Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-17-2008, 08:03 AM   #26
RADDRACINTRK
Re: post latest 1/4 and 1/8 mile times and 60ft.
djracer thanks for the welcome
69trk never thought truck would hook so hard with all stock hardware
still smiling
RADDRACINTRK is offline   Reply With Quote
Old 07-19-2008, 12:10 AM   #27
prostreet1967
prostreet1967's Avatar
heres my best out of three runs haven't been back since i got slicks and track bar.will post new times soon. as for now i got the slowest truck lol
60' 2.218
330 5.884
mph 62.30
1/8 8.943
mph 77.54
this run was with 454 th400 ford 9 in 4.56 gears spool 33x21.5x15 sportsmans
prostreet1967 is offline   Reply With Quote
Old 02-02-2009, 02:51 AM   #28
Super73
Super73's Avatar
This should become a sticky IMO..
Post your newest info and I'll update the spreadsheet..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 02-02-2009, 08:33 AM   #29
djracer
djracer's Avatar
Maybe we can make it one oneday!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-02-2009, 10:12 AM   #30
71Dragtruck
71Dragtruck's Avatar
10.61@126.75 1.54 60'
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 02-02-2009, 01:05 PM   #31
383 Stroker
383 Stroker's Avatar
7.18@93mph, 1.56 60ft...
Video's of my Truck Racing
1967 C-10, 383ci Sbc, TH350, 3200 stall, 3.73 gear
383 Stroker is offline   Reply With Quote
Old 02-02-2009, 11:10 PM   #32
1FAST68
I did more carb tuning.
11.98 at 109, had a 1.73 60ft and a good headwind so it improved.
1FAST68 is offline   Reply With Quote
Old 02-03-2009, 12:00 AM   #33
bigjimzlll
bigjimzlll's Avatar
ask and you shall recieve...it's sticky now
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-03-2009, 12:38 AM   #34
Super73
Super73's Avatar
Jim... Glad to see you around
Old 03-07-2009, 01:17 AM   #35
franks72
Junior Member
franks72's Avatar
This was the end of last year. This year we get a new converter ,rear springs and spray it. Hope to get it in the 12s on the motor and 11s on the juice..
60' 1.872
330 5.432
1/8 8.405
mph 82.29
1000 11.006
1/4 13.225
mph 101.43
weight 4500
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82
12.39 @111.33 With a 180 shot nos
69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/
email fdelcoglin@hotmail.com
franks72 is offline   Reply With Quote
Old 03-10-2009, 03:14 PM   #36
71chevytruckguy
71chevytruckguy's Avatar
Name 71chevytruckguy
Date 03/07/09
60' 1.811
330' 5.453
1/8 ET 8.478
1/8 MPH 82.736
1000' n/a
1/4 ET n/a
1/4 MPH n/a
Year 1969
Weight ???
Engine Platform (Cubic inches and SBC, BBC, BBF, LS-series, Hemi) 377 SBC
Transmission Muncie M-20
Stall converter dumping the clutch at 4000rpm
Power adder 1 none
Power adder 2
Power adder 3
Rear Gear 4.88
Rear Tire 28x10.5 M/T ET drag
Comments pump gas all motor
Chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 06-16-2009, 10:33 AM   #37
Outlaw72
Hay Team!!
Outlaw72's Avatar
Mine has a best of 7.36 @ 93mph in the 1/8th
That was a 1.61 60 ft.
LWB, Trailing arms, 10 inch wheel and MT Drag Radial
The new setup should be in the 6's...we will see soon
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 08-09-2009, 07:30 PM   #38
spaseghost
certified tard
spaseghost's Avatar
finally went out. i havent done anything to the truck except hook up the vacuum advance, tint the windows, and run premium. that open diff is killin me, i was thinking about going 305s in the rear or bigger. but i think a limited slip will really wake up the time and work great with the 275s. remember, im at 5000+ feet, so times are a little slower here. oh yeah, stock 8.5" 10 bolt with 2.73's. i was proud of me! ill get that lsd and see what happens, but i still really want some rallye wheels, money money money, damn it.
run #1
rt .655
60 2.638
1320 16.363 @ 81.44
run #2
rt .806
60 2.631
1320 17.614 @ 77.75
floor mat got stuck under gas pedal...
