Old 11-22-2008, 01:21 PM   #1
71cadc10
71cadc10's Avatar
my '71 LWB project - carb'd 6.0L gen III etc
figured I should start one of these. Been 3 years since I brought the truck home...$500 for a roller w/o engine or trans. Bed sides were good, frame good, 12 bolt rear and one fender. Scrapped the rest pretty much. I can't find the pics right now of the truck when I towed it home.
Picked up a cab in TN off a board member, it was shot in the lowers and cab mounts...but the windshield channel and upper areas were decent. So I got a crash course in cab fixin' LOL.
Frame was stripped down and coated with Eastwood rust encapsulator.
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 11-22-2008, 01:24 PM   #2
71cadc10
71cadc10's Avatar
Re: my '71 LWB project - carb'd 6.0L gen III etc
general cab fixin pics.....
I did the driver side w/ sawzall and cutoff wheels....had enough and bought a plasma cutter. The other side went much smoother and then the bed too.
Working in my small 30x30 garage w/ plasma and a 110V Lincoln welder.
Old 11-22-2008, 01:27 PM   #3
71cadc10
71cadc10's Avatar
more cab fixin and windshield had 2 bad spots at the seam when I stripped it down.
Old 11-22-2008, 01:29 PM   #4
71cadc10
71cadc10's Avatar
rear end build....had a guy shorten the housing 1" and weld on 9" ford ends from Moser...stuffed it with an Eaton diff, 3.42 gears, Moser axles
truck will see some 1/4 mile action with drag radials or slicks...so I wanted the C clips gone.
Old 11-22-2008, 01:32 PM   #5
71cadc10
71cadc10's Avatar
fast forward to this summer / fall....pics of the cab welding done...epoxy primer on everything.
Old 11-22-2008, 01:34 PM   #6
71cadc10
71cadc10's Avatar
applied the 2004 GM quiksilver metallic with a cheap gun for the inside cab, firewall, and jambs.
test fitting the seats I'd like to use...2004 GTO buckets. comfy but tall back. Not sure yet if these will stay or something shorter.
Old 11-22-2008, 01:38 PM   #7
71cadc10
71cadc10's Avatar
front suspension is done...steering column disassembled, painted, and put in. using a wheel from a 73-87 for now. 2.5" drop spindles from ECE...stock disc brake setup. rear is dropped 4" with just springs.
Steering and brakes are done except realized I can't find the dust shields...need to find a set of those...now waiting for the motor. I'll post up motor pics in the next couple weeks....
Old 11-22-2008, 01:45 PM   #8
71cadc10
71cadc10's Avatar
Plan for the truck is Silver all over, with black accents..
Planning to keep the lower black trim and go with 18" black center wheel of some type. 30" tires to fill the wheel wells up.
Engine is a 2001 6.0L LQ4 core...+030 and stuffed with 10.5:1 forged pistons from Diamond, Z06 cam out of a 2004 vette, with 317 casting heads milled slightly and my port work (nothing major). Dual plane performer RPM intake, 750 vacuum secondary holley, MSD 6010 box. 150hp plate nitrous shot. Shooting for a 400rwhp package on motor, and 500+ on spray....might need more cam to get there we'll see.
Headers from a 98-02 Fbody, TH400 long tail trans and a one piece drive shaft.
Old 11-22-2008, 01:45 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What a great looking project!
Best of luck!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-24-2008, 11:39 PM   #10
71cadc10
71cadc10's Avatar
72BlckButy: thank you sir
Not much to report...I got windshield in and intake showed up in the mail. Waiting on the rest of the motor to finish machine work..won't be long!
Old 11-24-2008, 11:46 PM   #11
LEEVON
LEEVON's Avatar
Nice project. I love to see the carbed gen III's. Where'd you get the intake and msd 6010 and what did they set you back if you don't mind?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-24-2008, 11:47 PM   #12
nuke1
nuke1's Avatar
that is gonna be one sweet looking truck, love the motor combo you are goin with
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-25-2008, 09:17 AM   #13
71cadc10
71cadc10's Avatar
Leevon, thanks. The MSD6010 I picked up off LS1tech.com basically new in box but opened for $260 shipped. They don't pop up often.
The intake I was going to buy at Summit, but were on back order.
I checked at Advance Auto and got it there. Friend of mine works there and Nov. employees get 30% discount...so it cam out around $260 delivered. I was surprised.
nuke1 - thanks
Old 11-27-2008, 01:17 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice work so far cant wait to see her done..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-27-2008, 02:23 PM   #15
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Lookin' great man, good luck with the build.
STOCKISH is offline   Reply With Quote
Old 11-27-2008, 05:27 PM   #16
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Nice! That's what's planned for mine as well, a carb'd LS motor. I'm hoping to build a 427 off a LSX block but will use a LQ4 or LQ9 and build a 408 if funds are tight when I get to that point. Besides what all went on my "shop truck"...I just have an empty frame right now.
Do you plan on relocating the coils? Mast has a nice setup that puts them behind the valve covers, for that old school look.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-28-2008, 10:06 AM   #17
71cadc10
71cadc10's Avatar
68GMCCustom
yes I probably will relocate the coil packs....like to use the cast valve covers from GM performance with the "chevrolet" script on them. Those covers don't have provision for mounting coils.
I was in the air about the 408 as well...but the 4" cranks are still pretty steep for my budget on this one. In a few years when there's more of them on the market used I may pick one up. If the economy really tanks maybe people will start selling their LSx blocks cheap LOL.
Old 11-28-2008, 03:06 PM   #18
67_C-30
I have a radical idea!
67_C-30's Avatar
Is there an easy way to change a Gen III engine over to single coil with a MSD or similiar ignition box?
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-28-2008, 03:07 PM   #19
67_C-30
67_C-30's Avatar
Awesome truck BTW! The silver looks great!
My trucks
Old 11-28-2008, 04:05 PM   #20
68GMCCustom
I believe so...but it requires using GM's front mount dizzy option.
Kurt -
Old 11-28-2008, 07:10 PM   #21
67-72crazy
67-72crazy's Avatar
keep up the good work.
1991 1500 longbed: my daily driver
1937 chevy 2dr sedan. dads project
67-72crazy is offline   Reply With Quote
Old 11-28-2008, 07:20 PM   #22
msgross
msgross's Avatar
watching this one... hopefully I can get to see this in action around town...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-29-2008, 07:34 PM   #23
OARNGESI
OARNGESI's Avatar
Looking really good really like the seats
OARNGESI is offline   Reply With Quote
Old 11-30-2008, 11:48 PM   #24
71cadc10
71cadc10's Avatar
thanks for the comments guys.
67 C30...
The MSD 6010 box is a standalone unit that will fire the stock coil packs.. It's a little over $300. The front cover shown uses an adapter to the front of the cam, and a Ford distributor. The cover and adapter alone are like $450. In my opinion the best option is the 6010 box and the stock coils.
Old 04-10-2009, 10:25 AM   #25
71cadc10
71cadc10's Avatar
been way too long for an update....I'm lazy, it was cold this winter...blah blah. Last month I been getting it going again....
Ported a set of 317 heads, lightly...just a clean up really.
LH8 oil pan from a Hummer, worked out real nicely. Engine is 10.8:1 with Diamond +030 pistons.
Z06 cam from a 2002 covette
