Old 04-04-2024, 06:00 PM   #1
1972RedNeck
1972RedNeck's Avatar
Fuel gauge diagnostics
1963 Chevy. Regulator died and over volted the temp and fuel gauge. Got the charging problem fixed. Bought a temp and fuel gauge from Truck and Car shop. Temp gauge works perfect.
Fuel gauge does not work. I have 12 volts at the gauge. To bypass the whoe sending circuit, I grounded the sense terminal at the gauge. Gauge should go to full when grounded but it just sits below empty and doesn't even wiggle.
They sent me another gauge to try - same thing. Again verified power. Again grounded sense terminal at the gauge. Still does nothing.
What am I doing wrong?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 04-04-2024, 07:02 PM   #2
ray_mcavoy
Re: Fuel gauge diagnostics
Grounding the sense terminal on the gauge should cause it to read empty (like you're seeing), not full.
For additional testing purposes, connecting the gauge sense terminal to through a 15 Ohm resistor to ground should cause it to read half. Connecting it through a 30 Ohm resistor to ground should cause it to read full. And leaving the sense terminal disconnected should cause the gauge to peg beyond full.
ray_mcavoy is offline   Reply With Quote
Old 04-05-2024, 01:03 AM   #3
1972RedNeck
Hmm, this one stays way below empty no matter what…
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 04-05-2024, 10:18 AM   #4
ray_mcavoy
So no needle movement at all regardless of what you do with the sense terminal, correct?
That might be due to a bad ground at the gauge.
It's been a while since I've had one apart, but if I remember correctly, there is a ground contact on the back of the gauge that has to make electrical contact with the cluster housing. So check that area of the housing to make sure it doesn't have any surface rust, paint, etc. that would prevent a good contact. Might also be worth checking the gauge itself (compare it to your old one if you still have it) to see if maybe the new one is made a little different and not allowing it's ground contact to make a good connection with the cluster housing.
Old 04-05-2024, 02:41 PM   #5
1972RedNeck
No needle movement no matter what.
I will check this out and scuff it up with a little sand paper. Thanks for the tip...
1966 F250 4X4 416
1972 K20 350 4 OTF
