Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 04-28-2024, 01:56 PM   #1
GSP7
GSP7's Avatar
Spray Max 1K E-Coat Primer
Anyone used this epoxy primer for small areas?
I bought 3 cans to try out. Used the white e primer fixing small rust removal repairs on inner fender lips . Color actually matched dodge ram truck white
https://www.coastairbrush.com/prodde...at_Primer_GRAY
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 04-28-2024, 05:38 PM   #2
7D2N
7D2N's Avatar
Re: Spray Max 1K E-Coat Primer
That's what I used (gray color) over the bare metal areas before I started filler. It sprayed real well.
Just for the fun of it
7D2N is offline   Reply With Quote
Old 04-29-2024, 12:53 AM   #3
GSP7
GSP7's Avatar
Did you use the 1K stuff like in the picture?
I got the 1k so I do small areas and re use the can many times until its empty
I think the 2k rattle can stuff you have to spray the whole can at once or waste what is left in the can
2k would be more durable with the hardener . Not sure how durable the 1k non hardener is
Old 04-29-2024, 07:20 AM   #4
7D2N
7D2N's Avatar
I did use the 2k I think there is a 72 hour wndow to use. It dosent cover a lot of area. I used used 4 cans pretty fast.
Old 05-02-2024, 12:08 PM   #5
Grounded63
If you're using the 1k primer. You need to check the tech sheet for what you want to top coat it with. ( assuming your not just rattle canning it ). Most modern/current products. Will advise you against/not applying them over a 1k product.
Grounded63 is offline   Reply With Quote
