Old 02-12-2009, 09:57 AM   #1
Huck
Huck's Avatar
Cool 99+up common problems
Ok let's list them---
1- Steering column vibration mostly noticed going slow --off road or in parking ---the column intermediate shaft is fluted with grease taking up the shock---it gets squeezed out. There is a factory bulletin to either repack or to "stroke!" the unit---what a BS fix this is but it works for a while.
2- Windshield noise pass side---from a bug shield changing the air flow!! Tape, caulk windshield to molding or take of the bug shield.
3- Premature front brake wear---factory bulletin for "northern states!!" ie the antilock sensor looses it's ground path due to salt-rust getting under it's mount to the spindal housing. factory bulletin recall---get them to replace the pads if you can.
4- Brake drag noise from the drivers side rear---the parking brake "horse shoe" unit is dragging on the drum and wearing out. Factory bulletin replaces the spring holder and possibly the horse shoe assembly but only on manual shift trucks!!!! how is that for another BS fix from GM?
OK guys, add some more as these trucks are full of BS GM issues~~~~
5-
Huck is offline   Reply With Quote
Old 02-12-2009, 09:17 PM   #2
silverado84355
silverado84355's Avatar
Re: 99+up common problems
Fuel gauge (sending unit)
Speedometer
Water pumps
Front bumper brackets cracking out
Im sure theres more....
silverado84355 is offline   Reply With Quote
Old 02-12-2009, 11:53 PM   #3
rddiaz
rddiaz's Avatar
loose driver seat...
factory security system...
leaking from somewhere and I can"t find out where from!..
GROUND ZERO IS R LIMIT
rddiaz is offline   Reply With Quote
Old 02-12-2009, 11:54 PM   #4
truckdude239
truckdude239's Avatar
rear mains leaking
i've seen them at work with 3k mile ont eh trucks with rearmains leaking
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-13-2009, 03:34 AM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
4x4 dash switch
CSK
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-13-2009, 05:37 PM   #6
66truckin
I had an 07 sierra classic and it was flawless for the 17k miles I had it. It was too big for the wife to drive so we traded it off on a car.
66truckin is offline   Reply With Quote
Old 02-13-2009, 07:28 PM   #7
Huck
Huck's Avatar
Forgot about the stupid faulty 4x4 switch.
The tow-haul switch in the shift stalk fails due to inadequate wiring into the column.
And the worst---and I have had 3 99+ trucks=5.3V8s and every one had the engine ratteling within the first 30k miles--sounds really bad in the cold butttt---they do run forever! Strong engines but one would think they could fix the stupid ratteling~~~.
Old 02-13-2009, 09:10 PM   #8
danno74
danno74's Avatar
hvac blend door servo motor.....
danno74 is offline   Reply With Quote
Old 02-14-2009, 01:34 AM   #9
67ChevyRedneck
I've fixed the tow haul switch on mine. Easy fix. I need a new 4x4 switch. Just haven't changed it. It has a slight CSK but Mobil One just about kills it and it's not noticable in spring/summer/fall. I've put over 50K on my truck, had 66K when I got it, it has new tires (last set lasted 40K+) and new Bilsteins, still has the factory pads and rotors, but need to be replaced soon.
I'd buy another one of these trucks in a heartbeat.
Jesse James
Project "On a Dime"
Old 02-14-2009, 08:06 PM   #10
kevinr1970
Explain this a little more please.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-17-2009, 02:05 PM   #11
Slammed67
Progress = 0%
Slammed67's Avatar
Based on my truck....
  • Gauge cluster power supply went out.
  • Replaced fuel pressure regulator.
  • A few of the radio/climate control button lights are out.
  • Sticking accelerator pedal caused by dirty throttle body.
  • Rain leaking into driver's side of cab. Ended up being the seal around the cab vent on the back of the cab.
  • Driveline vibration, usually felt at low RPMs under load.
  • Leaking water pump (or seal) that I need to fix.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 02-18-2009, 09:29 PM   #12
Huck
Huck's Avatar
My 99 had a coolent leak somewhere in the back--couldn't find it but did put some radiator stop leak into the system @ 140,000 miles. Sold it without a leak @ 188,000 miles.
Oh yea, there is that issue of cold air coming into the pass floor heater --that coating the foam rubber seal around the air box is supposed to fix---.
