Old 10-23-2023, 06:46 PM   #1
DBear
DBear's Avatar
LS 5.3/NV4500/NP205 swap
Good evening, looking for some info. I'm swapping a 5.3/nv4500/np205 into my 71 k10 suburban, that is originally a 350/sm465/205 truck. The nv4500 is a 93-95 model. I have already purchased the Advance Adapters bellhousing kit. I do not plan on running a hydraulic clutch. What I need help with is the flywheel, pressure plate, clutch, etc. I was originally going with the stock 350, so I was gonna use the clutch and all from the sm465, but changed to an 02 ls 5.3. I know AA has a kit for flywheel, clutch, and pressure plate, but very expensive. Could I piece mill different factory parts to save money? If so, can someone lead me the right direction? Thanks in advance
DBear is offline   Reply With Quote
Old 10-27-2023, 08:12 AM   #2
clay68c10
clay68c10's Avatar
Re: LS 5.3/NV4500/NP205 swap
Lots of info here, but the short answer is yes.
https://ls1tech.com/forums/conversio...-ls-motor.html
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is online now   Reply With Quote
