Old 03-21-2009, 05:23 AM   #76
Jvsapp
Jvsapp's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
whooo hoooo out of the bandwidth doghouse..... time for some more corn. i was putting my nova build pics up and my brother in law was saying my pics are nice. i had to show him yours and he was blown away with the tahoe and the minx.
Jvsapp is offline   Reply With Quote
Old 03-22-2009, 12:07 AM   #77
justcuz
justcuz's Avatar
You will not believe this, I drive by one of these every week or so. It is tan with a maroon roof and is a Hillman Minx. Looks almost identical to your body.
Nobody in a million years would consider the swap you are doing. Great work! That is going to be very cool as a finished project. My talent would have restricted me to a little Ford or GM V6, upgrade the rear axle and hope for the best with the front end. You are in a league of your own, my hat is off to you. That rear axle is equivalent to putting a 14 bolt in your Tahoe, it will never break.
justcuz is offline   Reply With Quote
Old 03-23-2009, 11:30 AM   #78
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Nice car, Fry!
Thanks for postin pix from your hard drive!
Joey~AP is offline   Reply With Quote
Old 03-24-2009, 11:09 AM   #79
Frizzle Fry
Frizzle Fry's Avatar
Snatch that thing up man! I agree the rear is plently, even riding on the edge of overkill... But I'll have no worries about laying into it off the line
There's pics of a V6 conversion on the yahoo hillman group right now. Looks like a full chassis swap.
Frizzle Fry is offline   Reply With Quote
Old 03-25-2009, 08:44 AM   #80
OLDIRON69
This is gonna be one killer ride!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 03-26-2009, 08:17 PM   #81
Frizzle Fry
Been trying to finish up the 4-link. I get an hour here, an hour there these days. I was able to tac three of the four housing brackets with the rear in place/centered/at ride height. But the last one is lapping on to the housing because it's so far off-center (the housing). So I decided it would be much easier to do that one out on stands since it involves trimming/fitting etc. I realize that welding on the cast pumpkin is not ideal, but I have achieved good results in the past by gringing the area clean and pre-heating it prior to welding. As can be seen in the pics below the left bracket will be welded to the tube and the housing. I will then add gussets on the tube side.
Old 03-26-2009, 10:17 PM   #82
Jvsapp
Jvsapp's Avatar
WOW that is some offset. i 'm guessing the shortness of the housing and width of the car doesn't help. i feel you with the hour here, hour there work. that's how my swap is going now, but i'm hitting it all day tomorrow. still it's awesome work, keep us posted. i love the CORN
Old 03-27-2009, 12:12 AM   #83
Frizzle Fry
You can see how offset it is in this pic. The pinion is actually not too bad though.
Old 03-27-2009, 01:42 AM   #84
Jvsapp
Jvsapp's Avatar
kinna makes you think about using a 8.8 out of a mustang or a 7.5 from a G body so you can have the mounting ears. but then again i think the Dana 44 is sweet.
Old 03-27-2009, 08:05 AM   #85
OLDIRON69
How hard is it to determine the angles on the 4 link set up? I have a Mopar I want to do the same thing on I just wouldn't know where to start.
05 2500HD 6.0 excab
Old 03-27-2009, 04:17 PM   #86
Frizzle Fry
It's an Art Morrison kit. The instructions call out all the specs that they have developed. I can attatch it if you want to see it.
Old 03-27-2009, 04:27 PM   #87
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Mike,
The whole project is Looking Sweet!!
I'm going to have to come see it in person soon. Maybe I need to talk you into helping me with the finish welding on Project 50th..
Drew
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 03-27-2009, 08:46 PM   #88
Frizzle Fry
Originally Posted by Twisted78SS View Post
Mike,
Drew
Sounds great Drew! I'd like to see that project of yours. Could be dangerous though, I already have a weakness for Blazers...
Old 03-27-2009, 10:41 PM   #89
Frizzle Fry
I've attached the tri 4-bar instructions. Let me just say that Art Morrison is top quality all around. They don't just sell stuff to take your money either. They didn't want to sell me the kit until we were sure it could be made to work for my application. That means installing it with the correct lengths and angles. I will certainly be a returning customer.
Old 03-27-2009, 11:05 PM   #90
BlueJeep
BlueJeep's Avatar
Welding to the cast like that won't be a problem on a dana axle, I've done it a hundred times. If it were a GM corporate axle, I wouldn't say the same thing (different cast). Pre-heat and grind it good like you have mentioned, and the only thing I might suggest is find a buddy with a big 220 MIG to weld it on.
Looks great!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 03-28-2009, 12:34 AM   #91
Rokcrln
Rokcrln's Avatar
It sure is nice to find a company like that these days. This car is turning out great.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-28-2009, 03:49 AM   #92
ERASER5
ERASER5's Avatar
I know you are using the Honda S2000 rotors on the D-44, but what calipers and what mounting plates are you going to use? Also,how many bolts do the retainers use?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-28-2009, 04:14 AM   #93
Jvsapp
Jvsapp's Avatar
that 4 link is giving me ideas for my morris build. it's probably the same width as your minx....
Old 03-28-2009, 02:58 PM   #94
Frizzle Fry
Kevin
LFD Inc.
It sure is.
I will make my own brackets to adapt the S2000 calipers. The theme here is to use as many mechanical parts from one donor as possible. That way future maintenance will be simplified and the huge selection of aftermarket upgrades are a simple bolt-on affair. I'll have to check the retainer bolt count.
Be sure to post a build thread when you do!
Old 03-28-2009, 03:50 PM   #95
Jvsapp
Jvsapp's Avatar
I will make my own brackets to adapt the S2000 calipers. The theme here is to use as many mechanical parts from one donor as possible. That way future maintenance will be simplified and the huge selection aftermarket upgrades are a simple bolt-on affair. I'll have to check the retainer bolt count.
that is the key, totally. with my project 20V swap i already have that problem. motor was only made in japan and Australia so i had to order a replacement timing belt from Australia before i get the motor in.
and yes once i start the morris i will be posting pics.
Old 04-08-2009, 12:43 PM   #96
justcuz
justcuz's Avatar
I would have a hard time fitting in it! At 6'1" and 250 I would look like a whale in a sardine can! Besides I have too many other projects right now. I still dream a lot but have learned to tell myself no.
Old 04-08-2009, 08:36 PM   #97
Frizzle Fry
I'm 6'2" but weigh less. It's not roomy but I'm comfortable in it. It's good to excercise some will power on the project acumulation. Maybe I can take some lessons from you? This one is the last "addition" before I start working back through mine (minx, tahoe, then 61).
No updates recently. Work, school, kids, etc... But I hope to get out there tomorrow!
Old 04-12-2009, 01:09 AM   #98
skchevota
skchevota's Avatar
Wow, cool project! when I was a kid, we had A sunbeam wagon. I think it was a 66 as well. My Great uncle was a Dealer in Los Gatos CA. I used to love to go work in his shop as a kid. He always had an Alpine or Tiger in his shop to give me a ride in. I would love to find one in as good as shape as yours some day.... awsome job.
skchevota is offline   Reply With Quote
Old 04-12-2009, 10:52 AM   #99
justcuz
justcuz's Avatar
You do not want to take lessons from me. 3 suburbans, 3 pickups, 4 chevelles and a 96 Impala SS.
Old 04-23-2009, 01:54 AM   #100
Sub-versive
Boss Hogg
Sub-versive's Avatar
? Progress pics???
Love this project.
Sub-versive is offline   Reply With Quote