I certainly would not pay $25,000. plus for another new chevy truck. Especially when they wouldn't even sell you one with a 5 or 6 speed manual!!!! They can go chapter 11.
Old 02-21-2009, 09:11 PM   #13
So far the only one I have noticed on my 02 is the steering column clunk. But I have the el cheapo model, so no fancy stuff on it to break. Seems like all the GMs have the clunk since about 2000 year. Mine wife's Bonneville had the same issue.
Old 02-25-2009, 11:06 AM   #14
mr._bowtie
mr._bowtie's Avatar
This is the only problem Ive seen on my 04. Other then that its VERY solid. My dad had a 02 and never had any trouble with it... put 110k on it. Did have the "bug shield" noise after installing a bug shield, but I wouldnt call that a problem lol. Now he has a new style 07 and no issues with it either.
Never heard of any chevy truck with bad rear mains... or water pumps.
2004 Chevy 2500HD Duramax
1978 K5 Chevy Blazer (in process of tranny and floor pans)
1970 C10 LWB (Rat Rod Project)
Those are the only vehicles that fit in here lol
mr._bowtie is offline   Reply With Quote
Old 02-25-2009, 08:51 PM   #15
kevinr1970
Can you explain what the symptoms of your problem was/were? And what the solution was??
On my '06 it seems I have been having a beech of a time regulating the temperature; if I have it at, say, 3/4 the way up and it I push the switch down slightly, after a few minutes it starts blowing cold. This is still way up in the red (hot) area of the control.
If I then nudge it up ever so slightly, after a few minutes it is cooking me out again???
2000 Tahoe Limited
Old 02-26-2009, 09:21 AM   #16
Houston54
The flap that directs the air flow to either the defrost vents/dash vents or floor vents is controlled by a servo which goes out. Happened on my 03 Z71 but the dealer covered it. I believe they mentioned it would have cost me about $250 to repair.
Other problems are the fuel pump. If you have trouble getting the engine to start when you have less than a 1/4 tank of gas it is a symptom of the fuel pump darn close to giving up the ghost.
Found a whole bunch of mud and debris in the gas tank when it was dropped to replace the pump.
The dashboard ABS light and parking brake light coming on and staying on with no codes is also a common problem.
From my own experience regarding electrical issues I would check all the ground connections especially the one on the top rear passenger side of the engine block.
Houston54 is offline   Reply With Quote
Old 02-26-2009, 03:02 PM   #17
D13
D13's Avatar
2 pc driveshaft failure/vib at low miles.
General rattles
Window regulators
water pump
#7 injector plugging
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-26-2009, 09:07 PM   #18
kookykrispy
The Early Chevy Van Man
Mine had the common problem of the odometer/drive position indication going dark... intermittent problem. I found a guy on ebay who sells the repair service for $100 + shipping. I'm currently driving around with no gauges at all because he is fixing them and will send them back soon. He has 100% positive feedback and instrument clusters is all he does it seems. I've got my fingers crossed!
Also:
-Problem with power windows only go to the right, but not left or up or down. I replaced the switch, but that was not the problem... so now what? I'm not sure.
-The driver's door seal is noisy. It lets the wind in at speed. On my list to replace the seal.
-The rear passenger side pop-out window no longer closes properly. Very noisy above 45-50 mph. Very annoying. I understand there is a fix for this by putting a sheetmetal screw through the hinge into the metal of the body.
-Rattle from the glovebox latch
-Rattle from the center console above the CD player.
-Keyless entry is 'lazy' you need to press the button on the key fob multiple times to get it to unlock... this is with a brand new battery in the fob.
-Seatbelts are twisted up and I don't know how to untwist them.
All minor issues... other than that its a great truck and I got a pretty good deal on it. I like the 6.0 engine and 4L80e trans. Its got alot of power and I also like the lines of the silverado bodystyle. Its spacious and very comfortable inside. For a 3/4 ton, it rides alot better than my old f250. I have the LT package with power heated leather seats and they are not loose and work great. I have only owned it for a couple months. It has 111k on it.
