Old 04-28-2024, 07:32 PM   #1
AustinBelair
Rear shock crossmember same as 67-72?
Does anyone make a new rear shock crossmember as seen here? I can't use a tubular because the QA1 rear sway bar for their coil-over kit uses this crossmember to mount the sway bar mounts to it. This one is in pretty bad shape.
I see that the 67-72 looks really close to the 66 style.
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 04-29-2024, 09:56 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Rear shock crossmember same as 67-72?
It's the same from 63-72 on that part, I'm fairly certain.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-30-2024, 02:39 PM   #3
Getter-Done
Getter-Done's Avatar
Here is some dimensions that you can check to your crossmember.
Link: https://help.classicindustries.com/e...ons-of-t677207
84 Chevy K-20
Getter-Done is online now   Reply With Quote
