Old 05-15-2024, 11:57 AM   #1
x1buellist
x1buellist's Avatar
Valve cover clearance
I am about ready to put the cab back on to my chassis. Anyone know if I will have a problem with clearance with these tall valve covers and the firewall? 66 with a sbc
x1buellist is offline   Reply With Quote
Old 05-15-2024, 04:20 PM   #2
sirJim
Re: Valve cover clearance
My 62 has no problem with clearance with tall valve covers on my small block.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 05-15-2024, 04:48 PM   #3
x1buellist
x1buellist's Avatar
Thanks, Didn't want to have 4 guys moving a cab onto the frame and finding out the cab hits the covers
Old 05-15-2024, 09:14 PM   #4
AcampoDave
AcampoDave's Avatar
Gonna be tight
AcampoDave is offline   Reply With Quote
Old 05-16-2024, 06:36 AM   #5
1restorick
1restorick's Avatar
I could not use tall valve covers on my 1963 Chevrolet C10. The passenger side hit the firewall. One factor could be that I have AFR Aluminum heads which have a 3/4" deck and are taller then a stock cylinder head. I would pull the covers for the cab install.
Rick
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 05-16-2024, 12:37 PM   #6
72Mountaineer
72Mountaineer's Avatar
Stock V8 motor mounts? HEI?
72Mountaineer is offline   Reply With Quote
Old 05-16-2024, 12:47 PM   #7
x1buellist
x1buellist's Avatar
yep, stock mounts with MSD dist.
Old 05-16-2024, 12:49 PM   #8
x1buellist
x1buellist's Avatar
Rick
Thanks, I will pull them off to be safe and go from there
Old 05-16-2024, 03:54 PM   #9
SkinnyG
SkinnyG's Avatar
Not that this makes a difference for your particular installation, but on my LS install, I made sure I could actually pull the heads off without having to pull the motor. I'd do the same in your case - just make sure it is actually "serviceable."
Do you have a build thread on here? I'd love to see it.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 05-21-2024, 12:08 PM   #10
x1buellist
x1buellist's Avatar
Good idea. Once I have the cab in place I will make sure I have enough clearance to pull it apart. I do have a build thread but am embarrassed about it. I started this build years ago and than let it sit. Now I have retired and am determined to get the truck completed.
