02-09-2004, 01:00 AM | #1 |
bag mounting on trailing arms
Have any of you guys mounted your bags offset on the trailing arms? I mounted mine haft way on or maybe a little less and made brackets but they twist a little bit. I plan on boxing them before I drive it. Has anyone else done this? Any help!
02-09-2004, 11:07 AM | #2 |
Trucker.
The ideal positioning of a bag on the link bar is to center it. If I were wanting to use a 2 link I'd center the bag, cove the frame for the upper mount and run a wishbone instead of a panhard bar.
02-09-2004, 12:13 PM | #3 |
Mine are centered. The arms aren't boxed & I've had no issues in over 3 yrs.
02-09-2004, 04:18 PM | #4 |
Progress = 0%
What was the reason for offsetting the bags?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
02-10-2004, 12:52 AM | #5 |
I offset them because I moved the bag postion up towards the front of the truck. I did a HUGE Notch to lay out on 295-40-20!
02-11-2004, 11:10 PM | #6 |
fully boxing the trailing arm is a bad idea, they are designed to twist going over off camber driveways etc.
maybe this pic will help. I run a 305-50-20 its a 32" tire. |
02-12-2004, 12:42 AM | #7 |
I am going to palte the sides but not the whole length. It twists where the bag mount is. If it doesnt work right I will mount them somewhere else.
02-12-2004, 12:19 PM | #8 |
MY EX DRIVES A BROOM
Wouldn't moving the bags further up on the trailing arms give you more lift as well?
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
