#226 |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
Re: [Project] "Fnlow69" PART II
Ok. Cool man.
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
#227 |
Wow you sure are jumping al the way in now aren't you? Looks good, like the dash! On the chop (I have never done one of our trucks) would it have been easier to cut out the headliner in one piece, set it aside. Then do the outer roof work so you could hammer and dolly the welds out and then replace the headliner in 1 piece and add fillers to the sides? Like I said I have not done one of these but on the others I have done I always like full access to the roof skin until I am finished welding it all off.
Kevin LFD Inc. |
#228 |
That is one sexy bracket.
Roof line looks great! It really forces you to look twice to figure out whats diff. about it. Just the right amount of chop. Thanks for the photos. |
#229 | |
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#230 |
thanks inverter, i like the front mount but the rear one im not to sure on? any input is welcome.
#231 |
Your welcome,
can you try and mimic the front ? The ears are just beautiful. |
#232 |
67GMC Slammed
wow what made you change it to a parallel 4 link?? looks killer
#233 |
thanks Ronm909, i just didnt like the old link setup. Wanted something simple and clean.
#234 |
Well got my panhard bar kit today so i got that installed and built the frame end mount. still have to gusset the back side like i did the front with the speed holed plate. also im changing the tube gusset to a plate with a speed hole in it. so it will flow better. anyways heres the pictures.
More this weekend and next week as im off tell next year. ![]() Pictures.... ![]() ![]() ![]() ![]() laidout ![]() ![]() speed holed gusset ![]() Justin
#235 |
hell ya man frame looks really nice, but i do have a ? why did you run a panhard bar as opposed to a watts link? just a ?..keep up the good work !
"Down to Earth" Last edited by little nick D; 12-23-2009 at 02:08 AM. |
#236 |
cause its simplier i guess, i never really thought about a watts link to tell you the truth. Also theres not much clearance between the diff housing and that rear crossmember. Plus with the canti/rocker arms theres already going to be a lot going on back there.
#237 |
thats cool man i was just wondering because i always see axels shift when the suspension travels with a trace bar like that.....ok thats just wat i ve seen an that just my opin....keep up the clean work
"Down to Earth" |
#238 |
Sheetmetal Psycho
When you weld the brackets to the axle, is there fluid inside?
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
#239 |
Justin, i have not checked in a while, and i just have a few things to say, the truck is looking amazing, greatly thought out dash, just amazing. Keep it up!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#240 | |
Thanks man
#241 |
Well on saturday i got the canti/rocker arms cut out with the plasma at my work and then i drilled the holes in them with a series of hole saws (not fun, lol) anyways today i got the holes all finished and got one tacked together. My hiem joints will be in tomorrow, so i should have them mocked into place tomorrrow.
Heres the pictures Pieces cut and drilled... ![]() and tacked together.... ![]() ![]() ![]() Justin
#242 |
o man the joys on hole sawing!!!!
"Down to Earth" |
#243 |
mig i dont have a tig yet, i really want to get one there just a little expensive
#244 |
Well i got the canti arms mounted today, now im just waiting on my heims to come in which is suppose to be tomorrow. im in the progress of figuring out a clean way to mount the bags. when the bags are in place and deflatted they will be flat and level.
Anyways heres the pictures. ![]() ![]() Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 12-29-2009 at 10:24 PM. |
#245 |
![]() Join Date: Mar 2004
Nice work. Keep at it.
#246 |
VA72C10
![]() Join Date: Mar 2008
Looking great...love the dash and canti setup
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#247 |
They look B/A!
Im surprised your attaching the axle end,inboard the frame.Wont that make for excess body roll? Last edited by Inverter; 12-29-2009 at 11:51 PM. |
#248 | |
Justin
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 12-30-2009 at 12:20 AM. |
#249 |
Theres no question it will work,I was just thinking you were going to run the arms parallel w/the axle tube w/the link bars reaching over the frame. I think 1badsvt has that kind of setup,,dont remember exactly.
Im not a suspension guru,by any stretch,I just know that its best to attach the load supporting links as far out as possible so the transfer of weight isnt accentuated as the vehicle turns.I almost sound like I know what Im saying ![]() Last edited by Inverter; 12-30-2009 at 12:19 PM. |
#250 |
ya that was the oringinal plan but theres not much room, i might try something else today but will see. Nates going to call me so ill wait to hear what he says.
