Old 09-25-2009, 12:28 PM   #26
JW76
JW76's Avatar
Re: 86 C10 Trailing Arm Conversion
Thanks for all the responses. You've made it clear that the crossmember needs to go between the frame rails so I will follow the advice. N2TRUX had a good point too. Putting it between the rails will open up more options for ride height, etc. later. I am currently not with the truck and am in Germany, so when I get back I can get more hands on. I am trying to get more of the theory straightened out now and will really delve into the project around Christmas time. These trucks are addicting. I'm on another continent and still thinking about it. Thanks for your help.
JW76 is offline   Reply With Quote
Old 09-25-2009, 12:44 PM   #27
SCOTI
SCOTI's Avatar
Be sure to update.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-25-2009, 01:01 PM   #28
terrellautosports
New Member
terrellautosports's Avatar
JW76,
to me when you mocked this up you still have the leafs on top of your rearend housing. in turn making the drive shaft and cross member below you frame rail. if you take the leaf springs off you should gain 3 inches for sure possible a little more. that should move your driveshaft up and your new crossmember up in the frame rails.
1968 SWB Project. Soon to Start Build Thread
terrellautosports is offline   Reply With Quote
Old 09-25-2009, 07:45 PM   #29
N2TRUX
Happy to be here
N2TRUX's Avatar
Lots of good conversation on the topic. It's a lot easier to make changes now than it is "after" you started cutting and welding....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-27-2009, 07:24 AM   #30
JW76
JW76's Avatar
Thanks for all of your input. I really appreciate the advice and I agree its a heck of a lot easier to think and rethink and make changes now then after you cut.
Old 09-27-2009, 09:05 PM   #31
Wild83C10
Wild83C10's Avatar
Looks like we will be doing this at about the same time. If I attack mine first I will let you know what I had trouble with or what worked better for me. Hope to hear the same from you. Good Luck!
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-28-2009, 11:38 AM   #32
falze
Does anyone know the length of the trailing arms of a short bed? I'm starting a buiild this winter with an orginal 2wd blazer frame with a manual trans. Sorry didn't mean jack your thread.
falze is offline   Reply With Quote
Old 09-28-2009, 12:15 PM   #33
SCOTI
SCOTI's Avatar
From what I remember, they should be 51" from C/L of the front bushing bolt to the C/L of the rear u-bolt/axle tube.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-29-2009, 07:21 AM   #34
JW76
JW76's Avatar
So, here is some food for thought I guess. Talking do you guys I realized I didn't know quite as mush as I thought so I started doing some homework. I did a search for some suspension design info and read through a lot of it. I looked at the HRH kits again, too and what other people have done with trailing arms on their trucks within this forum. I learned a lot but am confused too.
HRH sets their vehicles up almost identical to NASCAR. They install the trailing arms almost level with only a slight maybe 6 inches of pitch to the crossmember. They use screw jacks and coils for easy adjustment. For the panhard, they attach to either the drivers side axle tube above where the trailing arm connects or they catch the trailing arm then they anchor it on the right side frame rail with an adjustable mount with maybe 4-5 inches of vertical adjustment. They then set the panhard bar so that it is level at ride height. The panhard seems to run horizontal right along the axle tubes. This setup seems to work perfect form them allowing them to adjust to run drag, drift, or road courses.
Reading some other articles I read that the panhard should run at an angle with the center of the panhard crossing the differential, or that the panhard can be over the axle running parallel to it.
Also, I've read that having the trailing arms flatter will increase traction without pulling the front end off the ground and that the more angle you get, the more it wants to squat the rear end and lift the front.
Also, when I mentioned putting the crossmember under the frame, it makes my geometry identical to that of the HRH truck. I intend to keep my 15 inch wheels and can only afford to drop the truck in the back about 3 inches or so so with that drop it gives me identical geometry to the HRH truck which the owner of HRH swears by.
All together, this is a bit confusing.
Here are a few pictures and diagrams i looked found
Old 09-29-2009, 07:26 AM   #35
JW76
JW76's Avatar
pictures
Old 09-29-2009, 07:28 AM   #36
JW76
JW76's Avatar
few more
Old 09-29-2009, 09:51 AM   #37
andrewmp6
That camaro is from hotrodstohell.net they make a truck arm kit for a lot of cars even a s10.Its a good well rounded basic set up really only things to break are a arm or panhard bar.
