Old 01-08-2009, 05:36 PM   #26
tonythezeek
tonythezeek's Avatar
Re: 6 lug rotors on 71-87 c10 spindles
Originally Posted by Daniel 61 Apache View Post
I can either swap the lower control arm for a C10 and the upper ball joint for a C10, but I could just go ahead and get the conversion spindle from ECE and save a few hundred bucks.......
I would go forward with the C10 LCA and C10 ball joints. I don’t know how readily available C20 ball joints are at a local parts store nor know how much they would run you if they should fail. I have a 62 and that was one of the driving reasons for converting my front to something newer... price and convenience ...just MHO.
tonythezeek is offline   Reply With Quote
Old 01-08-2009, 06:08 PM   #27
Daniel 61 Apache
Daniel 61 Apache's Avatar
3/4 ton ball joints for an 85 C20 are $20 and instock at the local autozone.....
Here's the breakdown.
Spindle Conversion route of 3/4 to 1/2 ton:
ECE conversion spindle $269
CPP 6 lug rotors $129 DONE.
Control arm swap
LMC repo lower control arm $300
CPP C10 drop spindles $219
I'm going with the conversion route for now. Just ordered the conversion spindle from ECE.....
And I do want to say that I've spoken with CPP and ECE in the past two days and ECE does have some nice guys working over in their customer sevice dept. The guys at CPP sounded like they were pissed they had to come to work.
Daniel 61 Apache is offline   Reply With Quote
Old 01-08-2009, 06:55 PM   #28
SCOTI
SCOTI's Avatar
You have a C20 c.member & C20 a-arms in your posession now? If so, swap to an 88-98 lt. duty 3/4 ton disc set-up.
It uses the 88-98 style of spindle which requires a larger BJ pilot hole in the lower a-arm vs. traditional dics swaps using 71-87 parts (which require C10 lower arms). IIRC the required parts breakdown goes like this.....
C-20 lower a-arms (uppers are the same BJ bolt pattern & thus interchangeable)
88-98 spindles (w/brake stuff.... stock or dropped)
88-98 lower BJ
88-98 upper BJ
88-98 6-lug lt-duty 3/4 ton rotors
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-08-2009, 09:01 PM   #29
Daniel 61 Apache
I read through the threads before about that swap. I'll stick with this for now. Thanks for the info though, just too many different parts to remember.
Old 01-08-2009, 09:22 PM   #30
TR65
TR65's Avatar
Guys,
I used CPP parts to convert my 65 C10. The Western brand spindles (87 type) were excellent. The 6 lug rotors I believe are Chinese but they seem to work well. I ordered plane rotors but CPP sent slotted and vented!! I'll take em. One of the tie rod conversion adjusters was wrong but they took care of it.
I had to use 1/4" wafer spacers to get my 15" steel wheels to clear the calipers, but that's OK.
I am very happy with the end result, excellent stopping power.
Part of the never ending saga of old Chevy truck brake upgrades.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 01-08-2009, 09:54 PM   #31
suicide 63
[QUOTE=Daniel 61 Apache;3071947]Didn't your truck have 88-up spindles on it? I thought that the 73-87 spindles were different from the 88-up........
quote]
I'm sorry i didnt specify as i have more than one project.
I had cpp rotors on my 63 that i sold to another board member, and on my crew i went with 88-up stuff.
suicide 63 is offline   Reply With Quote
Old 01-08-2009, 10:10 PM   #32
Daniel 61 Apache
Hey TR65, what do you mean wafer spacers? Like a spacer that mounts between the rim and the rotor? Like this?
Old 01-08-2009, 10:46 PM   #33
TR65
TR65's Avatar
Yepper,
That's them.
TR
1965 C10 SWB Fleet
Two owner
Old 01-08-2009, 11:44 PM   #34
Daniel 61 Apache
Yepper,
That's them.
TR
Sweet. So I can keep my stock wheels.
BTW, those slotted rotors look b-e-a-utiful.
Old 07-19-2009, 02:06 PM   #35
likaroc13
Rollin' Old Skool
any other options for keeping the steel wheels? i'd like to convert to 6-lug discs, but i'd like to keep stock-type steelies
Old 07-19-2009, 10:03 PM   #36
Captainfab
60-66 Nut
Try this link here.....http://www.67-72chevytrucks.com/vboa...ad.php?t=35042
Old 10-02-2017, 08:30 PM   #37
gsharp
I have a 64 C10 Fleetside, I installed a front end from an 81 and wanted to keep the six lug wheels. I ordered a set of the 6 lug rotors and they didn't fit. Too deep and too big of bearing on the inner. Come to find out mine is a 1" thick rotor that is 4.69" tall. The 6 lug is 1-1/4" and like 4.95" tall or something. So does anyone know of a 6 lug 1" thick rotor?
gsharp is offline   Reply With Quote
Old 10-02-2017, 08:44 PM   #38
lolife99
67-72 parts collector,…
lolife99's Avatar
No 6-lug rotors for the 1" spindles.
You will need to swap to 1-1/4" spindles and calipers.
And inner bearings, as you know.
Keith
Convert to disc brakes.
Old 10-02-2017, 08:47 PM   #39
gsharp
Well that sucks. I guess the front end will be 5- lug for a while. Thanks for info.
Old 10-03-2017, 10:50 AM   #40
SCOTI
SCOTI's Avatar
Poverty cap & poker face. We won't tell.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
