03-09-2012, 03:23 PM | #1 |
Going to test the straight6 claims.
Ok so here is the deal. I have grown up hearing the claims from my dad, grampa, and other "older gentlemen" that you can build a straight 6 that will "walk all over" mild V8's. So my thought it, lets build one and see what it does. I have built my 350 to be a rather potent little street block, so I think I might be knowlegable enough to take this on.
Take a 250 inline 6 and built it to be as nasty as possible within an everyday budget, like it used to be done. I do understand that nothing costs the same as it used to, so I am accounting for that. I am sure I can find the block or even the whole motor, my question is what am I looking for as far as the best one to build. The Truck block or the car block? And from there what are some tips, ideas and advise that everyone here has for me. I am not worried about fuel mileage or everyday street ability as it will go into the light rolling chassis I can find, and be backed up with a TH350 or TH400. So far I know, offy 4bbl intake split longtube headers? max bored shave head to increase comp upgrade cam.lifters.sprins.and push rods what else??? Thanks
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
03-09-2012, 03:31 PM | #2 |
Real Projects never die
Re: Going to test the straight6 claims.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
03-09-2012, 03:52 PM | #3 |
ummm really just because i had always heard of the 250 and ford 300. it will be wichever is easiest to find. I know my loval pick and pull has atleast 6 of them sitting in the yard in trucks and some in cars. Just have to find one that is worth buying.
what is the physical diffrence between the two? what do I need to look for?
03-09-2012, 04:16 PM | #4 |
was just over at clifford, most likely going to go with the 1,200 for the mani/carb/header kit.
If i cant find a better set up go with the 272 cam and lifter hit aswell.
03-09-2012, 04:59 PM | #5 |
paper or plastic?
looking forward to this.......
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
03-09-2012, 05:18 PM | #6 |
It's Better With Nitro
X2...will be keeping an eye on this thread. In the early '80s, I bracket raced my 250 L6 relentlessly. I ran my ported 194 cylinder head that Sissell helped me set up. I would also build out a 250 as opposed to the 292. It's a little more difficult to get into the upper RPMs with the 292.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
03-09-2012, 06:57 PM | #7 |
250's are a dime a dozen here in central TX. I can get one already rebuilt with the split headers for 600.
rather build my own tho. and I had a 250 in my nova in highschool and i beat on that motor for a year and it never gave up. Anyone know were I can get new pistons in over bore sizes from?
03-09-2012, 10:22 PM | #8 |
mini truck racer
Used to be a 68 Camaro bracket car down hear called the buzzin-half-dozen . Had a 250 and th350 . Really consistant ran like 14.10's
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
03-10-2012, 12:45 AM | #9 |
I had a real nice 292 short block that included a steel crank, gas ported forged pistons, aluminum rods and main studs. I didn't have any use for it, so I sold it to this guy that runs www.12bolt.com
He said that my shortblock was designed for a head that was actually 3 small block chevy heads cut up and welded back together, pretty trick stuff. He builds turbo engines and all kids of neat things.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
03-10-2012, 01:45 AM | #10 |
mini truck racer
The guy that runs the local hydraulic shop has an anglis with a 292 in it . Had it since the 60's
03-10-2012, 01:42 PM | #11 |
as of right now I am scouting for a solid block, I am going to go with a 250 as from looking around it is the one with the most options and aftermarket parts available.
I really am looking forward to ripping it up with a 6 instead of my sbc.
03-10-2012, 08:45 PM | #12 |
Back when I was in high school a guy had a chevy II that he street raced with an inline 6 and it was pretty hard to beat.
Another guy in town had a t bucket with a 6 that would pull the front wheels off the ground when he launched it on the street!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-15-2012, 08:05 AM | #13 |
First, if you are serious, you need to buy Santucci's book, be sure to get the second edition. You are better off starting with the 292, that 40+ CID really helps, just stay out of the harmonics. Takes the same intake and exhaust and head, allows better carb selection.