64 Chevy Van
65 GMC Handi-Van
99 2500 silverado 4x4 ext cab
kookykrispy is offline   Reply With Quote
Old 03-02-2009, 09:46 PM   #19
TDs6t9
TDs6t9's Avatar
Huck, On your cold air coming in, how did you say you fixed it? We just did a trip and my wife really felt a draft on that side. I did too for that matter when she was driving. Is it an easy fix? Thanks in advance..
TDs6t9 is offline   Reply With Quote
Old 03-03-2009, 10:21 PM   #20
cheyenne402
Piston slap especially on cold start--I bought the truck from my Dad--who bought it brand new
2000 Chevy 2500HD 4x4 6.0 litre
He took it to dealer, they said "it is normal"--GREAT
cheyenne402 is offline   Reply With Quote
Old 03-10-2009, 01:52 PM   #21
463
463's Avatar
99% of the time the cabin air filters (2 of them) are very dirty and need to be replaced. the fan is on the up stream side and forces air thought them. when the filter is dirty the air bypass (due to the plastic and the seals letting the cool outside air into the inside on the pass foot well area. replace the 2 filters and you will haved fixed the cold air issue.
Trueman
463 is offline   Reply With Quote
Old 03-10-2009, 02:10 PM   #22
Riveted1
Tasty Cakes!
Riveted1's Avatar
My '99 too!
My ABS module died a long time ago. I just pulled the fuse meaning to fix it, but it's been like 4 years now LOL.
Fuel pressure reg died.
And I think the water pump gasket is leaking. These trucks are notorious for that one.
Not bad considering I drive it like my momma stole it and I don't do much more than change the fluids in it. And it's almost got 100k of 98% stoplight to stoplight driving!
(Of course, now that I said something she will die.)
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 03-22-2009, 06:12 PM   #23
Joe67
67 is sold
5-
1) is not a common problem
2) is not a problem, this is caused by aftermarket parts.
3) The problem is not premature brake wear, the problem is the faulty ABS sensor. My OEM brakes lasted over 60K miles.
4) this is not a common issue
4x4 dash switch, Ext Cab doors and fuel sending unit failure were a problem on 1999-2000 trucks, was resolved after that.
Rear end gears did wipe out prematurely (60K or so). this was also resolved on later models.
Pistion slap/cold start knock has NEVER shown to produce damage, there are many 200K mile plus 1999+ vortec trucks out there without issues.
The rest of these sound like basic problems, not rampant throughout the trucks sold and on the road
My 2000 5.3l GMC has 198K on the clock and is damn near flawless
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-22-2009, 06:44 PM   #24
jamie72
jamie72's Avatar
1# is a common prolbem my wife`s avy is havin that prolbem now. do a web search its all over the net..
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 03-22-2009, 09:03 PM   #25
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Here is my list….
1) Water pump gasket leaks. Most often misdiagnosed as a $300 leaking water pump rather than $10 gaskets.
2) Engine mount failures. The Pre-2006 trucks as susceptible to the rubber portion of the engine mount to get over heated by the exhaust manifold and the rubber collapses or crumble then fall out. GM has a new engine mount with a heat shield to protect against the heat from the exhaust manifold. The new part number is 25828247. Both LH and RH mounts are the same part number.
Failed original mount on left and new design on right.
3) Steering column clunk from the upper intermediate shaft. The original GM bulletin advised to pack it with grease. That was a short time fix that didn’t last very long. GM has had a new design upper intermediate shaft available since early 2008. Part number 19153614
4) The electric shift 4wd system sucks period and is the most unreliable system on the entire truck. Control head failures are the most common failure but the encoder motor on the side of the transfercase is also susceptible to salt water intrusion, which will eventually lead to a failure. The transfer case control module doesn’t have the best track record in reliability either. The AutoTrac transfercase in the non-HD trucks also has a habit of burning clutches. These issues and components are all common with Dodge trucks as well being all this crap is from the same suppliers.
I worked at the GM Technical Assistance in Troy, MI then later Pontiac, MI during the beginning of my automotive industry career before moving to the field. The rotation group I was in received at the time (1998) received call after call on electric shift issues on all GM trucks across the board. The S-series trucks and blazers were the worst! I went out of my way to purchase a manual shift transfercase on my ’98 Z71 and later my ’01 HD. I had no choice on the Hoe as NP8 (AutoCrap) is standard. My new used 2005 HD also has a manual shift tcase.
DirtyLarry is offline   Reply With Quote
