Old 07-31-2009, 06:35 PM   #1
Slmd92DIME
Slmd92DIME's Avatar
Will these axles work in my 65 c-10?
hey guys I was searching and found these axles and they convert it to 5 lug too. http://www.summitracing.com/parts/SAG-PA5855/ I want to go to carlisle next week and I need someone that ships rather quickly. Has anyone used these before?
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=269019
Petitioning *No Regrets* MD/WV
Slmd92DIME is offline   Reply With Quote
Old 07-31-2009, 06:43 PM   #2
shortbed70
shortbed70's Avatar
Re: Will these axles work in my 65 c-10?
I would like to know also. But mine is a 64
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-31-2009, 10:30 PM   #3
Slmd92DIME
Slmd92DIME's Avatar
I just ordered them so i will let you know about wednesday next week
My Build Thread
Old 08-01-2009, 04:55 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Application chart says yes .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 08-01-2009, 10:37 PM   #5
Captainfab
60-66 Nut
If your differential is an original '64 12 bolt then these axles won't work without switching the spider gears to 30 spline gears. The '63 & '64 12 bolts had 17 spline axles and spider gears.
Old 08-02-2009, 11:56 AM   #6
shortbed70
shortbed70's Avatar
Mine is a 64 so I need spiders
Troy
Big Red Dog build
Old 08-02-2009, 10:59 PM   #7
Captainfab
60-66 Nut
That would be correct.....unless someone has already changed them or the complete differential within the last 45 years.
Old 08-03-2009, 06:08 PM   #8
shortbed70
shortbed70's Avatar
Well I have a 72 rear out back I cant sell so I guess I'll pirate some stuff off it.
Troy
Big Red Dog build
Old 08-03-2009, 10:22 PM   #9
Captainfab
60-66 Nut
What about just swapping the complete '72 differential, or is the increased width not going to work for you?
Old 08-03-2009, 10:50 PM   #10
shortbed70
shortbed70's Avatar
I need the narrow rear and my 72 rear needs gone through and has an anemic 3.78 rear and open where I have 3.73 lsd factory.
Troy
Big Red Dog build
Old 08-04-2009, 12:07 AM   #11
Captainfab
60-66 Nut
If your '64 has the factory limited slip for the 17 spline axles, then you might have to change the whole carrier. I'm not positive but I don't think the 30 spline side gears will work in place of the 17 spline gears.
I would suggest verifying exactly what is in your '64 12 bolt to start with, and then go from there.
