Old 04-27-2024, 11:19 PM   #1
Tpo
Junior Member
Front turn signal ground question
1960 Apache 10.
Question 1. I have the clear lenses so I’ll buy amber bulbs. But I’ve seen 60s with amber lenses too. Did Chevy change to amber mid year?
2. The bulb housing grounds to the hood, correct? I have no continuity between my hood and the rest of my truck. My hood is firmly attached and I don’t think I can attach it any betterer than it is now. So I plan to connect both bulb housings to their own ground wires and run it down with the other lamp wires to the body itself. Anyone else done this?
3. The bulbs are so loose in the sockets that the bulb only illuminates if I press it quite firmly into the socket. Is there a trick to tighten these up? LMC sells replacement sockets for $3 but I’ve heard of replacement sockets being crappy from the git go. So if I could make the old ones work I’d rather do that.
I realize my truck was built almost 65 years ago but this turn signal grounding system is a pretty optimistic design on chevy’s part. Opinions?
Thanks!
1960 Apache10 long fleetside, 235 and SM420, Brigade Blue and Bombay Ivory
Tpo is offline   Reply With Quote
Old 04-28-2024, 12:18 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Front turn signal ground question
I wish I had more information for you. Are your hood hinges recently painted and that's why they don't conduct? I went to look at my 63 and notice the housing grounds to the hood, and there isn't a separate ground wire. I'm not there yet, but if I find better ground is needed on the hood, I will probably put a short ground strap between the back of the hood and the firewall.
dmjlambert is offline   Reply With Quote
Old 04-28-2024, 01:17 PM   #3
bigmoe
bigmoe's Avatar
I used these and ran a ground wire.
bigmoe is offline   Reply With Quote
Old 04-28-2024, 07:36 PM   #4
Tpo
Junior Member
Man it looks like my hood has never been removed so I don’t know why it’s not grounded. Hinge bolts are tight. Go figure. But I don’t care because I’ll just run a ground wire. Big moe those things are just what the Dr ordered! Where did you get them??
Old 04-28-2024, 07:41 PM   #5
1966c10shrtbd
1966c10shrtbd's Avatar
https://classicparts.com/chevy-gmc/c...66-truck-parts
1966c10shrtbd is offline   Reply With Quote
Old 04-28-2024, 08:57 PM   #6
Tpo
Junior Member
66 shortbed I didn’t see where they had a socket with a terminal on it on the classic parts site. I’d like the ones like moe has if I could find them.
Old 04-28-2024, 09:02 PM   #7
dmb
Active Member
dmb's Avatar
Run a ground strap from the hood to the firewall . When I worked for Chevrolet back in the 70s. I installed quit a few of them. Mostly for radio static but fixed the ground problems on the 60-66 trucks
Old dogs and children and watermelon wine
dmb is offline   Reply With Quote
Old 04-28-2024, 09:28 PM   #8
bigmoe
bigmoe's Avatar
It's been a while but I probably got mine on Ebay. Lots of plastic ones available but there are some metal ones. Do a google image search for 1157 tail light bulb socket and go from there.
Edit: try Dorman 85860
Old 04-28-2024, 09:51 PM   #9
Getter-Done
Getter-Done's Avatar
Yeah
Link : https://shop.advanceautoparts.com/p/...5860/5012139-P
84 Chevy K-20
Old 04-28-2024, 10:27 PM   #10
Tpo
Junior Member
You guys rock! I’m ordering some now. I like the idea of using the sockets with the ground terminal because my socket to housing joint is a little wobbly, in addition to the hot contacts in my sockets being wobbly too. DMB, how did grounding the hood to the body solve radio static?
Thanks men!
Old 04-29-2024, 04:42 PM   #11
dmb
Active Member
dmb's Avatar
was a lot of am radios back then and motor noise was a problem. Grounding the hood fixed a lot of it. you can take an older vehicle and raise the hood with the engine running on a am channel and you will see what I am talking about. We put condensers on the alternators too. Chevrolet had bulletins out the yen yang on radio static
Old 04-29-2024, 10:06 PM   #12
cwcarpenter98
cwcarpenter98's Avatar
The clear lens is correct for a 60, however the clear and amber lenses are the same except for the color, so it's really easy to put an amber lens in place of a clear one.
If your hood hasn't been off in awhile, it's possible that the original path to ground has gotten a smidge crusty and is no longer conducting properly. Adding a ground wire from the socket to the inner fender or cab would be a good way to solve your issue. I used a small hole that was already in the inner fender to ground the under-hood light I installed from a 90s Dakota. You can see it on the top left of the inner fender.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-29-2024, 10:27 PM   #13
Getter-Done
I remember this now.
I bet you precharged a condensor and left them laying on the work bench.
84 Chevy K-20
Old 04-30-2024, 02:52 AM   #14
Tpo
Junior Member
DMB, what’s an AM radio?��
Christian, your wiring is giving me the heeby jeebies, lol.
I like the looks of the clear lens better plus it’s what I’ve got so I ordered a 10 pack of amber 1157s for $9. I figure I can scrape the paint off a few and then I’ve got spare clear 1157s.
I’ve got the bulb sockets with the ground terminal on them ordered and I can’t wait to have park lights. Getting them to blink, now that’s another story…
