Old 03-28-2024, 03:29 PM   #1
wholio
wholio's Avatar
Bought awhile back.
It's been a while since I've touched my project. I bought it a while back but haven't had much time to work on it lately. I really need to start messing with it again.
One thing I'm stuck on is the wiring situation. It's all kinds of messed up and I need to find a good wire harness to get it sorted out. This thing has a 454 engine with a 350 transmission. Do you have any recommendations for a wire harness that would work well with this setup?
I'd appreciate any advice you can give me on getting the wiring squared away so I can make some progress on this project.
its a 1972 blazer 2wd, with a 454
it aint custom unless you CUT IT!!
My Restoration Begins on a 1969 k5
wholio is offline   Reply With Quote
Old 03-28-2024, 03:31 PM   #2
wholio
wholio's Avatar
Re: Bought awhile back.
Heres some pictures.
Old 03-28-2024, 10:18 PM   #3
Getter-Done
Getter-Done's Avatar
Does it have the original harness in place?
Does it have HEI ignition?
Pictures of the fuse box and Under hood wiring would be helpful.
84 Chevy K-20
Old 03-29-2024, 08:02 AM   #4
A1971Blazer
A1971Blazer's Avatar
what is the issue with the wiring?
I would start by downloading and printing the wiring diagrams found here.
https://67-72chevytrucks.com/vboard/...d.php?t=185856
That will help identify which wires you need to look for to solve problems.
If it's all hacked up, you may want to consider a new harness.
You can get separate harness components such as the engine harness and front lamp harness
that will plug right into the bulkhead connector at the fire wall and replace all the hacked up wiring under the hood.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-31-2024, 11:48 PM   #5
NDM
Best purchase I have made for my blazer was my American autowire upgrade kit! It solved all of my electrical issues and was a superb kit. I was nervous to install it but it was not bad with the detail that they put into the kit. The wires with labels every foot was fantastic! I am a normal dude and do not work for them or anything. Just a happy customer. I bought it on Amazon too.
American Autowire 510089 Wiring Harness for Chevy Truck
NDM is offline   Reply With Quote
Old 04-03-2024, 10:24 AM   #6
dirtscoots
dirtscoots's Avatar
That is good to hear. I got a wiring kit for mine and unboxing it was overwhelming with all the wires. I haven’t gotten the courage to start yet
dirtscoots is offline   Reply With Quote
Old 04-03-2024, 10:34 AM   #7
NDM
The American autowire kit was actually pretty easy but I had to just break it down to a little piece a day. I did it in just a few days after work.
100% worth the money. My OE wiring was so screwed and the firewall bulkhead was like melted or something.
Old 04-05-2024, 11:41 AM   #8
dirtscoots
dirtscoots's Avatar
I put a new motor in mine. Every wire I looked at was horrible. Then I noticed wire nuts and it was time to abandon all wires anyone else had touched.
Old 04-20-2024, 11:03 AM   #9
LT7A
Cool Blazer, neat flames and darling co-pilots. Good luck with the wiring. I'm no help in that department - I'd just have to go one wire at a time.
