Old 12-31-2008, 09:03 PM   #376
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: My 1965 build thread
Block Party
Everyone's invited.
JK
Ya'll would be interested until I told you what you needed to bring,......sanding blocks
I don't like days like today. I spend 7-8 hours sanding, sanding, and more sanding. I did get the dash ready for primer. I'm trying to get the cab ready to prime the final time. I had forgotten about all of the little spots that needed attention. Since the dash took so long. Seam seal still needs to be finished. These pictures are about as boring as this post.
Happy New Year everyone!!
Digging the old seam seal out (sand blaster doesn't get it). Repairing pits from deep surface rust.
Ready for sealer
The dash is ready for primer.
Alan's Classic is offline   Reply With Quote
Old 12-31-2008, 09:22 PM   #377
sdailey
The Few, The Proud
sdailey's Avatar
Looking good Alan. I've got a cab you can practice your skills on when you're ready.
Shannon
sdailey is offline   Reply With Quote
Old 12-31-2008, 09:22 PM   #378
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Shoot I forgot to have ypou practice on my truck while you were here
lookin good!
Old 12-31-2008, 09:28 PM   #379
Alan's Classic
lookin good!
Sand paper doesn't work good in 15 degree weather and neither do I
Old 12-31-2008, 09:31 PM   #380
Alan's Classic
You might want to learn some on mine, so you can handle yours when the time comes..
Old 01-02-2009, 10:16 PM   #381
tiggamonsta
tiggamonsta's Avatar
Alan, the photos are not boring at all. Those of us that cannot get to our projects for whatever reason, really enjoy seeing the progress you are making. Even if it does not feel like much to you. Keep the updates coming.
tiggamonsta is offline   Reply With Quote
Old 01-03-2009, 01:49 AM   #382
Alan's Classic
Thanks Tiggamonsta
I couldn't get off of my arse today, still enjoying the vacation. My motivation came at about 10pm. I got a little done just to uncover that there is alot to do before I can sling some paint.
I've been debating to myself........Should I block this opening up. For some stupid reason I think it would be a good cold air intake. More than likely I would never do it. I think I'm trying to find excusses not to do it. I'm thinking of just painting the block off plate.
Located another fuel door with filler neck off of a F**d Ranger.
Driver door still lumpy. Going to spray slicksand on it. I believe it will fill enough so it can be blocked out then primed.
Blocked on the roof and discovered a butt print. Slicksand might cure that problem as well.
Old 01-03-2009, 02:52 AM   #383
Captainfab
60-66 Nut
If you aren't likely to use it, IMHO it would look better welded up and finished rather than just painting the block off plate. You've done an outstanding job this far, it would just not fit the look of the rest of the truck with the block off plate. Just my .02
Old 01-03-2009, 03:04 AM   #384
joe231
joe231's Avatar
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-03-2009, 06:28 AM   #385
jonzcustomshop
1961 crewcab
I'll throw it the other way...
cold air intake like on the chev z11 would be cool.
Old 01-03-2009, 10:38 AM   #386
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I was just thinking about that motor.....Yeap, that would be an awesome idea to run it as a cold-air intake.
I would defiantely consider it....plus you would keep the cowl free of leaves and crap !!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-03-2009, 02:09 PM   #387
tiggamonsta
I am on the Cold Air Intake side of the fence. It would be a nice feature to add.
Old 01-03-2009, 02:18 PM   #388
4dranch
Shloooooong bed member #2
4dranch's Avatar
Alan,
I am in agreement with Captainfab. But honestly with your skills you could make either work, and make it turn out nice.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 01-03-2009, 08:37 PM   #389
SCOTI
SCOTI's Avatar
Gets my vote too (that & some pocket change nets you some pocket change ).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-03-2009, 08:50 PM   #390
scotts62
One day...
scotts62's Avatar
Thats a cool idea how they use it as an intake! I like it
Scott
93 crew cab build
Project 62
Old 01-04-2009, 12:38 AM   #391
Alan's Classic
Thanks Jon for helping me realize my vision. We need to change your name to the "Picture vault". You have some of the most unique pix. That 2nd pic is a 409 Impala, right? Do you know the year? I guess a 64.
Now does anyone have an air cleaner like that laying around.
Thanks to everyone else for their input. I'm so confussed. I like the cold air intake idea, but afraid it will take away from a nice and clean engine bay. If done right it might add to the appeal. I've never seen one done to this style truck. I'm sure Jon might have a pic.
The roof, LT door and dash got some Slick Sand sprayed on them
Old 01-04-2009, 12:50 AM   #392
joe231
joe231's Avatar
wow
that slick sand looks cool
CHEVY ONLY
Old 01-04-2009, 01:13 AM   #393
Alan's Classic
I was told by a painter that it's not a primer. The label says it doesn't need to be sealed prior to topcoat. It's like a sprayable filler to remove minor imperfections. Once I block it I will prime then block with 400. It's cheaper than primer and metal glaze. It applies evenly minimizing sanding. It is thick and requires a 2.0 gun tip. It can be thinned a little like I had to do tonight due to being 55 degrees.
Old 01-04-2009, 01:29 AM   #394
joe231
joe231's Avatar
wow that is cool!
thanks for sharing!
CHEVY ONLY
Old 01-04-2009, 01:39 AM   #395
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
looks great!
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
Old 01-04-2009, 02:05 AM   #396
olsofti
olsofti's Avatar
Thanks for the pic of the can.I was wondering what to ask for.
Can't wait to see the after pics.
olsofti is offline   Reply With Quote
Old 01-04-2009, 01:35 PM   #397
Inverter
Inverter's Avatar
Beautiful work man. Love the frame color.Is that oem or the color you chose.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 01-04-2009, 02:17 PM   #398
SCOTI
SCOTI's Avatar
Originally Posted by Alan's Classic View Post
....That 2nd pic is a 409 Impala, right? Do you know the year? I guess a 64.
You won't want an original pre-69 cowl induction air cleaner. . .... they're freakin' outrageously expensive. I've seen the 'common' units (big block Chevelles) listed on the auction type venues for $3K...... used! The aftermarket units made aren't cheap either @ $1500+ .
I think a better option would be one of the NASCAR 'used parts' places. You should be able to pick up a used NASCAR style air cleaner shroud & adapt it to your firewall (NASCAR cars get their cool air from the firewall/base of the windshield). They're made from both aluminum & carbon fiber & usually go for less than $150.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-04-2009, 04:50 PM   #399
Alan's Classic
This is only the second time I have used Slick sand. So far I love it.
Thanks. The frame color is a 2008 honda color. I posted the paintcode somewhere in my build thread.
Thanks for the info. I will contact the old ARCA race team I used to work on to see if they have any old ones laying around.
This should be entertaining to ya'll. Let me know if you find it informational. I'm a little camera shy.
Old 01-04-2009, 05:06 PM   #400
Inverter
Inverter's Avatar
Got it,Thanks. PPG 301274.
Video is cool.Dont be shy,,,you have amazing skills some would kill for.That should boost your confidence.
TROY
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
