Old 07-11-2009, 11:57 PM   #101
protrash64
Resistance is Futile
protrash64's Avatar
Re: Protrash Re-hash
Ok guys, another minor update. First up: at least it wasn't hot today when I decided to go work on the truck........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-12-2009, 12:11 AM   #102
protrash64
protrash64's Avatar
If you cant tell......its 110*. I also wanted to put out some general info that I discovered today. I bought power window regulators a couple years ago and I finally decided to scope 'em out. Looks cool and not too difficult at all....but here's what I found. I have the Electric Life kit for 64-66. You must drill to mount the motor assembly and it leaves 3 screws exposed thru the door!!!!. 2 will fall in the lower portion of the door and 1 falls in between the raised area and the door panel. I dont care that much, but I could see some people being very upset with it.
Decided to knock out the front clip with the 'bodymans palm pilot'...used some 180 and went to town. My front clip is in good shape and will take the least amount of work so I just decided to hit it and quit! Need to do the corners, edges and small work but it was nice to get the majority knocked down in about 2 hours. I'm trying to keep up with shortbed 70...not really. Put in some more effort on the doors and will be repairing the drivers door soon.
Also got to use the round Durablock as Alan suggested in the 'indent' of the door and it worked nicely. I'll probably go back over that area of the bed before primer gets stuck. Enjoy. (Notice my Craigslist find= 36'' Maxx Air fan)
Old 07-12-2009, 12:29 AM   #103
joe231
joe231's Avatar
cool man, glad you seem to be having a cold front hanging around
that fan is a nice find
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-12-2009, 12:32 AM   #104
kyle4381
You were outside today? You survived? Looking good. I will come by and check out the progress. Maybe roast the new Michelins...
kyle4381 is offline   Reply With Quote
Old 07-12-2009, 12:46 AM   #105
protrash64
protrash64's Avatar
Cool.......just do it in 4wd this time...you wont have to rotate the tires as much.
Old 07-12-2009, 12:45 PM   #106
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 07-12-2009, 01:42 PM   #107
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
what kinda temps do you have at night in AZ
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-12-2009, 02:41 PM   #108
kyle4381
It gets down to 85 at about 3 am. It was still 99 at 9:45 pm last night.
Old 07-12-2009, 08:31 PM   #109
Heater63
Heater63's Avatar
Back to the power regulators. Thanks for posting that alert on the screws. I am going to put in power windows too, so would appreciate any feedback on that kit, as well as others you may have looked at.
Since you are doing the body work now, I would WELD IN the screws, so that you end up with "studs" on the inside of the door! grind the outside smooth and proceed on with your filler, primer, and blocking.
Only 104 degrees here this week, load up the trailer and come to Texas!! LOL.
Looking good, don't rush the prep. 100% of a good finish is the prep.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 07-12-2009, 09:35 PM   #110
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
it was 102 today here its probably about 80 now
Gage
Old 07-13-2009, 12:49 AM   #111
protrash64
protrash64's Avatar
Thanx Heater63.....I thought of welding in something, BUT.....I've already painted the interior......my thoughts are that the mounting is basically a triangle shape so it should be stable with only the 2 lowest screws. I will cover them with a speaker pod/contraption yet to be conceived. I dont like to second guess the manufacturer, but hey, it wouldnt be a hotrod if it was stock!!!
The biggest problem with welding in the screws is that I dont know how I would rotate the entire power window assembly inside the door to tighten them. If you put studs on them, then you end up with nuts on the door.
This may be hard to visualize....I will post more pics of them when I get time.
Old 07-13-2009, 01:02 AM   #112
Dinos63
chevy only
Dinos63's Avatar
jeff nice work and yeah it was hot today i did manage to open my garage door and that was about it for me
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-01-2009, 12:57 AM   #113
spr85gmc
spr85gmc's Avatar
Alots of good info in here how'd I miss this.
spr85gmc is offline   Reply With Quote
Old 08-01-2009, 09:26 AM   #114
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by protrash64 View Post
...at least it wasn't hot today........
......If you cant tell......its 110....
ya right....thats funny !!!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-04-2009, 10:35 PM   #115
shortbed70
shortbed70's Avatar
Smile Re: Protrash Re-hash
Yours is looking good man at least you have all your sheetmetal...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-14-2009, 12:00 AM   #116
shrunken66stroker
shrunken66stroker's Avatar
What's up with the re-hash. Too hot to work or what?
shrunken66stroker is offline   Reply With Quote
Old 08-14-2009, 06:48 PM   #117
protrash64
protrash64's Avatar
Thanx for the inquiry....you're pretty much right on. I was laid off for nearly 6 mos and that is when I started the work out of boredom as I stated in the beginning. It was kinda a reverse psychology type thing; I knew if I started doing something that I really wanted to do, I would get a job......and sure as sh!t I got a job. I work for a solar electric company installing grid-tied photovoltaic systems. We start at 4:30am and its HOT....sometimes I cant even eat dinner Ive been cooked so bad during the day. I dont have a lot of energy left for the truck lately. This is the worst couple of months in the Valley IMO and I probably wont resume anything major until temps moderate a bit. I have some neat stuff and changes coming up and I will post up when I get going on them.
Hope everybody else keeps on truckin' before winter; I'm waiting for winter to get something done.
Old 08-15-2009, 02:18 PM   #118
shortbed70
shortbed70's Avatar
Well congrats on the new job and I understand about the heat thats why I haven't done anything with mine in two weeks but today I got board and primed the whole cab hopefully for the last time.
Troy
Big Red Dog build
Old 08-17-2009, 07:36 PM   #119
Strodder
Daring to be Different
Strodder's Avatar
Subscribed. Have to catch up now.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 08-17-2009, 09:32 PM   #120
scotts62
One day...
scotts62's Avatar
but looks like we have to wait until winter to see any pics
Oh yeah and congrats on the new job
Scott
93 crew cab build
Project 62
Last edited by scotts62; 08-17-2009 at 09:33 PM. Reason: Had to congradulate a home fri
Old 08-17-2009, 09:57 PM   #121
daverod
SSN 706
daverod's Avatar
Ya jobs kinda suck,but they do give you money to buy cool stuff for your truck.
daverod is offline   Reply With Quote
Old 08-18-2009, 04:04 PM   #122
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
The truck looks good. That palm sander may get you into trouble for body work though...lol
82 Chevy Blazer 4wd.RIP
1965 Chevy C10,350V8
Get it reliable,then puttin' it in the weeds..
"Old truck, all new headaches."
hAetWagon is offline   Reply With Quote
Old 08-18-2009, 05:19 PM   #123
protrash64
protrash64's Avatar
.....Yep, time to stimulate the economy!!!
A palm sander is not recommended for body work as it leaves little circles everywhere; I used 180g paper just to knock the high build down and I will be covering it in another layer of high build. I know its not good but its the only power tool I have for sanding, not enough air capacity for a line sander at my house. It did a good job for what I needed done as I kept it moving and there is not any serious stuff to do on the front clip. If I spray on the primer as thick as the last batch, nothing will ever be seen.
Old 08-18-2009, 05:30 PM   #124
daverod
SSN 706
daverod's Avatar
Here's what I use. It's orbital. Don't cost to much.
Old 08-18-2009, 06:00 PM   #125
Dinos63
chevy only
Dinos63's Avatar
JEFF I KNOW HOW YA FEEL, IT JUST NO FUN TO WORK ON STUFF WHEN YOU ARE BAKING
