#26 |
Re: Project "Nympho"
A lil update on the truck, drove it around today! I've done a ton of work...I will update with pics and descriptions when I'm not in class..lol...later..also, I'm picking up my bed this weekend!
#27 |
Under Construction
sounds like you have made some good progress. get those pics loaded when you can...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#28 |
Ok so here's my official update....
I had a hard time finding a driveshaft to fit and didn't want to pay 300 for a new one, so I finally found one that would fit with a long tail (mine is short tail turbo 350). My neighbor gave me a long tail so I installed it...long story short...it didn't work! So I reinstalled my short tail, moved the motor back two inches(PITA-requires new holes to be drilled for mounts) and finally a match. After that was done a played with it a little-drove it around the block and did some burnouts! This past weekend I drove to the Texoma area and picked up a bed..I did an even trade with a guy for a cab that I purchased for another build. I brought the bed home and realized that it wouldn't align very well so last night I cut the rails off the rear notch, set the bed where I wanted it to be and rewelded the rails in the correct position...needless to say it has been a handfull. The truck is making real progress though and should see some road time this summer-at least the road between me and the body shop! |
#29 |
Soon to come...I bought a york 210 off flebay and have started the bracket work for it!!! Also as you can see in the pics I have started the bodywork on the bed and cut a tunnel in the cab for the ds, I will also be revisiting areas on the rest of the truck. I also need to trim out more of the inner bedsides, I'll prob do that tonight.
#30 |
Under Construction
nice progress.
#31 |
Movin right along with the bodywork...also I found a couple of pics I forgot to post....
#32 |
Started messing with the tailgate...and the LH bedside is smacked pretty good near the tail lamp area, that will take some work.
#33 |
....the frame looks tweaked in the pic w/out the bed but I didn't have the cab mounts on at that point-all good now though. Also, I FINALLY fixed the trans leak-my garage floor is water proof for sure now!
Note: that's my 05 in the background. |
#34 |
It is lookin real tastey, i like it. that color is gorgeous, looks great on these trucks.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#35 |
low n' slo
![]() Join Date: Mar 2009
wow, it gets that low with just a notch and mounting the bags on the trailing arms? how far from the ground is the frame?
#36 |
I wish it were that easy...take a closer look...the bags are mounted on the axle, the cab has a tunnel for the ds, and the crossmember is cut...I'm not sure on the height of the frame but the bedside is about 3 inches from touching and I still need to put in some 2 in blocks on the back.
#37 |
Under Construction
looking good bro, need to check it out one day, I'm down the road in Midlothian....
#38 |
Doin an update today...I'll post some pics when I get done with the lcas in a bit.
#39 |
Left side is on......huge difference from before as you can see in the pics
![]() ![]() Last edited by mycool72; 10-16-2009 at 01:37 PM. |
#40 |
I finished the right side lca last night, i'll pull it out today and upload some more pics.
#41 |
low n' slo
that lca mod made a big difference...truck looks good
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#42 |
The truck looks good. Keep up the work.
#43 |
Thanks guys.
#44 |
low n' slo
you anywhere near rosenberg?? maybe i could get you to do my lca's like that! im not sure if i want to attempt that myself
#45 |
I don't know where rosenberg is so i guess not. I'm se of ft. worth and sw of dallas.
