Old 11-13-2009, 05:11 PM   #1
90\87Formula
90\87Formula's Avatar
One piece drive shaft
Is is common for an '87 GMC Suburban to have a one-piece driveshaft? It's equipped with a TBI 350 with 700r4 trans. 2 wheel drive, 1/2 ton.
I have a 90 and had an 85, and they both were/are equipped with a 2 piece DS, both 350s with the 700r4, 2 wheel drive, 1/2 tons.
Robert
Member 1532
90\87Formula is offline   Reply With Quote
Old 11-13-2009, 06:24 PM   #2
rcbildr
rcbildr's Avatar
Re: One piece drive shaft
Is it 2wd or 4x4? Both my 4x4 Burbs have a one piece drive shaft and the two 2wd Burbs I've had came with a 2 piece drive shaft.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 11-13-2009, 07:23 PM   #3
90\87Formula
It's 2wd.
Robert
Member 1532
Old 11-13-2009, 07:50 PM   #4
texassquarebodies
Truck Nut
texassquarebodies's Avatar
I have seen alot of burbs,,,,2wd.....all 2 piece.
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 11-13-2009, 08:37 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
I was at the junkyard 3 days pulling a trans out of an 87 burb. 1/2 ton 2wd 350 w/ 700r4 trans. The truck had a 1 piece shaft in it...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-13-2009, 09:07 PM   #6
Daggar
Daggar's Avatar
1987 was my old burb. Same config. 1 piece driveshaft
1999 Chevrolet Suburban 2500 4x4 - 454, 4L80E and lots of other fun options
1967 Chevrolet C10 Longbox Stepside - Restored
1991 Chevrolet Suburban 2500 4x4 - 350, 4L80E - Not dead but severly crippled
1987 GMC Suburban 1500 - Now some retired guy's trailer hauler
1992 Lumina Z34 - I'll miss that PITA
Daggar is offline   Reply With Quote
Old 11-13-2009, 09:30 PM   #7
JEM
Ironmonger
Maybe GM was running short of 2pc shafts in '87. My '91 2500 is a 2pc.
I wonder what the critical RPM is on a one-piece shaft as long as the one in a Sub.
JEM is offline   Reply With Quote
Old 11-16-2009, 06:27 PM   #8
rcbildr
rcbildr's Avatar
Both of my 2wd (82 and 84) burbs were 3/4 ton. Maybe that might be a factor.
My Projects:
1978 Camaro Z28
Old 11-17-2009, 12:17 PM   #9
Damien
Damien's Avatar
A suburban has the same wheel base as a long box pickup (137.5 in), so it shouldn't be all that uncommon to see a one piece drive shaft.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 11-17-2009, 11:53 PM   #10
72 CustomCamper
huh ???
Nope. A suburban has a 129.5 inch wheelbase. The long bed pickup is 131.5 inch...
Chuck
Old 11-17-2009, 11:58 PM   #11
87 dually burb
my short bus
87 dually burb's Avatar
I think it is where it was built cause my 77 had a 1 pc
but my 91 and 87 both 2 pc
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
