Old 09-03-2009, 09:18 AM   #251
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Are you going to have some sort of bracing from the top of the shock towers? That front section of minx frame looks like it could be tied into the bottom of the new section, but I suppose it depends on the other suspension/steering parts that need to fit in there. Looks like a hack job now, but I'm sure you'll get it all tied together and looking like it was that way from the factory.
This build is cute an all, but I have to say, I miss the progress reports from the burb.
hgs_notes is online now   Reply With Quote
Old 09-03-2009, 10:48 AM   #252
Frizzle Fry
Frizzle Fry's Avatar
The front is barely tied in just to hold position for now. There will be boxing top and bottom and yes tower bracing triangulated back to the firewall and a removable strut brace laterally.
Frizzle Fry is offline   Reply With Quote
Old 09-03-2009, 12:34 PM   #253
Britain Smith
Nice man...I will try to make it over after I pick up the kids tonight to check out the progress in person.
Now get out there and cut the other side!
-Britain
Britain Smith is offline   Reply With Quote
Old 09-03-2009, 11:59 PM   #254
Mister laugh
You missed a big spot in the middle.
On a more serious note i wish i had 1/10th of your metal skill........It looks great
Mister laugh is offline   Reply With Quote
Old 09-03-2009, 11:59 PM   #255
454_72_4X4
454_72_4X4's Avatar
Originally Posted by Frizzle Fry View Post
Full effect:
Ya forgot to fill that huge hole in the center! hahaha
Amazing work frizzle! Keep it up!
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 09-04-2009, 12:01 AM   #256
Jvsapp
Jvsapp's Avatar
he's gonna use a wheelbarrow tub for that hole
Jvsapp is offline   Reply With Quote
Old 09-04-2009, 12:04 AM   #257
454_72_4X4
454_72_4X4's Avatar
Hahaha! Same thought, same time! I agree on your second sentence too!
And it'll probably look great too!
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 09-04-2009, 01:06 AM   #258
Mister laugh
He could probably use an old rusty barbecue lid, and make it look like it came out of a factory with his skill.
Old 09-04-2009, 06:44 PM   #259
Frizzle Fry
How did I miss that?
No wheelbarrow (I know where that idea came from) or BBQ lids here. But I'd use one if it met my needs.
Yesterday I put the engine in place again so I could mark the rack position and box the frame accordingly.
Since it's a bit of a PITA to get the engine/trans in/out I decided to knock some other things out while it was in there. I really wanted to see if my header would work with the added clearance gained with the straight frame rail: NOPE. Not without modification anyway.
I was able to remove 3/4-1" from the primaries right by the flange to suck it in closer to the block.
3/4" taken off (one rolled away):
The two center pipes are the real problem. I was able to get another 1/4"-"3/8" off them forcing them in with a hose clamp:
The 4th cylinder did not want to cooperate.
Be we have ways...
Old 09-04-2009, 07:04 PM   #260
hgs_notes
GEARHEAD
hgs_notes's Avatar
Where there's a will, a hammer, some visegrips, a cutting wheel and a welder, there's a way. Man that's tight.
Old 09-04-2009, 07:41 PM   #261
Frizzle Fry
It is tight. I will have to clearance the frame rail a bit.
Also had to make some room in the floor (view from inside on PS):
But otherwise it's like it was made for it!
Old 09-04-2009, 09:43 PM   #262
dammitmitchell
the pollock
dammitmitchell's Avatar
still sexy and incredible (the car and welding ... dont get no ideas here)
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 09-05-2009, 12:18 AM   #263
hgs_notes
GEARHEAD
hgs_notes's Avatar
Remember that header wrap adds to the thickness. Considering how close everything is in there, I would say the wrap is mandatory.
Old 09-05-2009, 12:28 AM   #264
Frizzle Fry
thanks
It will be ceramic coated and I'll make a heat shield. Not a big fan of header wrap but I'll use it if I have too.
Old 09-05-2009, 12:34 AM   #265
tdave00
Restoring a 68 SWB
tdave00's Avatar
Love watching the progress on this project. Good job man!
tdave00 is offline   Reply With Quote
Old 09-05-2009, 12:46 AM   #266
Jvsapp
Jvsapp's Avatar
damn that's tight. and you still have clearance between the firewall and the valve cover? your passenger is gonna have a hot foot but awesome work FF. i was looking at the use of hose clamps thinking *thwanggggg* if it let go.
Old 09-09-2009, 05:55 PM   #267
Britain Smith
Where are the updates? I know that you have some, I was there!
-Britain
Old 09-09-2009, 06:52 PM   #268
Frizzle Fry
It's just a repeat of the PS on the DS for the most part. I'll post pics when it's boxed. I've done some more work on the header too. I can post those when it's done (soon).
Old 09-16-2009, 01:27 PM   #269
jb1016
"Oh well, it's a driver."
jb1016's Avatar
This slayed me! Looking good FF.
Old 09-18-2009, 11:41 AM   #270
Rokcrln
Rokcrln's Avatar
Looking good Mike! You had me thinking about doing a 4 banger power plant for an early scratch built roadster pick up I am designing but I came across a 4 cam lincoln 4.6 mod with 50 K on it that will fit the bill a bit better for this build but maybe next time in a little 34 roadster or something. Keep up the progress and get back to that Hoe sometime soon
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-18-2009, 11:52 AM   #271
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
I'm no ford guy, but those 4.6's are some good cheap power. I've seen some builds where guys have pulled a butt load of HP out of them relatively cheap.
IvelDesigns is offline   Reply With Quote
Old 09-18-2009, 06:42 PM   #272
Frizzle Fry
Kevin
LFD Inc.
Love 4cammers. The F20C is a good match for this car's intended use; daily street and occasional weekend ax/drift/silliness.
Still making progress on the DS. I've also been doing a lot of research for the selection/design of the steering. It's not a matter of simply selecting a rack with the right inner-to-inner tie rod length and putting it in the right position. The position of the engine in this car will not allow the correct placement of a "conventional" rack. So I'm designing the steering around a center steer rack similar to this:
The problem is that all the center steer units I can find are designed for rear steer. I may end up getting a RHD rear steer unit and using it for LHD front steer... We'll see.
Old 09-18-2009, 06:56 PM   #273
joe231
joe231's Avatar
Rear steer?
As in the rack mounted to the rear of the front wheels, or steering on the rear wheels?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-18-2009, 07:01 PM   #274
Frizzle Fry
RHD manual rack:
Old 09-18-2009, 07:03 PM   #275
Frizzle Fry
Originally Posted by joe231 View Post
Rear steer?
Rear steer: Tie-rods/steering-arms aft of wheel center on the front wheels.
