01-14-2024, 02:38 PM | #1 |
2wd vs 4WD rear
Is there a difference between a 2wd and a srw 4wd rear on 3/4 or 1 tons? Perch location/ mounting? Thanks
Pic for attention
1985 Custom Deluxe long bed 305 3 on tree 2015 Silverado "Great White"1987 K20 dump and plow 1968 K20 327 long bed 4spd big blue 68K20 SuburPan 4spd 79C30 L96 6L90e 86 K10 plow |
01-14-2024, 04:13 PM | #2 |
Active Member
Re: 2wd vs 4WD rear
2WD and 4WD have the perches in the same location. 3/4-ton & 1-ton use different locations. Basically a 3/4-ton rear axle will mount to 3/4-ton or 1/2-ton 2WD or 4WD. A 1-ton SRW will mount to a 1-ton 2WD or 4WD SRW 1-ton.
01-14-2024, 06:31 PM | #3 |
Post Whore
Re: 2wd vs 4WD rear
i know you said SRW ,but to add to this a C&C rear axle is narrower than a dually axle on 1-tons
01-14-2024, 08:23 PM | #4 |
Re: 2wd vs 4WD rear
Thanks for your help 🏁
