01-15-2024, 07:46 PM | #1 |
Front sway bar install
Today I installed the front sway bar. It is FSBK6372 from POL. I bought the front and rear in a kit. Nice looking bar, I can see it making a difference.
01-16-2024, 11:53 AM | #2 | |
68 C10 Longbed
Re: Front sway bar install
Looks great, I went with the CCP brackets and an original front bar. |
01-16-2024, 02:19 PM | #3 | |
01-17-2024, 02:43 PM | #4 |
What is the purpose of using the sway bar frame stand off bracket vs just attaching the mount to the frame?
01-17-2024, 03:11 PM | #5 |
I don’t know for sure, but this bar from POL was designed to mount on frame. I’m guessing the bar is contoured so it can be mounted like that. Maybe the bars that use the mounting bracket are straighter. I noticed some sway bar kits have short and tall mounts in case your truck has been lowered.
01-17-2024, 05:19 PM | #6 |
68 C10 Longbed
Not sure, but that’s how the General did it originally. I used an original sway bar and my truck sits at factory height so I didn’t feel like reinventing the wheel.
01-18-2024, 10:46 AM | #7 |
Nice looking, need one for my 67 3/4 2wd.
01-18-2024, 12:24 PM | #8 |
IMHO adding a 1 1/8 front sway bar vs none make a big improvement in handling (body roll). My 72 did not come with one so I installed the one I got from LMC
01-18-2024, 12:48 PM | #9 |
Go Canada....
The first stabilizer bar patent was awarded to Canadian inventor Stephen Coleman of Fredericton, New Brunswick on April 22, 1919.[1][2] |
01-18-2024, 01:32 PM | #10 |
Drove my 68 C20 for years without a bar, then one came up on a truck my son-in-law was parting out. I installed it--all factory parts--made a huge difference driving the mountain roads I live in. Night and day difference
01-18-2024, 07:16 PM | #11 |
It’ll be the difference between night and day.
I put mine on many years ago, and was immediately satisfied with the way it firmed up everything. I got mine from an old salvage yard frame in NC. I got it for a steal but had to put in the “Sweat Equity” by removing the perches by hand. (I used a little saws all, a chisel, a 4lbs sledge, and a pry bar, to cut the factory rivets) Mid-July heat in Fayetteville NC is no joke. |
01-19-2024, 01:14 AM | #12 |
Same thing I did, scratched it all off of a 2500, frame brackets and all. I've done several trucks like this, world of difference. Especially when you use Energy Suspension bushings.
03-09-2024, 12:47 AM | #13 |
You put a 70's C10 on a 2500 chassis? Any pics?
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
03-10-2024, 09:34 AM | #14 |
No sir. What that post is referring to is that I removed all of the front sway bar and frame brackets from a mid '80s 2500 square body truck and installed it onto my '68 C10. World of difference for a whopping $25.
The original rivets on the frame brackets can be a booger to get out if you don't have a grinder to cut the heads off with. Most salvage yards won't let you use anything that can produce sparks. Much easier to grind them off, but they wouldn't let me use the grinder so I had to drill the rivets out doubling the 20 minutes it usually takes to get the bar and brackets off. This last bar I removed had a good set of Energy Suspension bar mounts and bushings installed on it. BONUS |
01-19-2024, 08:40 AM | #15 |
Got to agree. Of all the tinkering I've done, the front sway bar and headlight relays have made the most difference to me.
01-19-2024, 09:37 AM | #16 |
68 C10 Longbed
01-18-2024, 10:47 PM | #17 |
Senior Moment
Years ago I put a front bar on and couldn’t believe the difference. Now years later I have Full QA1 Suspension front and rear. Rides Great, Handles like a Go Cart. Love it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
01-18-2024, 11:29 PM | #18 |
That’s a nice setup!
01-19-2024, 06:47 AM | #19 |
68 C10 Longbed
01-19-2024, 08:32 AM | #20 | |
I went with 2" drop spindles and 650# springs on the front with dual adjustable shocks. What settings are you running on the shock adjustments? I know it may take some "dialing in" .....just looking for a starting point for the best all around ride/handling settings. I'm running an all aluminum LS1 so it's about 100# lighter in the front than a standard small block.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-19-2024, 12:33 PM | #21 | |
Senior Moment
And #750 springs (recommended by QA). Im at 6 in the front and 4 in the rear Nice thing is if you don’t like it you have 18 adjustment points that can be made in a matter of minutes
03-08-2024, 09:18 PM | #22 | |
New Member
These pictures help. The directions included from POL aren't that helpful. Was trying to figure out how the 'L' bracket was going on to the front Arm. Do you have any pics of the rear installed? |
03-08-2024, 11:37 PM | #23 |
[QUOTE=Hupper7;9294270]I just bought the front and rear POL sway bars for my C20 with coils.
These pictures help. The directions included from POL aren't that helpful. Was trying to figure out how the 'L' bracket was going on to the front Arm. Do you have any pics of the rear installed? I have another post called rear sway bar install. I tried to copy and paste the link here: http://67-72chevytrucks.com/vboard/s...d.php?t=849910 . Last edited by LockDoc; 03-09-2024 at 12:55 AM. |
03-09-2024, 01:39 PM | #24 | |
03-09-2024, 01:52 PM | #25 | |
New Member
When I picked them up at POL, the salesman told me that would be the position. Just checking in with someone who has installed them. |
