sure it can be moved but I have no idea how. I had an idiot at a Jiffy Lube muscle his way past a detent on a B&M floor shifter on my '67 K/10 Suburban w/ 454/TH350/NP205. All the kid needed to do was pull up on a toggle under the T-handle to go over a gate, but they can't afford to hire geniuses there. Now I change my own oil. I replaced it with a Hurst shifter.
09-17-2023, 08:56 AM | #3 |
There are different locations on the shifter plate to optimize lication. The adj shift rod length can be changed as well. Mine had several locations, now it works nice. It's hard to get in low, but with BB and deep gear, never use low.
09-17-2023, 10:21 AM | #4 | |
09-17-2023, 04:43 PM | #5 |
I have a Lokar cable shifter in my LS/4L60E swapped 98 Wrangler. 15 years on the swap zero issues.
On my current 80 Camaro LS3/4L60E project I used the Lokar shifter but its the direct rod style. On my Camaro I had to build a bracket that bolted to the front two mounting holes in the Lokar mount to tip the shifter back a bit. See pics. I would contact Lokar for NSS adjustment. I don't believe they sell one an auto shifter without one. |
09-23-2023, 04:53 PM | #6 |
i think the previous owner installed incorectly. there is too much slop in the lever before it even moves out of gear. the rear mounting bracket is missing i think if that was on it would be solid. i also think the shifter needs to be moved back one notch on the pattern. ill post pictures later to show what i mean.
09-24-2023, 12:08 AM | #7 | |
The cable operated shifter is different from my "rod operated" shifter. My shifter came with 3 different arms that fit on the shifter mechanism. After you get the shifter mounted in the floor, and have selected the arm and have it "clocked" per the instructions, here's how to get the transmission arm and shifter in sync and connected.. Remove the threaded shift rod. Put the shifter in park. Put the transmission in park. Measure the distance between the holes in the two arms.. Subtract 1 1/2 inches and cut the treaded rod to that length.. Put a jamb nut on each end of the rod. Install a spherical rod end on each end and adjust the length so that the connector bolts will pass through the rod ends easily..... The detents in the transmission should coincide with the detents on the shifter.. |
Tags |
lokar shifter |
