Storing chassis for slow build
Looking at a long slow build. Have the frame, going to do all new brakes etc. It will take me probably 5 years before final assembly. How do you guys store your chassis for long periods without the brakes rusting? I live in Michigan with temp and humidity swings. I don't have a heated building or a dehumidifier the size of a house.
I'm looking at stainless lines, possibly silicone fluid as truck will sit for a considerable portion of the time. Heavy 3/4 ton 4wd so rotors and hubs are $$$ and I'd rather not have to replace them bu once.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
![]() Join Date: Jan 2011
Re: Storing chassis for slow build
Have you thought about changing the order of the build? Maybe do all the metal work first then the Chassis.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Moderator
![]() ![]() Join Date: Aug 2011
Wipe em down with corrosionX.
You can shoot them with cheap spray paint and use acetone and a rag later to wipe it off. As long as the brakes are smooth you shouldn't need to do any real work removing it.
Ive seen people use masking tape with pretty good effect as well.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
use a nice grease or heavy sticky oil over it that is why these are really oily new from the store
My other understanding silicone fluid does not mix well with dot3
If everything is new no issues |
I'm thinking leave the brakes off and in box until you are ready to bolt them on for good. If you need the chassis rolling just make a dolly for the front and rear axles so you can move it around as needed.
On my 68 C10 project I did the frame first. Sand blasted and epoxy primer. With the frame bare I stood up against my shop wall so it took up almost no room. Rear axle and front suspension cleaned and primed same thing. When I was ready after about 18 months I bought all brake stuff so it had no chance of rusting. Good luck with your project. |
