Closed Thread
Old 11-04-2009, 09:55 PM   #1051
WILDSTANGRACING
WILDSTANGRACING's Avatar
Re: How about some pics of 60-66 Trucks
im glad to hear that its been fun
JUST ASK
WILDSTANGRACING is offline
Old 11-04-2009, 10:24 PM   #1052
WILDSTANGRACING
scoti was your question for me ??
JUST ASK
Old 11-05-2009, 11:07 PM   #1053
DWright
Shlong Bed Club
DWright's Avatar
mine; be nice, its a work in progress... I just finished hacking the front crossmember from a '79 for the newer suspension, power disc brakes and steering. Does anyone know where I could find a set of 6-lug rotors to fit the '79 spindles? I already have new calipers so all I need is just the rotors; any help would be great. Looking back, I wish I had kept the truck it's original "patina green".
DWright is offline
Old 11-06-2009, 12:22 AM   #1054
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i know the some of the 73 to 87s had 6 lug i guess it was the heavy duty ones
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline
Old 11-06-2009, 02:22 AM   #1055
Sicboy
Sicboy's Avatar
Dam, I love that seat...
Project Build (1): http://67-72chevytrucks.com/vboard/s...d.php?t=362482
Project build (2): http://67-72chevytrucks.com/vboard/s...d.php?t=370985
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming...Wow, What a Ride!”
- Hunter S. Thompson
Sicboy is offline
Old 11-06-2009, 03:09 AM   #1056
markeb01
Senior Enthusiast
markeb01's Avatar
Dig the 4 barrel on the six. That was something I always wanted to try back when I had a six.
markeb01 is offline
Old 11-06-2009, 06:06 AM   #1057
DWright
Shlong Bed Club
DWright's Avatar
Now only if someone could tell me what that ultra comfortable, power seat came out of....
DWright is offline
Old 11-06-2009, 09:34 AM   #1058
clemdaddy
clemdaddy's Avatar
Originally Posted by SCOTI View Post
Give us the story behind this one. Drivetrain? Suspension? Original flatbed?
I love it!
the dually began as a 66 custom cab half ton with fac air that was in sorry shape. i had a 64 1-ton with a rusty cab and a 87 dually with a tired motor. so, like most of you guys would do, i used the best of what was there. it's got a fresh 350 with holley pro-jection and electronic ignition, the frame and granny 4 speed are from the '64, the front disc-brake cradle and rear suspension are from the later model donor ( cool that you can cut the rivots on a much newer truck and the older frame is already drilled to bolt up the front and rear suspension). the bed came from a 50 model 1-ton. the total build took 13 months and everything was done in our driveway including the paint job.
thanks for your interest scoti, i will try to get some more pictures this weekend and post them.
clemdaddy is offline
Old 11-06-2009, 10:57 AM   #1059
aggie91
I'm just glad to be here!
aggie91's Avatar
CPP, ECE, Performance Online, they should have a 6 lug rotor that fits the 79 spindle. Is your current 79 rotor a 1" or 1.25" rotor? I think the 6 lug rotors that they may have are 1.25" and will not bolt on a spindle designed for the 1" rotor.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline
Old 11-06-2009, 12:58 PM   #1060
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I bought my brake kit from Performance online. They are set up for the 1.25 spindle. make sure you have the right one. I got mine really within 2 days.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 11-06-2009, 01:41 PM   #1061
SCOTI
SCOTI's Avatar
Very cool build. I'm sure everyone would love to see more pics.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now
Old 11-07-2009, 01:35 AM   #1062
Rich 5150 69
Rich 5150 69's Avatar
`64 short box, quad fed vortec 350, Turbo 350 shift kit, 373 posi, 05 buckets and consol, `86 jeep column, power drum, power steering, diamond plate bed, yet to be done move tank, disc`s, new wiring and then repaint
Rich 5150 69 is offline
Old 11-07-2009, 11:59 AM   #1063
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
dang killer lookin truck
how much did you spend on diamond plate
Gage
Old 11-07-2009, 12:16 PM   #1064
Rich 5150 69
That was put in in `93 $104.00 at the time, thru a friend then cut to fit, seam down the middle. 5/8 inch cdx plywood, need to redo the plywood, I did not seal it. and change the carraiges bolts to stainless.
Old 11-08-2009, 08:09 PM   #1065
nbrfd007
nbrfd007's Avatar
Thought you guys might like a pic of the shop truck. It has a 9000 lb. winch on the back for pulling vehicles up on my trailer. It also has louvers on the hood sides which help keep the under hood cool. I got those louvers from a couple of core supports.
clemdaddy, your place is Great, go by there alot. Someday I would like to stop and say hello.
nbrfd007 is offline
Old 11-08-2009, 10:01 PM   #1066
412dab
412dab's Avatar
[IMG]C:\Documents and Settings\barlowda\My Documents\CK1500_.JPG[/IMG]
Ok, trying again.
412dab is offline
Old 11-08-2009, 10:04 PM   #1067
412dab
412dab's Avatar
OK, I think I have it.
412dab is offline
Old 11-08-2009, 11:09 PM   #1068
hornet53
hornet53's Avatar
Originally Posted by bubba327 View Post
Attachment 509960
Not mine but a picture of this work horse should be included. Spotted in a very small Idaho back woods town. Wanted to check out the 4 wheel drive but a big guard dog refused access.
If you look real hard, it looks like the hood ornament trim (not a functional scoop) from a 53 Hudson Jet, maybe Hornet.
By the way, I would like to say Hello! to all you 60-66 guys. I'm new to Chevy trucks but not to the old iron hobby. Here's what I just picked up...
Jeremy
1953 Hudson Hornet Sedan 308ci Twin-H-Power!
2003 Ford Crown Victoria Police Interceptor (beater!)
1966 Chevy C-10 Longbed SBW 396/TH400
Member Deviants C.C. Vanc.WA
hornet53 is offline
Old 11-08-2009, 11:20 PM   #1069
Slow Build
Slow Build's Avatar
Looks like it's in pretty good shape.
Very cool.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 11-09-2009, 12:05 AM   #1070
hornet53
hornet53's Avatar
Very cool.
Thanks. This is the Sick Industries '65 build from a few years ago. Check out the build at http://sickindustries.net/
It's got it's issues, but it runs, drives and is registered. The problems are mostly cosmetic sheet metal things.
I'll post more pictures when I get the correct SD card adaptor for my computer.
Jeremy
hornet53 is offline
Old 11-09-2009, 12:30 AM   #1071
Sicboy
Sicboy's Avatar
Welcome neighbor...
Sweet ride.
Sicboy is offline
Old 11-10-2009, 03:17 PM   #1072
clemdaddy
clemdaddy's Avatar
tim, stop by anytime... we live in the shop and if we're not there, we're probably just out running parts.
Old 11-10-2009, 04:56 PM   #1073
Strodder
Daring to be Different
Strodder's Avatar
Welcome aboard Jeremy. I like the "Old School" look.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline
Old 11-10-2009, 06:12 PM   #1074
gatch
A couple pics of my '63
gatch is offline
Old 11-10-2009, 10:34 PM   #1075
chevytrucknut
chevytrucknut's Avatar
By the way, I would like to say Hello! to all you 60-66 guys. I'm new to Chevy trucks but not to the old iron hobby. Here's what I just picked up...[/QUOTE]
Welcome Jeremy, you should post a pic of the truck dropped. That truck really scrapes.
'77 GMC SWB
'66 SNB (Project)
Battle Ground, WA
chevytrucknut is offline
Closed Thread