Old 09-29-2009, 10:29 AM   #38
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm really failing to see where they have a stock crossmember mounted to the bottom flange of their frame in this picture:
It looks TO ME as though they are building a custom, low profile crossmember that mounts to the bottom of the frame:
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 09-29-2009, 11:06 AM   #39
JW76
JW76's Avatar
I was not inferring that they mounted a stock crossmember under the frame. They made a custom one, however it works the same way AS IF you were to mount a stock one below the frame. The driveshaft goes through the hoop and in both scenarios the mounting brackets for the trailing arms are at the same height in the same location. Their custom member works out the same as the way as the way I mocked it up.
The geometry of this move has been questioned in previous posts so I was just asking for more explanation as to why this is poor geometry. I am just trying to fully understand because if I move the crossmember up between the rails it is higher than the HRH truck and therefore there is more angle on the trailing arms. It seems like all HRH vehicles strive for a minimal angle in the arms.
Old 09-29-2009, 12:00 PM   #40
SCOTI
SCOTI's Avatar
The HTH set-up does mount between the frame rails, not under. In that pic, the c.member was being installed. If you look @ the side view shots of the truck on the ground w/wheels & tires installed, you can't see the truck arm forward pivots (below the frame rail).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-29-2009, 12:09 PM   #41
JW76
JW76's Avatar
Are there more pictures of the HRH truck available? Just curious has anybody seen the truck first hand?
Old 09-30-2009, 02:05 PM   #42
tymbom
The truck that HRH built was designed to look stock and not lower at all. If you put the cross member between the flanges of the frame like it is on the stock 67-72 style frames then it won't need to be custom fabricated at all. You could even use the CPP cross member.
tymbom is offline   Reply With Quote
Old 10-30-2009, 10:47 AM   #43
Damien
Damien's Avatar
I'm considering doing this swap on the step side I'm building for my dad, so I will be watching this thread. I found an istall artical of CPP's kit. There are some decent pictures of the set up. Here is the link. http://www.classicperform.com/tech_a...iling_Arms.htm
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 10-30-2009, 06:24 PM   #44
JW76
JW76's Avatar
Seems like a lot of people are interested in doing this swap. I have also been thinking about the crossmember and agree that it has to go inside the frame rails like Scoti and N2Trux said. I want the truck lower than I was planning before. The CPP article has some good tips on setting up the suspension. I am also thinking about trying to run the 63-72 front and rear cool ride setup with the trailing arms. The coolride front is the same for 63-87 so I could just use the older kit. More research to come.
Old 12-11-2009, 02:40 AM   #45
bluex
bluex's Avatar
Bump.
I'm intrested in doing this to my '78. I'm thinking the best way for me to do it will be with CPP's kit, without arms ($609) and use some stock 67-72 arms. This kit includes everything of the $1200 kit, without the arms. What I like about it is the upper spring mount is built into the c-notch plate and I wont have to worry about figuring out a mount.
Anyone know if there is a difference in arm length from a shortbed to a longbed. I'm going to call CPP and check that the kit will work with some stock arms and then start checking the local yards for them.
If I cant find any, then I'll go with Nates arms since they are cheaper, and have a drop built in.....
here is another article on the CPP kit.
http://www.classictrucks.com/tech/08...kit/index.html
Here is a cool video of the '79 in the article. Bottom screen, left side. Titled '79 C-10 Truck
http://www.classicperform.com/Videos/Videos.htm
bluex is offline   Reply With Quote
Old 12-11-2009, 09:54 AM   #46
SCOTI
SCOTI's Avatar
They are the same length.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-11-2009, 10:07 AM   #47
bluex
bluex's Avatar
Cool, that will make it easier to find them then.
I'm thinking with used arms I could get it done for under 1k?
I've also seen ECE sells a kit to strengthen the factory arms, would that be a worthwile investment?
Old 12-11-2009, 10:27 AM   #48
SCOTI
SCOTI's Avatar
Yes. Scrap steel would do the job too if budget is a factor. I simply put ~ 2" beads every 6" or so down the seam of the OE arms & weld up the extreme ends (front & rear).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-11-2009, 06:19 PM   #49
bluex
bluex's Avatar
Thanks Scoti, thats a great idea. Any pics?
From CPP about the kit:
Kit is designed for 63-72 arms and will work with a stock set of arms.
The truck in that video uses their modular brake kit with a 2" drop spindle
They also used a 2" drop spring up front for 4" total.
Their rear arms have no drop built into them
and the truck has 3" 63-72 drop coils in the rear, or can use any other drop or stock spring for those years.
Old 12-11-2009, 06:49 PM   #50
SCOTI
SCOTI's Avatar
I can get you some.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
