Old 01-06-2024, 10:13 AM   #1
fishnixon
fishnixon's Avatar
Chev-odge: ‘71 K20 Cummins build
Welcome to the build of my Chev-odge. I’m Rob and I’ve always wanted a Cummins diesel truck and I wouldn’t want anything else except a 67-72 Chevy to house it in. I am thankful for this site and the resources it contains as I certainly will be needing them, and you. Thank you for your input and help ahead of time. Enjoy the fun and struggles with me that this will bring…and hopefully we’ll see a great outcome at the end.
So to start things off, here’s the 1989 5.9 Cummins I purchased with 400,000 miles. With this, I received the 5 speed Getrag transmission (no transfer case), the front and rear differentials (with 3.08 gears I am told, not verified), the driveshafts and to me, one of the most important items…the front clip of the Dodge. Right now my goal is to use the factory Dodge crossmember (with mod and fabrication) in the K20 frame. I think using the Mopar mounts will be slick. Has anyone else used a Mopar cross member? If so, what was your experience?
fishnixon is offline   Reply With Quote
Old 01-06-2024, 10:54 AM   #2
raggedjim
raggedjim's Avatar
Re: Chev-odge: ‘71 K20 Cummins build
Sounds like fun, Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 01-06-2024, 11:19 AM   #3
Getter-Done
Getter-Done's Avatar
I will follow along.
Here are a Few threads.
Link: https://67-72chevytrucks.com/vboard/...hlight=cummins
84 Chevy K-20
Old 01-06-2024, 06:47 PM   #4
regan wilson
regan wilson's Avatar
Looking forward to seeing the build.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 01-06-2024, 11:24 PM   #5
D.B
Me too, this will be interesting!!
D.B is offline   Reply With Quote
Old 01-08-2024, 10:35 AM   #6
fishnixon
fishnixon's Avatar
Old 01-08-2024, 10:36 AM   #7
fishnixon
fishnixon's Avatar
Originally Posted by Getter-Done View Post
Thank you for the links…I’ll check them out
Old 01-08-2024, 10:37 AM   #8
fishnixon
fishnixon's Avatar
Thanks for following!
Old 01-08-2024, 10:38 AM   #9
fishnixon
fishnixon's Avatar
Hope you like it, and thanks for the follow.
Old 01-08-2024, 11:08 AM   #10
fishnixon
fishnixon's Avatar
I’m calling in reinforcements. Jim and John (father and son), know what to do…they do this for a living.👍
Old 01-08-2024, 11:11 AM   #11
fishnixon
fishnixon's Avatar
The stand is holding!
Old 01-08-2024, 11:13 AM   #12
fishnixon
fishnixon's Avatar
Manifold side done
Old 01-08-2024, 11:15 AM   #13
fishnixon
fishnixon's Avatar
To say the least, a new water pump is needed.
Old 01-08-2024, 11:16 AM   #14
fishnixon
fishnixon's Avatar
Dowel pin is still there even with 400k miles.
Old 01-08-2024, 11:19 AM   #15
fishnixon
fishnixon's Avatar
Intake side done
Old 01-08-2024, 11:20 AM   #16
fishnixon
fishnixon's Avatar
Getting ready to pull the injectors
Old 01-08-2024, 11:22 AM   #17
fishnixon
fishnixon's Avatar
Off with it’s head!
Old 01-08-2024, 11:24 AM   #18
fishnixon
fishnixon's Avatar
Found a small bolt in oil pan…yikes!
Old 01-08-2024, 11:27 AM   #19
fishnixon
fishnixon's Avatar
Inner bolt from timing cover housing.
Old 01-08-2024, 11:31 AM   #20
fishnixon
fishnixon's Avatar
Bolt got wedged between housing and cam gear, chewing up the housing.
Old 01-08-2024, 11:33 AM   #21
fishnixon
fishnixon's Avatar
Everything is coming out…
Old 01-08-2024, 11:36 AM   #22
fishnixon
fishnixon's Avatar
Gutted and ready for magnaflux testing and then machining.
Old 01-08-2024, 03:14 PM   #23
loudchevy
Active Member
loudchevy's Avatar
Awesome build, I'll be following along. Do you have the K20 already?
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 01-08-2024, 03:51 PM   #24
fishnixon
fishnixon's Avatar
Thanks for tuning in…Yes, I have the frame and the cab.
Old 01-09-2024, 04:04 PM   #25
fishnixon
fishnixon's Avatar
Brought some parts home to clean up and prime…the pistons are home for good as they won’t be used. We’re going .020 over on the block.
