Old 10-18-2023, 08:29 PM   #1
chaileyk5
'Stock' replacement spring questions
Getting ready to start the refurb (again), and have some stock spring questions. Somewhere around 2000 I put a set of 2.5in springs up front with blocks in the rear. I'm wanting to go back to stock height, and am looking at one of the online spring places (General Spring, SD Truck Spring, etc.).
For the fronts, what is the thought between the 2 leaf vs 3 leaf? I think the originals were 2, but I'm not positive. I assume the 3 leaf will ride a bit rougher (I'm thinking Bilsteins to help), but is there anything else to take into consideration?
For the rear, I was thinking about keeping the 51 year old stock springs with 2in blocks to help level it out - any potential issues with this? Or should I just pull the trigger on the 5/1 leaf replacements?
Last question - does anybody have the correct model number for stock size Bilsteins, front and rear? I'm only seeing two choices on their site (part 24-009232 and 24-192941) - both are showing as front, but I'm not sure what the difference is.
Thanks for the help!
chaileyk5 is offline   Reply With Quote
Old 10-18-2023, 08:41 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 'Stock' replacement spring questions
My '70 has 3 leaf front springs, but it is optioned with F60 Heavy Duty front springs.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 10-18-2023, 10:06 PM   #3
chaileyk5
Good call - didn’t even think to check the options. I’ll take a look tomorrow to see what came from the factory. Thanks!
Old 10-26-2023, 02:52 AM   #4
Richard
IMO, look for a cheap standard hydraulic shock for a stock leaf or even the stiff aftermarket lift offerings. A gas type shock will just make the ride firmer. Stiff spring + stiff shock = uncomfortable.
Richard
