Old 04-30-2024, 04:15 PM   #1
pontiacvince
pontiacvince's Avatar
307 Stroker Anyone???
I want to add some grunt to my lil 307. I know I'm gonna catch hell for wanting to keep the same engine instead of swapping to some other engine, but that's what's gonna happen.
I want to add a 3.75" stroke crank from Summit and the 400 SBC 5.565" rods. This will make it a 360 (359) cubic inch. The only problem is the available pistons will be .070 out of the hole. I can get thicker head gaskets or mill my pistons.
Ready......GO!!!
pontiacvince is offline   Reply With Quote
Old 04-30-2024, 08:54 PM   #2
65truckowner
65truckowner's Avatar
Re: 307 Stroker Anyone???
I like different I say go for it
65truckowner is offline   Reply With Quote
Old 05-01-2024, 12:36 PM   #3
HO455
Post Whore
HO455's Avatar
Do it. Worst case you might have to get some custom pistons made. Have you figured out the static compression ratio? This one from Diamond pistons is my favorite. I've built several Pontiac strokers over the years. Figuring out all the details is enjoyable for me.
https://diamondracing.net/p-10-compr...alculator.html
RIP Bob Parks.
Old 05-01-2024, 12:55 PM   #4
Getter-Done
Getter-Done's Avatar
Sounds like Fun.
The (self proclaimed) Engine Guru's are going to have something to say about this.
84 Chevy K-20
Old 05-01-2024, 02:01 PM   #5
truckster
truckster's Avatar
I'm just curious what the benefit will be.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-01-2024, 02:40 PM   #6
350TacoZilla
Nothing wrong with hot rodding a overlooked engine like that since its still SBC and parts availability is huge (other than the odd bore piston deal) more cu.in with small bore should pair well with mild cam for low end torque, only thing you would be giving up over a larger bore like a 350 would be airflow around valves but that is mainly higher rpm problem anyhow.
350TacoZilla is offline   Reply With Quote
Old 05-01-2024, 04:02 PM   #7
pontiacvince
I just talked with a tech guy at Silv-O-Lite pistons and he said my .030 over pistons are .482 thick at the top. That's PLENTY to take .070 off.
My next call was to the machine shop. They can mill all 8 for about $150. My buddy owns a shop and he had a set of 5.5656" 400 rods I picked up.
The 307 (360) stroker is GONNA HAPPEN!!!
Old 05-01-2024, 04:50 PM   #8
Getter-Done
Is a Dyno test in the plans (that's if you have a source close to you) ?
84 Chevy K-20
Old 05-01-2024, 05:40 PM   #9
pontiacvince
Not sure where a dyno close to me is. I'm building it for more torque, not high rpm power.
Old 05-01-2024, 06:48 PM   #10
Ziegelsteinfaust
For pistons use Summit racing search engine.
If you know the bore you want to one that is feasible. You maybe able to get a piston with a different compression height to work that is commonly available.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-01-2024, 10:24 PM   #11
Getter-Done
I have not ever had the Need/Desire to want a Dyno readout.
With that be Typed
At the C10 Nationals at the Nashville Super Speedway in Lebanon,Tn
They had a Mobile Dyno Trailer.
It was Cool.
84 Chevy K-20