Run #3
rt .555
60 2.844
1320 16.503 @ 85.41
run #4
rt .403
60 2.717
1320 16.356 @ 84.81
spaseghost is offline   Reply With Quote
Old 08-10-2009, 12:27 PM   #39
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Well i finally made it to my local track first time ever with the truck it has alittle more in it need to change gears crossing the line in second gear
all motor passes
1st pass
1.68 60'
7.66 1/8
83.85 mph lifted early
2nd pass
1.60 60'
7.45 1/8
88.70 mph adjusted timing
3rd pass
1.75 60'
7.65 1/8
89.57 mph spun out of the hole
_______________________________
1968 c-10 stepside "THE GRAPE APE"
all motor
1.56...60ft
7.41...1/8
89.41..1/8
limitedstreetoutlaw is offline   Reply With Quote
Old 08-29-2009, 02:25 PM   #40
spaseghost
certified tard
spaseghost's Avatar
two new ones from 8/28/09
rt .508
60 2.897
660 10.893 @ 69.29
1320 16.679 @84.48
still having traction issues
second run just had the track cleaned after a spill, i was first! i went against my dads 68 camaro, first time he raced it he started in third! luckily it was a bye run, still embarassing. second time we went up together, im on the left lane.
0.223 rt .244
2.510 60 2.723
6.840 330 6.832
10.400 660 10.132
69.82 mph1 74.39
13.393 990 12.890
16.169 1320 15.409
84.29 mph2 92.74
85 swb bbc 5% tint
16.356 @ 84.81 8/07/09
4800 Ft., bad timing, carb tune, and traction, fugg it.
16.169 @ 84.29 8/28/09
good timing, no carb tune, some traction...
06 Equinox LT AWD, wife's and family ride
03 Mustang V6, CAI, Duals, Pullies, Programmer, Short Throw, wife's dream car?!
90 Eagle Talon, other project / space taker, GOT head!!
08 Silverado 2500 HD, the bad ass work truck
Old 08-29-2009, 11:18 PM   #41
1FAST68
Learning how to take off and where to **** my new bullet.
11.13 at 117
Old 08-30-2009, 03:20 PM   #42
KQQL IT
At the body shop.
KQQL IT's Avatar
Super73? hows your 73 coming havnt seen any new pics over there. Any how .012 rt 1.671 60 ft 4.95 330ft 7.71 1/8th 88.71 mph 12.20 1/4 108.1 mph sbc 406 th 475 tci 3500 ish verter 3.82 gear 9 inch cal tracs hoosier 325/50 drag radial.
KQQL IT is online now   Reply With Quote
Old 09-05-2009, 04:35 PM   #43
Super73
Super73's Avatar
Nice pass.. Truck needs a little tuning but I did drive it to a car show a week or so ago.. I think the new intake is loading it up.. Weird how an intake change can make this thing go soooooo rich.
Old 09-07-2009, 12:30 AM   #44
69trk
69trk's Avatar
It seams i can just change a nut on the fender, and mine will run different
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 09-07-2009, 12:43 AM   #45
KQQL IT
At the body shop.
KQQL IT's Avatar
super 73 good to hear the car moves. the pics on nc1320 were awesome
Old 09-15-2009, 12:15 AM   #46
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Name68 C-10
Date9/11/09
60'1.664
330'
1/8 ET7.670
1/8 MPH88.94
1000'
1/4 ET12.223
1/4 MPH106.62
Year68
Weight4013lbs w/ 8 gal of Fuel
Engine Platform SBC406
TransmissionTH400
Stall converterHughes 4000 leaving @ 3600 RPM
Power adder 1na
Power adder 2na
Power adder 3na
Rear Gear4:10
Rear Tire28x13.5 ET drag MT
CommentsI'm not sure were some of my power went to. End of last year it ran 12.0 around 109mph. I have done leak down and comp test all is good. Next up Valve spring test.
68 C-10 KID is offline   Reply With Quote
Old 09-15-2009, 07:28 AM   #47
djracer
djracer's Avatar
Was the air the same?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-15-2009, 11:27 AM   #48
Super73
Super73's Avatar
I was going to say DA effect's possibly.. It's amazing how much of an effect it can have..
Old 09-15-2009, 01:50 PM   #49
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
wasent it like 90* that day? were you at Woodburn or PIR?
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 09-16-2009, 01:46 AM   #50
68 C-10 KID
Mean Green
I don't have any thing to test air levels to see if they are high or low.
I have only went 12.0's @ Woodburn and 12.1's at PIR.
I'm not on board w/ the abbreviation Of DA.
I did put a new ss blaster coil on last night. I need to OHM my old one. I'm borrowing my machinist spring tester this weekend so I can check springs on the heads in truck. I need to invest in log book real bad.
