Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-21-2024, 06:21 PM   #1
1rippen6
Low back bucket seat tracks w/ brackets with p/s floor mounts and seat belts
Tracks are good but the mounting brackets need some tlc. I'm assuming the seat belts are correct for a bucket seat application and the floor mounts for the passenger side. They made need some extra metal welded on, I'm not sure if they cut them tight to the floor. Bucket seats are not available. The one passenger bracket was removed from the seat and the spacers were missing, the one side is there for comparison. 450 plus shipping
1rippen6 is offline   Reply With Quote
Old 04-21-2024, 06:22 PM   #2
1rippen6
Re: Low back bucket seat tracks w/ brackets with p/s floor mounts and seat belts
More pics
Old 04-22-2024, 08:47 AM   #3
TKCR
TKCR's Avatar
Should you decided to separate, I’m in for the seatbelts. Those are just single cab belts for the 76/77. Not specifically for just the Bucket seats. They were used for the Benchseats also.
Old 04-22-2024, 03:03 PM   #4
1rippen6
Even the center belts with the plastic cover to the buckle?
Old 04-22-2024, 03:31 PM   #5
TKCR
TKCR's Avatar
Yep, the retractors will need buckles.
Old 04-22-2024, 08:52 PM   #6
1rippen6
I may have not asked the question correctly. I was asking if the center belts on the bench seat trucks have plastic covers the whole way up to the buckles like the ones pictured.
Old 04-22-2024, 11:11 PM   #7
TKCR
TKCR's Avatar
The bench seat is slightly different, as far as the sleeves. And the of course there’s the center lap belt. But that’s the only slight difference. The retractor is still the same whether it’s for a bench or buckets.
Old 04-23-2024, 09:45 AM   #8
1rippen6
Ok, thank you for the pictures, that helps a lot. It does look like there is some slight differences.
Old 04-23-2024, 10:03 AM   #9
TKCR
TKCR's Avatar
Yeah, just that there’s a center lap belt added. The sleeves are slightly different to accommodate those.
Should you decide to separate, I’m interested in the belts.
