04-25-2024, 08:05 PM | #1 |
"Tail Gate Best Seat In House"
Home gas furnace .. I do not want no more
I grew up with folks using a wood stove ,,and I did the same for the begining of my grown up years out on my own ,, I then installed a electric furnace and AC ,,and enjoyed low killwatts per hour for years along with a wood stove too.
This house in Idaho we live in now has a furnace run by gas and electricity for the fan , Soon after moving here I quit using the gas furnace as it only heated the living room The Gas bill was high also ...So,,,,,,,,,I am now thinking of tearing the gas furnace out.. Am I the only one on here that is fed up with a gas furnace . Please read down a bit where I explain my fireplace that has a metal exhaust that goes out through the wall to the outside .. I did not explain this very well
When you learn a thing a day you store up smart. Last edited by GOPAPA; 04-26-2024 at 10:22 AM. |
04-25-2024, 08:43 PM | #2 |
Re: Home gas furnace .. I do not want no more
I had a high efficiency gas furnace put in our new house last year. I love ours. I think our bills are going to average around $100/ month.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
04-25-2024, 08:53 PM | #3 |
I have a high efficiency gas furnace, two gas dryers, a gas range/oven, and a gas tankless water heater. I love the way natural gas heats, and here in Utah the price is very reasonable.
I also have a gas fireplace, but we haven't used it in years. I do have a wood-burning stove in the basement and a supply of firewood, in case of emergencies.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-25-2024, 09:10 PM | #4 |
BlahBlahBlah
We have a gas furnace and AC with no issues heating the whole place. Maybe there is a problem with the way your ducts run? Seems odd it only heats one zone of your house.
As far as electricity goes our latest bill informed us of upcoming rate hikes, not small either.
04-25-2024, 09:26 PM | #5 |
GOPAPA, living in Idaho what do you use for heat during the winter if you do away with the gas furnace? Seen no mention of electric baseboarda or similar? How old is your gas furnace? We had a new gas furnace and electric 4 ton central unit installed about 6-7 Years ago. High efficiency furnace also with the flue stack exiting thru the roof and is PVC or similar plastic, warm to the touch but not hot at all. VERY pleased and during our Kansas winters our gas bill is $100 or a bit less each month. Also I run a wood burning fireplace which is very efficient. Glass doors, two speed blower unit and uses outside air to feed the firebox. Plumbed ducting under the floor in to our central air ducts. When running it I usually knock down the furnace t-stat setting a few degrees to keep the furnace from coming on. Pour up a Crown Royal and enjoy being retired while adding a log to the fire.
I don't see a time within the foreseeable future that our nation's electric grid will be able to supply the needed electric power that will be required during the winter for heat alone. Much as a few factions don't like the idea, natural gas is still our best alternative for such.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
04-26-2024, 07:19 AM | #6 |
The house I live in has electric baseboard heating and propane water heater . It works well if and when I use it . Its expensive and the grid here is iffy at best . Wish we had natural gas so I heat with wood . My rental has oil fired hot water and heat .
04-26-2024, 08:02 AM | #7 |
I hear good things about a "heat pump".
My sister in law is in the heating/cooling biz and she had one installed in her own home. I just moved and my new place has a heat pump for moderate weather and an oil fired traditional furnace for when it gets cold. I can't comment on how that works since we've only been there for about 36 hours. So far so good, though K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-26-2024, 08:13 AM | #8 |
Attention ! I did not explain myself very at all.. Let me start over, I have a gas furnace with duct work that works fine.. I also have a gas water heater that works fine ,, what I am wanting to maybe just get rid of is the fireplace in the living room that when running only puts out heat and that heat only heats the living room as it does not have ducts to spread any heat to other parts of the house . NOR ....does it have a chimney going out through the roof ,,it has a vented pipe through the exterior wall of my living room
When you learn a thing a day you store up smart. Last edited by GOPAPA; 04-26-2024 at 10:23 AM. |
04-26-2024, 09:34 AM | #9 | |
04-26-2024, 09:59 AM | #10 |
All about them Ks
I have a gas furnace and a wood stove. I only use the wood stove. That’s what I grew up with and that’s what I like. You could also look into a wood stove insert for the fire place to blow the heat out instead of just up the chimney. They work pretty good.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's 87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue 10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-26-2024, 10:00 AM | #11 |
Get a wood stove or pellet stove insert for the fireplace.
