Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-06-2008, 01:19 AM   #26
k5kev
New Member
Re: Project: 1972 502 HO 4x4 Suburban
Originally Posted by LEEVON View Post
Better fill that puppy up while gas prices are low Love the build!
I know what you mean! Heck, by the time I get this thing on the road gas could be $10 bucks a gallon!
k5kev is offline   Reply With Quote
Old 12-06-2008, 01:22 AM   #27
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Cool, and the upside is, that tank is a good ways forward, so if you should go through the very unfortunate experience of being ass ended, there is a much smaller chance of bursting into flames.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 12-06-2008, 01:31 AM   #28
k5kev
New Member
Originally Posted by nuke1 View Post
looking real nice and clean, job well done so far, what rims and tires do you plan on running?
Thanks for the complements and ecouragement.
I guess I'm kinda going with a semi-stock/resto-mod/sleeper look. Just drivetrain upgrades and mild lift. Also going with a stock interior,....3 rows of bench seats,....stock door panels etc. So with that in mind I'm leaning towards some stock steel wheels and chrome 3/4-1 ton hup caps, along with some Goodyear MTR's,.... 33's or 35's. Not sure if this thing is going to fit thru my 7' garage with 35's and a 4" lift, so that'll determine the tire size. Can't be leaving this baby parked outside with all that's invested.
Old 12-06-2008, 11:15 AM   #29
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice job job far..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-09-2008, 08:31 PM   #30
k5kev
New Member
So finding a set of headers was a serious challenge,...BBC in a 4x4 frame with a SBC crossmemeber. GM Performance Parts tells you to use 2" primary and 3" collector headers for the 502HO. Not to many header companies make 2" primary headers, and I definately didn't want to choke down the motor with some 1-3/4", which everbody makes. I think just Hedman and Hooker make 2" BBC headers. I ended up going with Hedman. It still wasn't simple, I tried 4 or 5 different sets, and the only way I was able to make it work was by combining 2 sets. I used a 67 chevelle driver side and a 72 Chevy 2wd truck for the passenger side. Since Hedman sells a drivers side only for the 67 Chevelle, so I only actually paid for a set and a half of headers. I still also had to do some grinding to the frame to squeeze them in, and I shortened (cut and re-welded the flange) the driver side collector by about 4",...it was too long and too close to the trans crossmember,...not enought room to bend the exhaust pipe over the transfer case.
Old 12-09-2008, 08:46 PM   #31
k5kev
New Member
After the headers it was time for exhaust. I'm going with dual 3" aluminized pipe. Its a universal set you can get from Flowmaster, it has two pieces of every bend,..22-1/2, 45, 90, straight, etc. I also went with a pair of stainless steel Magnaflow mufflers. I cut and welded the pipe up,..and around the transfer case,...pretty tight fit!,..nice not having the body on! Going to dump em out in front of the rear tires. Also going try and paint the aluminumized pipe with VHT ceramic heat paint in the future. Not sure if a h-pipe is going to work out yet,..gotta fit up the drive shaft and see.
Old 12-09-2008, 09:21 PM   #32
msgross
msgross's Avatar
looks nice, any trick to welding that aluminized pipe?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-10-2008, 11:58 AM   #33
k5kev
New Member
Thanks......If there are any tricks I don't know them! I'm not really a welder, I just pretend to be one in my garage.
I used a 120 volt Hobart 140 with shielded .030 wire, and #2 setting. The pieces that slip fit together welded up easy. the pieces that just butted together were tough, I kept blowing holes, but finally got it. If I had it to do over it I'd go with .024 wire, gas, and the lowest setting (#1). I tried welding the shielded .030 wire at the lowest setting but it wouldn't burn/melt.
Old 12-10-2008, 12:24 PM   #34
k5kev
New Member
Next up for the build was a GM Performance Parts serpentine system. IMO this is the way to go when starting from scratch on a big block swap. I looked into trying to find all the original v-belt brackets, pulleys, etc. But it probably would have cost me more than the GM kit ($700) when you add it all up, not to mention the time searching this board, ebay, etc. This is a slick kit! Everything bolted right up with the exception of a couple of bolts that were the wrong size. No big deal just picked up a couple new ones from the hardware store.
