Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-17-2023, 11:05 PM   #1
Old_Green
Old_Green's Avatar
Cool 1968 C40 to K40 pickup project BlueMule
1968 C40 w/ 12' flatbed turned into long bed 4WD pickup
I'm hoping to match front fender flares on bed. Stretch cab or make 4 door cab.
I picked this up last year, so some work is done, I will make several posts to catch this up to date
Old_Green is offline   Reply With Quote
Old 11-17-2023, 11:18 PM   #2
Old_Green
Old_Green's Avatar
Re: 1968 C40 to K40 pickup project BlueMule
Picked up Last year 80Kmiles 250 strait 6
Old 11-17-2023, 11:22 PM   #3
Old_Green
Old_Green's Avatar
appeared solid except for some rust in floors in the footwells and along the rocker seal area.
Old 11-18-2023, 12:00 AM   #4
Old_Green
Old_Green's Avatar
I was looking for a parts truck to snag some front fenders. I found one I wanted, but was a little too much to bite off for a parts truck.
72 C60 Bucket truck they used for setting telephone poles in the mountains. It had the Napco 4WD package, a 427 and had the wider fender flares, but it had a lot of rust too.
I wanted it for the Napco, but it was really heavy duty. 11K lb front springs and 28K lb rear. The price also put it a a little over the top for me. He sold it for 5K, but it was an interesting truck.
Old 11-18-2023, 12:12 AM   #5
Old_Green
Old_Green's Avatar
Still searching, I found one I liked that was in decent shape. My buddy Dave pulled out his Truck and we hauled it home. Its a 72 C50 Fuel truck with an older fuel tank on it. was kind of a cool looking tank, but I couldn't find a use for it. Found a guy that is going to use it to store diesel. He took the parts I didnt need. Frame, axles, Tank, pumps, hoses. All I really was looking for was the fenders, but kept the whole cab & engine, a running 350.
Old 11-18-2023, 12:38 AM   #6
Old_Green
Old_Green's Avatar
So, back to the BlueMule. I got it into the garage, and picked up a couple of truck beds from Facebook Marketplace. First one looked nice, but ended up having a lot of bondo. Since I was going to be doing a lot of cutting and welding on it, I wanted to find one with better metal. The 2nd was a little rough, but mostly where I was going to be cutting material out, and it had Zero bondo on it.
I pulled the wood off of the flat bed, which was rotted, and sold the bed frame. I then placed the pickup bed on the frame and lined it up over the axle and put some temporary spacers under it to line it up to the cab lines. I didn't mount it solid since I hadn't decided on the frame shortening method yet.
Old 11-18-2023, 12:55 AM   #7
Old_Green
Old_Green's Avatar
About the same time as I got the beds, I Picked up a tall deck 427 as a possible builder for it. Also took the cab and engine off of the Tank truck to scavenge the fenders. Set the rest aside as parts for future use.
I took the Tank truck fenders and cut out the wheel openings to patch into the bed wheel openings. Notice the fancy duct tape holding the extension on. Yep.
Old 11-18-2023, 01:12 AM   #8
Old_Green
Old_Green's Avatar
Jumped right in and started cutting. I wish Id taken more pics here, but only have the cutout then the patched in flare. The last 2 are welding the wheel well back to the factory inner panel.
Old 11-18-2023, 07:09 AM   #9
Looks like your plan is coming along nicely. The tank body would be nice on another classic truck
Old 11-18-2023, 10:15 AM   #10
too much stuff
Roadtrip!
too much stuff's Avatar
Coming along nicely. Any more price or info on that napco?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-18-2023, 02:07 PM   #11
Old_Green
Old_Green's Avatar
I thought it was a cool looking tanker too, just couldn't figure what I would do with it.
Old 11-18-2023, 02:11 PM   #12
Old_Green
Old_Green's Avatar
It was a cool truck, ran great too. I updated the post above. He sold it, I think he got 5K.
Old 11-22-2023, 05:20 PM   #13
Old_Green
Old_Green's Avatar
Picked up some emblems and hood vents off of Facebook.
Mike
67 Camaro "Amber"
72 K10 Longbed "Old Green"
68 C40 to K40 project BlueMule Build
2006 GMC Sierra "Lello Truck"
Old 11-22-2023, 05:26 PM   #14
Old_Green
Old_Green's Avatar
Tried to do some work with the stud puller. The one next to the light worked pretty well. the one near the bottom edge ripped a little before I got it all the way out. Welded back up ok though.
