02-25-2024, 06:25 PM | #1 |
For those who do, how do you gap spark plugs?
So back in the day I used the slotted bender built into the gap gauge to bend the electrode. But I have found on modern spark plugs the electrode is very hard and the slotted bender bends before the electrode and there is often not enough room to fit the slot of the bender in there to do the bend. On the last batch I clamped the electrode with vise grips and bent it, but it didn't feel very scientific to be doing that. What is the correct way? I know a lot of people just leave them gapped at whatever gap they are at when purchased, but sometimes I want do dial in my own preferred value. Considering how seldom I do this I'm not sure I would get some $100 tool for it, but perhaps I could.
02-25-2024, 06:34 PM | #2 |
Re: For those who do, how do you gap spark plugs?
Gee, I'm still using the included gapper hook on the feeler gauge. But then I insist on copper electrode plugs. No fancy-dancy platinum for me -- you can't clean it up with an ignition file. Also I'm only going to .045. Both trucks have HEI.
The old Craftsman key chain round gauge, with an inclined plane on the circumference edge might help you if you have a way to drive it between the tip and the ''claw.'' If I were a Pro, and worked in a shop, I could write off the expense of the $100 tool and impress customers with my mojo by using it. But otherwise, no thanks.
02-25-2024, 08:27 PM | #3 |
Who Changed This?
I was a pro and worked in a shop and used the tapered tool, and the one with bits of wire on it. Electrodes weren't that tough, back in the day.
02-25-2024, 09:59 PM | #4 |
I could never find the damned tool, I always used whatever pliers I found first
1970 C10 Custom longbed 350/350 |
02-25-2024, 10:29 PM | #5 |
The Niner
What the heck type of plugs are you using?
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
02-25-2024, 11:19 PM | #6 |
Autolite 24 copper resistor plug.
02-26-2024, 07:58 AM | #7 |
I use the round gauge like 68OrangeSunshine described.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
02-26-2024, 08:33 AM | #8 |
I have alll three os these in my tool box, but tend to grad the flat blade one and it's tool as that is what I am use to using.
02-26-2024, 11:37 AM | #9 |
I have one each of these.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
02-26-2024, 03:33 PM | #10 |
I like how Derek of Vice Grip Garage does it... He looks at the new plug and says "gapped." -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-26-2024, 03:44 PM | #11 | |
It also has a thicker, beefier bending hook.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 02-27-2024 at 04:11 PM. |
02-27-2024, 03:15 PM | #12 |
I have those too. Pick what works at the time.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-27-2024, 06:11 PM | #13 |
I find on newer plugs I am always closing up the gap a bit. Don't remember the last time I opened them. I use the round tapered gauge and just give a couple raps of the electrode on my vice to close them up.
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
02-27-2024, 08:30 PM | #14 |
Do you insert the gauge at the setting you want while rapping it on the vice, or rap/measure/repeat?
02-27-2024, 08:40 PM | #15 |
Active Member
The old knife blade aint bad for opening them up. Also good for cleaning finger nails, cutting wire and getting viennia sausage out the can lol
02-28-2024, 01:12 AM | #16 |
That last option is the most important.
02-28-2024, 01:16 AM | #17 | |
Measure again til it's there.. The important thing is not to spill the beer.
02-28-2024, 08:32 PM | #18 |
rap/measure/repeat
02-28-2024, 11:42 PM | #19 |
Thanks for the education, I'll fix up these spark plugs just right.
Tags |
spark plug gap |