Old 12-10-2008, 12:29 PM   #35
k5kev
New Member
....then I bolted up the core support, new 4 core radiator and shroud.
Old 12-10-2008, 01:27 PM   #36
k5kev
New Member
.....and the rest of the motor dressings,
Holley offroad carb, 770 cfm
Summit Racing HEI distributor
Holley air filter
some K & N breathers
Summit upper and lower radiator hoses.
I took this stuff off before towing the chassis to the painter.
Now you are all up to date on the progress of the chassis.
I'm just waiting (and waiting, and waiting!) to get it all back from the painter so I can continue the build.
Old 12-11-2008, 10:28 AM   #37
Number98
Prestige Worldwide
Number98's Avatar
Lookin good!
She is coming along now...
Number98 is offline   Reply With Quote
Old 12-16-2008, 09:51 PM   #38
Yukon Jack
Yukon Jack's Avatar
What an outstanding project. Gonna be a killer Burb!!!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-11-2009, 04:46 PM   #39
Sir Fisher
Sir Fisher's Avatar
big blocks are awesome!! very nice!!
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 06-14-2009, 11:07 AM   #40
k5kev
New Member
While my paint & body man is still taking his time, I'm scrounging up the rest of the parts to finish the Burb. I picked up a set of 16x7 Ford steel wheels off ebay and had them powdercoated semi-gloss black. Have also got a set of 3/4 ton hubcaps, which I'm going to have restored soon.
Old 06-27-2009, 12:56 PM   #41
Yukon Jack
Yukon Jack's Avatar
I feel for you with the painter delay - that can sure test a guy's patience!
Old 06-27-2009, 06:31 PM   #42
msgross
msgross's Avatar
Do you leave those vertical bands on the new radiator? I have a similar radiator is why I ask.
The Garage:
Old 07-01-2009, 10:12 AM   #43
k5kev
New Member
I cut them off. I'm fairly certain you're supposed to. On some of my pics if you see a line there its because they (radiator supplier) painted it with the straps on.
My Body Man tells me both driver and passenger rockers/floors are cut and welded in. I gotta get down there and get some new pics. With any luck he may be blocking and sanding,..maybe even spraying a little blue on the interior (ya, right!?). We'll see.
Old 08-02-2009, 02:33 PM   #44
k5kev
New Member
I got the hubcaps restored at Hubcaps.com. $65 each. I'm very happy with the results. What do you guys think?
Old 08-02-2009, 05:42 PM   #45
msgross
msgross's Avatar
nice, I didn't know they restored...
SOmeone else had a set of those polished at a metal shop and they looked chrome..
The Garage:
Old 08-04-2009, 03:34 PM   #46
70rs/ss
70rs/ss's Avatar
Holy sickness!! You are building my Burb, well like mine, but I opted to stick w/the 2wd chasis. I put my rear axle under the trailing arms and I am going to use a DIY4x set up for the front leaves (will eventually do a coil sprung front as well to match the coil sprung rear w/trailing arms!) Other than that I am leaning towards a BBC 496-505 but the old school way, stoked and poked! Sweet build and man did you start with a sweet Burb!
We need more picts!!
70rs/ss is offline   Reply With Quote
Old 08-05-2009, 09:45 AM   #47
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
nice burb build!
i would like to build one someday.
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 08-05-2009, 10:02 AM   #48
barthmonster
subscribed. Awesome build ! Looks like the color is close to my Dad's Blazer ('79). Can't wait to see it done !!!
barthmonster is offline   Reply With Quote
Old 08-05-2009, 11:06 AM   #49
lyrikz
PITbut
lyrikz's Avatar
In for updates. Cool rig.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 08-18-2009, 10:57 AM   #50
k5kev
New Member
Working on getting the 3 rows of seats done now. Had all the frames sandblasted and powdercoated. Then I bought some 1/8" masonite from Home Depot and used the old cardboard seat backing for a pattern to trace onto the masonite. I then used some tie-wire to attach the masonite. Turned out great.
I went ahead and had the front seat covered. I'm very happy with the upholstery guy that was recommended to me so I think I'll drop off the back seats soon.
[img]
