Old 06-29-2007, 01:39 AM   #1
va_tlc
va_tlc's Avatar
couldnt wait.....
well i was off work today so...... i started on the front springs around 12 noon i guess round 2 hrs i had the front in... heres a pic of the front
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 06-29-2007, 01:45 AM   #2
va_tlc
va_tlc's Avatar
Re: couldnt wait.....
after the front i was gonna call it quits ,,, then a buddy showed up and says... well lets finish this thing so the back went pretty good and quick with 2 people still need to get it outside and measure by the looks inside the shop its still sits higher in the rear, i took out the stock rear blocks, but i belive it is higher cause of the new spring perches we welded on they was around 1 inch taller than factory, sooo i guess im gonna add a spring in the front ,,, i dont really like the looks unless they sit level
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 01:48 AM   #3
va_tlc
va_tlc's Avatar
in this pic youll see that under the front spring hanger theres a welded bracket of some sort, well the passenger side doesnt have one, is this a factory bracket or yall think someone made it?
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 01:49 AM   #4
va_tlc
va_tlc's Avatar
whoops the pic shows the side without the bracket sorry
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 01:55 AM   #5
earl87gta
earl87gta's Avatar
Yap factory with them but most the time there cut off you dont see them on all the trucks.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 06-29-2007, 07:55 AM   #6
Looks as good as I figured.Couldn`t wait?I can`t wait till you roll it out a sanp us some pictures.
Old 06-29-2007, 08:05 AM   #7
va_tlc
va_tlc's Avatar
thanks earl.. the front of the spring is actually touching that brace i guess if it sqeaks it wont hurt if i cut it off huh?
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 08:08 AM   #8
va_tlc
va_tlc's Avatar
yea tim, i may have to roll it out im gonna have to get the wife to watch me back it out my door is rite at 7 ft..... i belive itll come out w/o hittin the roof. may have to let the air out thou. gotta put the rear shocks on yet.wasnt a bad job since i had alreay had all the u bolts out b4,
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 09:46 AM   #9
Yukon Jack
Yukon Jack's Avatar
I can't wait to see that outside - lift looks great to me.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-29-2007, 10:35 AM   #10
1969k10stepside
It's looking great!
1969k10stepside is offline   Reply With Quote
Old 06-29-2007, 11:09 AM   #11
sdailey
The Few, The Proud
sdailey's Avatar
Looks good.
What lift did you use and how high? Also what size tire and wheel?
sdailey is offline   Reply With Quote
Old 06-29-2007, 12:00 PM   #12
earl87gta
earl87gta's Avatar
Now you just need to get it out side so we can see some more pics. It looks great from here but we need a few more full truck pics. It almost looks like its to high to get out of the door in the pic.
Earl
Old 06-29-2007, 03:26 PM   #13
va_tlc
va_tlc's Avatar
finally got the rear shocks on an cleaned up the shop this a.m, rechecked all the bolts an pulled the rear wheels off cause i forgot to paint the hubs, then took it for a test drive down the lane, rode pretty good i belive a bit better than before, let my wife take it a spin she had some trouble with the gears at first , then vroom she was off, by the looks of her smile i just lost my truck!!! well heres some outside pics, like i said before i belive its up in the back cause of the new perches, can yall tell it bad? and what would yall do to fix? add leaves to the front? or cut the perches down some? ohh and it came out the door but i had a spotter just in case,
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 03:30 PM   #14
1969k10stepside
I think it looks great! I like when they slope down a little in the front,but that's just me.A leaf added in the front might help.Did you use the perches off the old eaton or the ones on the 14 bolt? The ones from the eaton might bring it down a tad bit in the back.Seeing your 4wd lifted makes me want to down grade the lift,and put on some skinnier and smaller tires!
Old 06-29-2007, 03:32 PM   #15
va_tlc
va_tlc's Avatar
sdailey.. its a rough country 4 inch lift with there shocks too. tires are bfg 33x12.50x 16.5... around 160 each, wheels are mickey thompson classics11. 9.75x16.5 i belive around 125 each.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 03:34 PM   #16
va_tlc
va_tlc's Avatar
.. yall tired of pictures yet? lol i love looking at pics cant wait till i have enough time off to get to a nice spot for some good pics and background
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 03:45 PM   #17
va_tlc
va_tlc's Avatar
..last one for now, hope ya enjoy i belive i am, but im kinda upset since i did this truck azzbackwards as in my inital plans was no lift at all, so i had bought new stock shocks, that i had to take off, took my origanal wheels and tires i had bought luckily they just swapped me for the diffrence, and the front spring bushings i had the guy who set up my front gears , he put the bushings in, then 1 week later i take the springs out then the rear end i had the h0 52 i belive with 4.55 gears, i put new wheel cylinders and brakes on that, and changed the gear oil in it, then found the 14 bolt ff and of course brakes were diffrent and wheel cylinder difrent, so had to do all that to the 14 bolt.... now i have 3.73 both ends, its drivable now
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 03:51 PM   #18
sdailey
The Few, The Proud
sdailey's Avatar
VA_TLC
Thanks for the info. That's the look I'm going for with my '69 as far as lift and tires go. I just got to find time(and $$$$) to start on it.
Old 06-29-2007, 03:55 PM   #19
1969k10stepside
Would you mind measuring from the ground to the bottom of the bumpers front and rear on the truck now that it's lifted? I want to see how much,if any higher mine sits than yours now..your truck looks like its sitting pretty close to mine,and I like the way yours looks bettter!
Old 06-29-2007, 04:04 PM   #20
va_tlc
va_tlc's Avatar
sdailey man thats a pretty truck you have there did you justbuy that or have you had it awhile, that truck will look great lifted, dustin ill walk out in the shop rite now and get the measurements man,, hold ya horses lol
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 04:16 PM   #21
va_tlc
va_tlc's Avatar
dustin measuring from the shop floor to the bottom of the rear bumber it is 36 inches front is 34 inches, as far as the spring perches i bought new ones from summit they were steel, the ones from the eaton was cast. and the summits are deffinitly taller, man these tires ride alot better than the sport kings i had bought first....
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 04:19 PM   #22
sdailey
The Few, The Proud
sdailey's Avatar
I just bought it about 3 weeks ago.
Old 06-29-2007, 04:20 PM   #23
va_tlc
va_tlc's Avatar
sdaily the whole lift was umm 386 shipping and all, that gives you everything you need, if your gonna do it i would deff go start spraying some penerating oil on all ya shock bolts and u bolts, if the u bolts are to tuff to get off just grind em off, cause the kit comes with longer u bolts anyways
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 04:23 PM   #24
va_tlc
va_tlc's Avatar
im nosy what does a nice truck like that bring down there? if youd rather not say i understand too, does it have 3/4 ton axels? kinda looks like it in the pics? thanks and was it a original 4x4 swb? thanks
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 06-29-2007, 04:27 PM   #25
sdailey
The Few, The Proud
sdailey's Avatar
VA_TLC
Sent you a pm.
Shannon
