02-07-2010, 08:52 PM | #1 |
Dually 4x4 swap
Can i install the front axle without the stock crossmember getting in the way? and will a k30 crossmember work in my c30?
if i have to change it? why do i need to change the crossmember anyways. What get's in the way?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 Last edited by Matt Man; 02-07-2010 at 08:57 PM. |
02-07-2010, 09:53 PM | #2 |
Grease Monkey
Re: Dually 4x4 swap
If you are doing a 2wd to 4wd conversion you will need to remove the 2wd crossmember and put in a 4x4 crossmember. Then you will need to then weld on all the needed brackets for the springs. The crossmember itself is in the way of the axle. The 2wd CM is a lot deeper than a 4x4 CM.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
02-07-2010, 10:54 PM | #3 |
Re: Dually 4x4 swap
4wd crossmember will not go into a 2wd frame. I tried and it's too tall. IIRC it's only a 1/4" if that, but enough to make it not work. I would be done with my truck if it was a bolt in deal.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
02-07-2010, 11:59 PM | #4 |
Re: Dually 4x4 swap
But if a decent lift is involved, why would the 2wd cross member be in the way? Does it hang that low?
02-08-2010, 12:02 AM | #5 |
Re: Dually 4x4 swap
1/4"? wow
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
02-08-2010, 12:13 AM | #6 |
Re: Dually 4x4 swap
If you have access to a variety of metal you can make your own crossmember and use the 2wd mounts. I was gonna go this route, but dont' have easy access to the truck, nor a welder or a decent way to cutting any metal. I ended up getting a custom crossmember with mounts to put a Cummins in my truck. But it will also work for any gas engine, just the crossmember is bigger to clear the pan on the diesel.
02-08-2010, 12:24 AM | #7 | |
Re: Dually 4x4 swap
02-08-2010, 12:31 AM | #8 |
Re: Dually 4x4 swap
The crossmember between the two is totally different. I guess you could make it work, but I'd rather use something else than the 2wd crossmember. Thing is huge, and hangs down more than necessary. Also the crossmembers are the same between all the motors, my crew was originally a 454. Cummins oil pans are HUGE, and much longer than any GM motor, so a custom crossmember is used. I have it sitting right here, I'll get some pics tomorrow.....
02-08-2010, 12:41 AM | #9 |
Re: Dually 4x4 swap
cool thank you for the pics. So im planning on running a 6 inch lift would the 2wd crossmember still work since there will be more space than stock?
02-08-2010, 01:26 AM | #10 |
Re: Dually 4x4 swap
If its anything like a 72s crossmember, I would stay no. I have a 6in and it looked like it would hit if I hit a bump or flexed. But, this was a 72, Don't know how much the crossmembers and frames are.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 |
02-08-2010, 01:33 AM | #11 |
Re: Dually 4x4 swap
argh im in a tough spot right now. The problem is i can do all the work myself except the crossmember. i know i can have someone fab a custom crossmember but they need the truck in front of them to make me one. i dont want to get into it then figure out i need someone else to finish it.... dont have the money for that. i still dont understand why the k30 crossmember wont bolt in to my frame there the same i thought...
02-08-2010, 01:48 AM | #12 |
Re: Dually 4x4 swap
If its less an a 1/4 in, you could grind it down, a 1/8 inch on the top and bottom, may not be the best option, but could work. Not the whole thing just the sides. Then drill out and weld a piece of steel in to regain the lost strength, on the bottom of the top piece and the top of the bottom piece.
02-08-2010, 08:57 AM | #13 |
Re: Dually 4x4 swap
Something I was considering was a universal crossmember from Summit. They are less than $100, and have couple different ones to clear a small or large oil pan. Figure out where you want it, drill some holes or weld it.
Only thing I didn't like about them was you have to use their isolators.
02-08-2010, 09:51 AM | #14 |
Re: Dually 4x4 swap
The front suspension is all mounted to the massive C30 cross member. I looked at cutting up a 2wd front cross member to use under project Grasshopper. It is easier to use the diy4x cross member. Instead I took the clamshell mounts off the donor truck and plan to mount then to the frame and fab up the rest of the cross member. I have a 396 empty block. I will mount the transmission up to it and mock ti up with the new clamshell mounts and fab the new side mounts with that in place. Once that is done, I will remove the 396 block and install the complete short deck 427 and trans. Then I can fab the cross member to connect the 2 side mounts. The reason for doing it this way is I don't have another rear sump pan to put on the 396 block. It will be similar to the diy4x xmember, but will use the factory clamshell from the later trucks. Unless you have a heavy duty tubing bender and very good welding skills, this should be farmed out to a welding shop.
Sorry for the long winded answer. Diy4x is looking better all the time. Doug
68 CST 396, 60K original miles 70 Longhorn project 72 Stepside (150% complete) 67 Stepside project 71 RS Camaro 90% done 71 BB Corvette 50% complete 78 K5 project |
02-08-2010, 06:59 PM | #15 |
Re: Dually 4x4 swap
thanks for the replys everyone. i will go to a buddys shop of mine and see what he can do. He does custom stuff for nothing but big trucks. 1 ton+
