1970 Chevy k20 front drums
Anyone know if these rear drums part number BrakeBest Select Brake Drum - 9625DGS from a dodge 3/4 ton van fit the front of my 1970 Chevy k20 with Dana 44 open knuckles front axle? I know there was an older thread but I want to make sure they fit good and work before I possibly buy them. Thanks
I'm trying....
![]() Join Date: Oct 2013
Re: 1970 Chevy k20 front drums
I am working toward this. That's what I have bought. If I beat you to it, I'll let you know.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
Ok thanks let me know if they work out for you then I’ll grab a set thanks.
At my NAPA store I was sent home with the wrong Dana60 shoes twice. I brought my shoes in and the better parts man grabbed a book that had drawings and dimensions or various shoes. For an 8-lug it's all about the diameter and surface width. Your drums should have "max dia" stamped on the back edge. Mine said 12.125", so 12" drums allowing for 1/8" machining
I am not sure about the open knuckle dana 44 with drums, but for my closed knuckle dana 44 on my 1967 K20, the Raybestos 2008R drums were a fit. I did have to drill out the lug holes and ream them as I have upgraded the studs to 9/16" but the drums themselves fit over the shoes perfectly. I believe that this drum was used on 1950's Chevy 3/4 tons, but I am not 100%.
https://www.rockauto.com/en/moreinfo...t=1744&jsn=727 Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
Ok thanks probably won’t work I’m thinking I’ll possibly try the oreillys part number drums and see if they work if not I’ll probably return them.
Born Psycho
![]() Join Date: Feb 2001
a place called torque king 4x4 shows them (406)384-0270, they are quite pricey @ $283.98 each
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
I'm trying....
So far so good.
Is your front axle open or closed knuckle? Is your year a 1970 also? Year doesn’t matter Just trying to make sure it fits on mine thanks.
I'm trying....
70 K20. Open knuckle. June of 70 build date.
Ok thanks are studs long enough also? They look like it thanks
#13 |
I'm trying....
Factory length studs are fine on the front. When you get to the rear it may be a different issue. I had to bump it up there to have enough. I don't have the Dorman numbers with me at work, but I could post later if needed. There are a few threads that document the rear stud problem.
#14 |
Yeah I have different ones for the back I was just more worried/concerned about the front because they are basically impossible to find and since these work for the front I’m going to buy these.
#15 |
I'm trying....
Raybestos 2009R works for the rear, but the Eaton is a different animal altogether. Many threads on here are very helpful with that. You can see my set up with the longer studs.
#16 |
You mean Eaton rear end? I don’t know which rear end I have or even what rear end gears I have. lol
#17 |
I'm trying....
Yes. The rear axle. You most likely have an Eaton H052 axle with either 4.56s or 4.10s.
#18 |
Mine came factory with a 350 SBC and 2 barrel carb along with a 4 speed manual. That’s all I know about it.
#19 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Any list of art that transcends generations will include the walking liberty half dollar, Bach's cello suites, Neuschwanstein castle, Rubens's The Descent From the Cross, and a Hall Brothers truck.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#20 |
I'm trying....
"Excuse me, Mrs. DeadheadNM, is this your husband? We found him wandering around downtown mumbling something about a castle and a truck."
Pete you're crazy. But thanks I think. ![]()