Mike
67 Camaro "Amber"
Old 11-22-2023, 05:58 PM   #15
Old_Green
Old_Green's Avatar
I spent some time on the passenger bed side. 2nd pic shows the rear of the wheelhouse area. I'm leaving a little extra material to see if I can attach it to the bed structure. It will create a natural mud flap of sorts. Last pic is another parts donor that I picked up. It an 87, but it has a 1996 454, 4L80e. The 4WD is a dual stick NP205 with a Dana 60 front and 14bolt rear. I pulled off the Peterbilt sleeper and the cab and sold those as they wont be needed for this project.
Mike
67 Camaro "Amber"
Old 11-22-2023, 07:41 PM   #16
Old_Green
Old_Green's Avatar
have been working on some patch panels, trying to clean up some rusted areas. This is one at the passenger front fender. I used part of the bedside that I cut out for the flare insertion in the bed for the main body line, and part of the wheelhouse that was left over for the curved area. Rust mort was used to convert the rust in the inner panel area as best that I could, and covered with some enamel primer called rusty metal primer
Mike
67 Camaro "Amber"
Old 11-22-2023, 07:49 PM   #17
Old_Green
Old_Green's Avatar
more work on the patch panel.
Mike
67 Camaro "Amber"
Old 11-22-2023, 08:15 PM   #18
6BT 56
6BT 56's Avatar
Love these trucks. I have a GMC topkick 4x4 chassis waiting for when I find some
Nice tin to use.
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 11-25-2023, 03:41 AM   #19
LT7A
This is a cool project. It'll be cool to watch the progress.
Old 11-27-2023, 11:14 AM   #20
Old_Green
Old_Green's Avatar
I have found that I didn't take a lot of pictures during some of the work, and a ton of pictures during others. I installed that patch into the fender. I took pics of the patch creation but not the welding or body work. I also missed out on the cleanup under the patch. I treated inner panel with rust mort, and then a rust resistant primer. I followed that up with a cavity wax to hopefully seal off any areas I might have missed.
Mike
67 Camaro "Amber"
Old 11-27-2023, 11:44 AM   #21
Old_Green
Old_Green's Avatar
since I ended up with 2 full cab and front ends, I started checking for which pieces are in better shape. The blue cab floor and both kick panels are rusted out pretty bad. The grey cab was in a little better shape. It has some rust in the rear drivers side rocker area, and some in the inner rocker area of the footwells, but overall the floor was in better shape than the blue cab. The blue cab also has a beat up back panel from hauling things on the flat bed over the years.
Mike
67 Camaro "Amber"
Old 11-27-2023, 12:12 PM   #22
Old_Green
Old_Green's Avatar
I put the grey cab on a rolling cart, but it was a little unsteady. My friend Dave brought over his cab body cart, and I moved the cab over to that. It has a pretty ingenious idea. The cab mounts the cart at the stock mounting locations, and then the cab can be rolled around as needed. If you need to work on the topside, there are two "legs" that can slide into any of the four sides of the cart. You can then roll the cart and cab either 45 or 90 degrees onto the legs.
Mike
67 Camaro "Amber"
Old 11-27-2023, 12:36 PM   #23
kwmech
If I ever decide to take on one of these as a project, I'd be inclined to put a turbo diesel in it. Like maybe a 4bt
Old 11-27-2023, 12:39 PM   #24
Old_Green
Old_Green's Avatar
After tossing around a lot of ideas, I want to attempt to do something a little different. I've seen 4 doors and extended cabs. With the size of this truck I think it will look good with the cab a little longer. This will means I'm going to be stretching the cab, and the doors by six inches. I'll start by keeping the roof off of the extra cab. I like the tear drop lights better than the little rounded ones on the newer cab. Then I'll cut some sections out of the cab to use in the stretch area. (some rusted areas will have to be replaced by extra metal)
Mike
67 Camaro "Amber"
Old 11-27-2023, 01:22 PM   #25
Old_Green
Old_Green's Avatar
First I put in a lot of support in the cab to keep its shape, but I left space between front and back sections so that I can separate them. I used all-thread at all 4 corners with locknuts on both ends to control movement. I placed the brackets exactly 2" apart and welded them to the body in order to ensure when I moved the sections apart that I was moving them evenly, and I could fix it in place with the lock nuts when I was in correct position. I made my cut on the roof thru both panels about 3 inches in front of center. I then trimmed the outer panel back 3 inches to center, leaving the inner panel cut out in the open, On the donor roof, I left it long so I could patch in wherever I needed to. The floor was cut just in front of the seat mounts. Its pretty flat there, so I can use flat sheet metal where donor pieces are rusty.
Mike
67 Camaro "Amber"
1968, 427, c40, c50, k40
