Wood Bed Varnish...Pics please
So I am getting ready to do my wood bed in my 68 lwb. Most likely going with Oak. I have heard many different things on varnish and stains. Can I get some recommendations and pics to back them up. Greatly appreciated.
-mgf- 1968 Chevy LWB.
Lowered. 15x7 rallies and BFG's. Built 350. Dual Flowmasters. Fast and Loud. |
Re: Wood Bed Varnish...Pics please
I researched it before I did mine too, and if you want a natural wood look, it's gonna take some maintenance. I haven't found anything that will hold up in the weather. I ended up using stain and 6 coats of Helmsman spar urethane on my white oak. I've had the truck together for about 6 months, and it already has some cracks in the coating, and a couple of splits in the wood. I think it was Mar-k that did a couple of tests on various products. You should be able to find it on their site.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
#3 | |
Did you not do any bed to frame bolts? Bed looks sweet and clean without them. Did you secure it some other way?
#4 | |
Nice Thread. My 2-cents. Wood is not like the metal our trucks are made of. It has tends to expand and contract with every change in the weather. (I also do some serious woodworking when not playing with the trucks.) So no matter what you put on it, it will eventually crack. You need to seal all 6-surfaces with the same product, top-bottom-sides-ends. A minium of 3-coats is required here. And while more is usually better, you are only deepening the shine and not adding any further protection to the wood with the addition of more coats. Now all that being said, I used the same automotive clear coat on the wood in the bed of one of my trucks as I did on the truck. Spraying the clear allows you to put down more product, and also it will dry quicker than using another methods. I would highly suggest 3-coats and then letting it dry overnight. Then a final sanding the next day with the addition of a final coat. This usually leaves a glass smooth finish.
Thanks, MrBlue
MrBlue 72' C-10 350 TKO-600 Current Project 54' Ford F-100 Life Long Project |
Saving 1 truck at a time!
I don't know...some just like it stock!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 04-17-2010 at 08:31 PM. |
#7 | |
I wonder if I can put that over urethane.
Bruce Horkey sells a complete finish kit. sandpaper, stain, brushes, varnish, etc.
http://www.horkeyswoodandparts.com/ I used it and was extremely happy with the results. |
How about a Plastic Wood Grain Composite of some kind? UV is always a problem but a good Bed Cover can eliminate that. Al W.
See previous discussion
http://67-72chevytrucks.com/vboard/s...d.php?t=391890
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
drove to home depot one night and bought some oak plywood and red oak stain. used the poly clear i already had, including hardware i probably have $200 in it all.
whoever thought of "i live my life a quater mile at a time"-vin diesel needs to be ***** slapped. i would have a pretty short life ![]() |
good thread...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
I wanna see MOAR!!!
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
#15 |
McCloskey's Man-o-war spar varnish - satin. Four brushed coats per side with light sanding between coats.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#16 |
polyurethane 7 coats and buffed but has a truck cover to protect.
#17 |
Hey everyone,
Thanks so much for the advice. I bought the SS Strips last saturday from a local shop, Dan's Classic Auto Parts, so no shipping ![]() Been pricing hardware now. Have bolt count and sizes thanks to Dan's. Actually seems cheaper just to order the kit from one of the resto companies such as Classic Parts or LMC. Then just have to get the wood. The kits are pretty expensive + shipping. Probably gonna do the wood myself since my buddy has a full wood shop and after getting him the diagrams and dimensions he says it should be a piece of cake. Finding out that lumber is a lot more expensive than I would have thought.
#18 |
I will have to dig out some pictures of my bedfloor but here are the basics. Cabinet grade white oak stained with a heritage oak, pecan mix to get the darker color. I followed instructions from my father-in-law who installed bowling alley lanes for many years. I sanded everything smooth, then used a high quality polyurathane clear gloss. Then the poly was dry to the touch (dries from outside in) following his instructions, I hit the clear with a buffer. According to him this causes the fibers of the poly to cross link and makes them very hard and bond tighter. I then wet sanded the finish allowed the surface to dry and followed using the same method for six coats. Buffing between each time. I did top and sides in this fashion (several day process) and then I mixed tung oil and poly together for the bottom. The oil actually drew the poly into the wood and increased the weight of each board quite a bit. This mixture got very hard and seemed to pentrate very,very well. The truck has been finished for 8 years, and there are no signs of cracks weathering spliting or other associated problems. I did allow the wood to climatize for a couple of weeks prior to any work.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
#19 |
Has anyone used Hemlock for the wood bed. Pine is cheap and affordable, but worried about longevity. Oak looks sweet and is durable, but is rather expensive. I found some real nice looking Hemlock at Lowes. It is about in the middle for price of pine and oak.
Thanks.
