12-14-2010, 10:15 PM | #1 |
LS1/LS2 Conversion with 4x4
I am planning on converting my 72 blazer to either an LS1 or LS2 engine but I am finding no threads on doing this and keeping it 4x4. What do you do with the transfer case,etc. Can anyone guide me in the right direction with transmission and transfer case answers. thanks!
12-15-2010, 10:56 AM | #2 |
Re: LS1/LS2 Conversion with 4x4
My buddy runs a LS2 in his 72. He is allways swapping Auto to Manual and back...depends on what he is using the truck for..Pismo he uses the Auto and rock crawling he uses the manual.
THey are kinda far from you but pacificfab.net in Morgan Hill CA has all the knowledge you need for the swap. Or Google LS2 K5...? .02c good luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
12-17-2010, 04:34 PM | #3 |
Boosted Member
Might be able to swap a ford or dodge D44 axle under the front so that the late model TC case drop lines up with the pig on the front axle?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
12-17-2010, 05:21 PM | #4 |
You dont do anything if you dont want to. My boss link his LS1 to his already stout 350/np205 combo. Someone makes an engine Xmember that he used, and crossover steering.
12-17-2010, 10:07 PM | #5 |
I am building mine right now i used ls1 with 4l80 and the stock np205 i had to use a advanced adapter to join the tranny with the np205
04-02-2011, 02:22 AM | #6 |
Collector of Projects
Did you start with a 4x2 or 4x4 4L80e transmission?
12-18-2010, 03:07 AM | #7 |
That is incredibly helpful. Thanks!
03-31-2011, 05:04 PM | #8 |
what Crossmember was used to put the LS-1 in? I have had a hard time trying to find a 4 wheel application for the LS-1 in a 4 wheel drive.
Any advice will be great
Build Thread, |
03-31-2011, 10:53 PM | #9 |
looks amazing
05-04-2011, 04:13 AM | #10 |
novak trans adapters has what you need to run a numerous selection of auto and manual transmissions. http://www.novak-adapt.com/ , I am also thinking of doing the swap with an ls1 out of a c5. i want a good all around truck, I have an SM420 4 speed in it that I could make work but dont know if it will hold up you familiar with that trans ?
05-04-2011, 06:52 AM | #11 |
From all I can see on Novaks web site is stuff for Jeep conversion. Have you actually found something for the LS1 into a chevy truck/Blazer the look to have mounts and crossmembers for the LS1 but the applications are for a jeep? Let me know if you could I appreciate it.
Build Thread, |
05-08-2011, 07:22 PM | #12 |
Check out advanceadapters.com
Posted via Mobile Device |
05-08-2011, 09:20 PM | #13 |
LS1 is the same as a 5.3, 6.0 etc they are all vortec engines and hook up the smae mechanically. check out my blazers thread in my signature should help u out
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 |
05-08-2011, 09:37 PM | #14 |
Has more rust than truck...
More info in my sig.
05-09-2011, 09:38 AM | #15 |
Are there any problems with mud/water splashing all over these motors and the wiring?
That is the only real concern I have about running one of these.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
05-11-2011, 10:19 AM | #16 |
No problems with water. All the wiring connectors are weather pack. Mount the ECU high and dry under the dash and build a breather box that aquires air from a high/dry point (like a snorkle) and you can submerge the whole thing if necessary LOL.
Check out my build thread.
1970 Datsun 240Z 1972 K5 Blazer Highlander 1972 Chevelle 1959 Apache 3100 SWB Fleetside 2006 VTX 1800f Build thread: http://67-72chevytrucks.com/vboard/s...ght=highlander |
