6 lug to 5 lug adapters on 23" wheels on porterbuilt suspension
Hey guys,
looking to start building my 66 c-10. Have a set of Giovanna 23" 5 lug 120mm rims laying around the garage. Thought process here is to use these rims with the build till I swap them year or two down the road. (trying to save a few bucks now). About to order my kit from Nate at porterbuilt he would take 1.5" out of the arms. The offset on the 23" rims is 6" plus 1.9"-2" for the 6 lug to 5 lug adapters ?? Just looking to cover my basis here, in-case you guys forsee a problem i don't. Look forward to some in-sight.. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 6 lug to 5 lug adapters on 23" wheels on porterbuilt suspension
Forget the 6-to-5 adapter.
They are very scary looking as far as adapters go. They have to be a 2-piece adapter since 1 hole in both lug patterns overlaps. Use 6-lug rotors and 6 lug rear axles. You are spending lots of money to get QUALITY parts from Porterbuilt,... don't screw it up with adapters. I'd rather run 15" steel wheels with hubcaps before I tried to use an ill fitting wheel and installation process. (my opinion)
#3 | |
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
Happy to be here
![]() Join Date: Mar 2000
Welcome to the forum laynrockers. I have to agree with these guys. If it were me, I would sell the wheels you have and buy what you want with the correct pattern and backspace. Its really not an economical advantage to spend time, and money just to install a set of wheel you don't really want.
Guys,
I appreciate the advice. Tempting looking at those wheels everyday I started to look for a way to use them. |
#6 | |
Happy to be here
I would hit one of the Full Size GM boards and see if they will sell. Then you can afford new wheels with the correct pattern and backspace....win/win... ![]()
Yeah i have not seen any good come from adapters,I seen them where the lugs worked loose and just spun in the hole even a few that failed that's never pretty.
I agree.Also having those pretty PB arms shortened may screw you u down the road.Your truck tho,post pics and specs if you do go through with it.
You could probably get a decent buck on those rims by selling them... why not just sell them and pick out a nice set of six lug that you'll stick with? Just my 2 cents
Collector of Projects
Welcome from Vegas...
Why are you taking 1.5" out of the arms? Is it for the rims you may not keep? Don't make the suspension fit the rims you will not be using in the end.... I agree with the others, get some cheap rims that fit without adapters. It may not be the perfect look now, but it will be safer and save probably save you money in the long run.... |
#11 | |
#12 | |
Happy to be here
#13 | |
We need some more pics of the Orange and White truck!
Appreciate the heads up, def wont be considering adapters ever again. Been looking for wheels, problem is the ones i like arn't cheap. Attached pics of the two projects.
#16 |
Yes, but some steelies on it, sell the 23s and enjoy life
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#17 |
Check out COYS C-5 or C-55 for a less expensive option.... the website is having a sale right now too...
http://coyswheel.com/index2.html ![]() |
#18 | |
The price is so tempting. Who else that you guys are aware of make wheels similar the the above?? Thanks for the tip! Last edited by laynrockers; 03-22-2012 at 07:47 PM. |
#19 | |
needs more $$$
http://www.bossmotorsports.com/wheel...d=1920&cat=466
1970 2wd Blazer |
#20 |
What are wrong with Wheel adapters!!! I put a set of High Quality 2PC 6 to 5 Lug Adapts on my 68 and Never had a problem, even spaced my wheel out 2" to make my Cragars fit better. Dont let these guys "Scare" you to death, $130- took 45 Min. Done, wheels went on and I went driving down the road, I almost forgot I had them on there.
#21 | |
Happy to be here
Combine all of that with the fitment issues the OP was facing, and it was not a practical choice for him.
#22 |
What it cost for good adapters you can buy new rims almost.The garage i use to work for wouldn't work on anything that had adapters or thick spacers on it for legal reasons.Ever since i bought a wheelrite i never had to worry if my math is right if a wheel and tire will fit.If you don't know what a wheelrite is its a tool that lets you test first any rim and tire combo http://www.summitracing.com/parts/PHP-01201
#23 |
Just seem goofy to take some off the arms and run spacers for temporary rims that as most will be changed sooner or later, then what?. Just sell them don't compromise, get what you want the first time. So one with spacers will want them,
#24 |
welcome from a fellow vegas board member, if you need any help let me know.
-mike |
#25 |
Well like always, I learned a few things during this process. Turned out with the Disc brake conversion I am running the fronts don't need to be modified and will fit perfect. The rear axles I had a machine shop convert for $170 and will pick up tomorrow.
I am gonna use the 23"s for now cause to be honest there great rims and new tires later on down the road i am leaning towards the boss 338's. Thanks fellas. ![]() |
