Old 10-12-2008, 10:53 PM   #1
tk-mpl
tk-mpl's Avatar
Rear bag mounting pics please
I am in the middle of putting in a rear c-notch, cpp trailing arm crossmember and redoning my rear air bag setup. The PO put in really small bags and some really messy blocks/brackets..
My first question is how are you guys mounting your air bags?? When you put in the c-notch are you taking out the rear spring upper plate. Are you mounting the bag to the trailing arm with just one bolt up through the trailing arm.. If you got any pics I would like to see them..
Second I was wondering what bags you guys are running. I was going to get the Doninators, but wasn't sure if they were to big for the front and rear.
Thanx.
Trevor
tk-mpl is offline   Reply With Quote
Old 10-12-2008, 11:18 PM   #2
draggin86
draggin86's Avatar
Re: Rear bag mounting pics please
here is my 86 with f9000
draggin86 is offline   Reply With Quote
Old 10-12-2008, 11:34 PM   #3
tk-mpl
tk-mpl's Avatar
Wow, that is alittle out of my league. I am just putting a c-notch and cpp crossmember.
But, is that ever nice...
Old 10-13-2008, 12:44 AM   #4
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
here is what I've got...
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 10-13-2008, 01:21 AM   #5
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
Mine on my '72 burb
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 10-13-2008, 09:47 PM   #6
tk-mpl
tk-mpl's Avatar
Got the c-notch finshed off today... Should of taken some pics, but everybody has see it before..
Old 10-13-2008, 11:15 PM   #7
smashingchuck
I must say that it is refreshing to see people running the correct bag on the rear in this thread.
78 Build Thread
4Runner Build
Old 10-14-2008, 10:40 AM   #8
blazer2007
what would the wrong bag be,I,m going to do mine here soon ,would like to know
blazer2007 is offline   Reply With Quote
Old 10-14-2008, 11:38 AM   #9
leftcoast66
leftcoast66's Avatar
I'm guessing a dual convoluted bag. Sleeve bags are better for this application, atleast with ride quality in that mounting area. Besides that, I don't know...
leftcoast66 is offline   Reply With Quote
Old 10-14-2008, 11:40 AM   #10
RunninLo
RunninLo's Avatar
well every bag pictured here so far is a F9000 "sleeve" bag. The double convolute bag aka firestone 2600lb, Slam specialties RE-7 RE-8, etc. are also popular in rear aplications but many feel they are not ideal. Neither bag is "wrong" just suitable for different apps.
Josh
88 4x4 crew DD
Old 10-14-2008, 02:54 PM   #11
stunna
Man u guys have some beautiful rear suspensions!! Its just like art or something. My suspension will not be as elaborate but i can appreciate your work, AWESOME!!
stunna is offline   Reply With Quote
Old 10-14-2008, 03:46 PM   #12
tk-mpl
tk-mpl's Avatar
Ya, I wish I had to time and $$$ for something like that. But I will just have to keep it simple. I have a hard time getting the simple stuff done. 20 min. here and 20 min. there just ain't cutting it..
Old 10-14-2008, 04:30 PM   #13
leftcoast66
Josh
Mk, that's what I thought. Wasn't sure w/ how sure the other poster was about how it was wrong. Thanks for clearin it up.
Old 10-14-2008, 06:19 PM   #14
Slammed67
Progress = 0%
Slammed67's Avatar
Is this what you are looking for? I have a single bolt through the trailing arm. The upper bags studs go through the notch and frame. The studs were barely long enough to go through the frame and notch (only a couple of threads showing). Not that they are going to fall out, but I'd like to know what others are doing to remedy this situation. My thought was to remove the notch and enlarge the holes in the frame (large enough for a socket the size of the nut to fit through). Then bolt the notch back on, put the nuts on the studs and tighten them down. Then the bag would actually be bolted to the notch only. Make sense?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 10-14-2008, 06:47 PM   #15
SCOTI
SCOTI's Avatar
Flip the bag or swap to Slams .
Since you already have the Stones, they can be inverted vs. the way you have them installed. This allows for the use of a bolt that gets the correct amount of thread engagement through the c-notch + frame + reinforcement plate. For the trailing arms, 'clock' the bag so the studs straddle the C/L of the trailing arms 2-halves. Drill 3/8" holes for the studs & the larger 1/2" hole for the air fitting. Route the airline so it's not contacting anything & call it done.
I had them installed this way in my 68 because of the same issue w/there barely being enough thread to secure the studs through the frame & notch.
Slams use bolts on top & bottom so they're more user friendly on these trucks. I'm not sure what newer Stones use these days either.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-14-2008, 08:39 PM   #16
tk-mpl
tk-mpl's Avatar
Slammed67, that is exactly the kind of pic I was looking for and I too had the same questions about the studs on the top.
What do you guys think of the Dominators for installing??
Anybody got more pics to help a rookie out..
Old 10-14-2008, 09:05 PM   #17
DrtyJack75
What's with all the bolts? Just making stronger or is there another reason Im not seeing??
Mine on my '72 burb
Josh
DrtyJack75 is offline   Reply With Quote
Old 10-14-2008, 09:24 PM   #18
SCOTI
SCOTI's Avatar
That's Porterbuilts bolt-in rear 'Dropmember'.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2008, 09:30 PM   #19
TylerHuff
TylerHuff's Avatar
slammed67 could you post up some more pics of your setup im also needing some pics
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
Old 10-14-2008, 11:08 PM   #20
gringoloco
A guy with a truck
gringoloco's Avatar
This would work well, I think. You could also use a bolt-in style bag like a Slam or Dominator. Scoti's idea would work if you don't wanna buy new bags, I'd just be a little leery of air line routing...
I have the Domintors on my pick-up. Night and day difference in ride vs. Slams and no problems so far. I'd say the Slams are more of a sporty feeling bag vs. the Doms that are more plush. Check out MrShelley's FAQ for good pics on rear bag installs.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-15-2008, 12:24 AM   #21
tk-mpl
tk-mpl's Avatar
Thanx, I found the air bag install in the FAQ's. I saved most of the pics for future ref.
I think I am going to go with the Doninators.
Old 10-15-2008, 09:01 AM   #22
Slammed67
Progress = 0%
Slammed67's Avatar
What specifically do you need pictures of?
Old 10-15-2008, 09:27 AM   #23
TylerHuff
TylerHuff's Avatar
how your frame is notched, how low it sits in the back, and what you had to do to leave the stock trailing arms, or did you just pull the coil and put an air bag in there
1987 Gmc sierra
1962 Apache 10
Old 10-15-2008, 09:38 AM   #24
Slammed67
Progress = 0%
Slammed67's Avatar
I'm in KC so if you'd like to come by and check it out in person, let me know. You can e-mail me at jason (at) jayspot (dot) com.
Old 10-15-2008, 09:44 AM   #25
SCOTI
SCOTI's Avatar
What's the diff between the 'Dominators' & Stones?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