Next, define your budget. Six parts are not 'cheap'. 1. Rebuild short block - cheap, use sealed power 307 pistons, mild upgrade cam, good timing set, new oil pump, turn crank, etc. About $1200 inclusing machine shop. 1a. Use forged pistons and upgraded rods, add Fludidampr, studs, align bore - add $800 2. Rebuild stock head - $250 2+. Swap to 194 head for better compression - $300 2a. 250/292 head but Increase valve size, lump ports (read the book), screw in rocker stands, roller rockers - add $5-600 depending on how much you do yourself 3. Intake and exhaust - Clifford manifold, Holley 390, Langdon's headers, electric fuel pump, custom exhaust - $800 So for about $3300 you can have a 292 that makes gobs of torque and will give a stock SBC a bad time. now let's get serious. T4 SPA turbo manifold, turbo, HP head gasket, methanol injection, intercooler, blow thru carb, boost adjusted FPR, custom exhaust and BOV -$2000 So can you make 400 HP with a turbo, carb, and some tweaks? yes. Will it be as cheap as a 383 Chevy? no. EFI $1500 (megasquirt, port fuel log, controlled timing, knock sensor) Hybrid head based on LS or big flow SBC, lay back cylinder bore walls, BIG cam, etc - $5000 is depending on what/how. Now you're pushing 550+ HP, up there with some stout SBC's, but you're close to the limit of a six. If I wanted to beat up on SBC's I'd pick up a 5.3 LS motor (under $1200 with harness), add a chip, and you'll pund 305's and STOCK 350's, and give mild 350's a good run. When I have time to be truely different I'll finish my 250 and swap it for the tired one in the 77 and cruise in an ungly old truck that I fit in. But it's not likely to win many races. The LS motors are just too good, my 1999 3/4 ton xcab weighs 5400 dry and is much quicker than my 1990 454 SS was.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
03-15-2012, 02:38 PM | #14 |
D13- Damn good info and the prices you are quoteing are near spot on. i was budgeting for about 3500. This is really going to be a long term build so it will be pieces by piece. Also it will be going into something along the lines of a chevette/pacer/p**to, small and RWD.
I am going LS with the truck hopefully next year after the body is in final primer and sealed.
03-15-2012, 04:09 PM | #15 |
Just build a Cummins, thats a 6 and can make 1000hp. lol
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently. http://67-72chevytrucks.com/vboard/s...d.php?t=451950 1971 c10 step 250 3 OTT 1969 c30 TOW-MATER. 307 4 speed, holmes 440 body. http://67-72chevytrucks.com/vboard/s...d.php?t=451082 2006 CTS-V LS2 6spd. |
03-15-2012, 04:29 PM | #16 |
haha naw i dont like the smell of diesel
03-15-2012, 10:31 PM | #17 |
check inliners.com for there forum. There are a few turbo cars in brazil with 250 and turbos that go fast, like 8 seconds fast!
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
10-10-2012, 04:45 PM | #18 |
Any updates here?
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
10-12-2012, 04:41 PM | #19 |
Champagne Taste on Beer Budget
Yeah I'd like to know as well.
Sounds like this would be very cool to have a hot lil' 6 banger!
Coming Soon: Project 1970 Country Truck |
10-12-2012, 06:31 PM | #20 |
Yeah, I've got a 250 in mine and I have Santucci's book, was thinking of doing this myself, not sure yet though.
OKLAHOMA MEMBER MEET JUNE 15, MIDWEST CITY OK.http://67-72chevytrucks.com/vboard/s...d.php?t=559886 72 C-20 Stepside - Work In Progress |
01-23-2013, 10:05 AM | #21 |
Updates?
Car Craft did a feature some time ago about a guy who took a blue oval 300 6, slapped a turbo on it from an old dumptruck or something and was running 10 second 1/4 miles in a Maverick on a pretty cheap budget. Obviously that car is lighter than a truck but if the enemy can do it why can't Chevy guys do it with a 250 or 292? |
10-22-2015, 04:39 PM | #22 |
My 64 has the 292 in it. I'd like to know the options as well.
I'm leaning towards a big block, but this 292 has 22,000 documented miles on it. Was installed in 1980. Stock bore WAR engine. |