I have baseboard, a old non EPA wood stove and a pellet stove insert. I can heat cheaper with the baseboard per day than with the pellet stove. The pellet stove uses a fan to force feed the fire and turn the auger. The wood stove just cranks out the heat and wood is free or permit fee. I get mill ends for free in town and Junipers are weeds here. The wood stove runs 24 7 when I use it and is black out proof.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
04-26-2024, 10:37 AM | #12 | |
04-26-2024, 11:03 AM | #13 |
GOPOPA, okay, now I understand the situation more clearly with "the rest of the story" as the saying goes. Yup, the open gas fireplaces do more for just "the look" than actual heat. If and that's a big IF you like the fireplace I believe I would look into a wood burning insert or stove if you have the room. Pellet stoves have their features but along with everything else it seems the cost of pellets has gone up also. If you have the wood available to you I would think a true wood burner would have the advantage altho there is a bit of clean out and chimney maintenance along with cutting and splitting. With the wood stove you get the added feature of maybe a pot of beans, chili or stew sitting there simmering thru the day. Plus it's a constant coffee cup warmer for those cold days also.
04-26-2024, 11:33 AM | #14 |
If I didn't use my wood stove my electric bill in the winter would be around 6-700 dollars. I'm on 5 acres so there is plenty of wood to be had. We've gone through 4 cords so far.
04-26-2024, 01:11 PM | #15 |
BlahBlahBlah
Ok now I get what you are saying. We also have a gas fireplace and no it doesn’t heat the whole house, but we had no expectations for that.
It does nicely heat the area we want it to though.
04-26-2024, 05:17 PM | #16 |
Sorry about wording my post so terrible.. must be age kicking in.. I find myself doing dumb things more than ever .. I live in the city now and my days of wood burning are over. Been over since moving here 12 years ago.. The gas fired furnace I have works good so I have no compaints about it . The fire place looks good and to do away with after thinking would be a lot of money to do so with all the remodel work that it would create.
Always good to run things by you all ..
When you learn a thing a day you store up smart. |
04-26-2024, 06:04 PM | #17 | |
MidlifeCrisisUnderWay
I'm next door in Meridian. |
04-26-2024, 08:07 PM | #18 | |
That being said my gas fireplace has a glass front and puts out nice heat without sucking the air out of the house . We use it when it gets real cold like zero or below
04-27-2024, 03:06 AM | #19 | |
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 04-27-2024 at 03:11 AM. |
04-27-2024, 07:07 AM | #20 |
Everyone I know down here can't wait to get rid of their heat pumps. Very inefficient and typically requires more maintenance and parts replacements than traditional heat/AC systems. My furnace is gas (pretty much always had it except in my real young days we had coal t heat the house and the house at farm. Real fireplaces aren't that efficient in today's standards for heat distrobuton. The fake gas and electric ones seem to be there just for visual rather than real heating.
04-27-2024, 07:14 AM | #21 | |
When you learn a thing a day you store up smart. Last edited by GOPAPA; 04-27-2024 at 08:25 AM. |
04-27-2024, 09:20 AM | #22 |
One oddball idea for the fireplace is to seal up the chimney at the outside to keep bugs and birds out and then put a TV in the firebox. When you want a 'fire' just show 'fire on a loop' video. I think there is a site that streams a fire for just such a use. Avoids most of the remodel expense and you still have some of the fireplace ambiance.
04-27-2024, 10:26 AM | #23 | |
For now its on a back burner,, I appreciate all the advice all the same
04-30-2024, 03:50 AM | #24 | |
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-30-2024, 07:11 AM | #25 | |
Turn it on and run the forced air system fan to distribute heat to the rest of the house. Richard you do know your heating systems I agree with your thoughts for Southern Cali ,,but this just would not work out well for us in Idaho,,nothing does as good a wood heat,, but not any wood close to us here ,thx for your input all the same .
