Old 03-02-2010, 10:26 PM   #1
Wild83C10
Wild83C10's Avatar
C4 Dropmember and Trailing Arm Conversion Install
So for the last 4 years I have been waiting for the right time to convert my leaf spring suspension to the the trailing arms. I finally got to it in the past few months. I used the CPP 73-87 conversion crossmember, original arms from an older C10 (welded seams), CPP adjustable track bar and some QA1 coilovers.
I have also been building up the parts for the C4 dropmemeber install over the last year + and I finally started the install in December. I upgraded to the C5 Z06 brake setup. I am also upgrading to all new hard lines and SS braided lines as well as the CPP MCPV-1 Master Cylinder.
The main intent of the C4 DM and trailing arm conversion wasn't to get the truck on the ground but for performance as that is my #1 goal.
Next up on the to do list is the CPP rear disc kit and an extra couple hundred horsepower from a Borg Warner Turbo
Check it out:
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-03-2010, 12:41 AM   #2
BIG KRIS
BIG KRIS's Avatar
Re: C4 Dropmember and Trailing Arm Conversion Install
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 03-03-2010, 01:01 AM   #3
JW76
JW76's Avatar
super nice job... i put off doing the trailing arms on my long bed til i can weld good enough to make my crossmember... nice to see a 73-87 with trailing arms... i had a talk with jeff at CPP the other day and he is talking to the engineer about designing a crossmember and kit that will work with a long bed. hopefully they will think it is worth it. again awesome job!
JW76 is offline   Reply With Quote
Old 03-03-2010, 02:41 AM   #4
bluex
bluex's Avatar
Would a stock 67-72 crossmember not work? I'm planning on running stock arms and crossmember on mine with the rest of the CPP kit.
Vette stuff looks killer!
bluex is offline   Reply With Quote
Old 03-03-2010, 02:44 AM   #5
nastyc10
nastyc10's Avatar
Nice job! It should perform great!
nastyc10 is offline   Reply With Quote
Old 03-03-2010, 08:03 AM   #6
Wild83C10
Wild83C10's Avatar
I don't think the 67-72 crossmember will work. You will have intereferance with the cab floor. I was working on my own crossmember using 2x6 tubing but it hit the floor. The CPP crossmember is S shaped for that reason. I would have had to mod the floor if I wanted to use my 2x6 crossmember. The CPP crossmember was a nice piece. The only thing I would have liked is the ability to adjust the trailing arms. The CPP piece was worth it, call up Jeff and he will hook you up.
turbo=
Old 03-03-2010, 01:40 PM   #7
SCOTI
SCOTI's Avatar
Bolt hole alignment of the CPP piece vs. an OE c.member where it bolts to the frame similar? You have PM.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-03-2010, 03:59 PM   #8
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good. What sway bar did you use for the front? What was required to do the C5 brake upgrade with the C4 suspension parts?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 03-03-2010, 07:35 PM   #9
DKN
Active Member
We have a different track bar mount that we use on the 73-87 trailing arm conversion to get the track bar up closer to the frame. Call Jeff and tell him what you need.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 03-03-2010, 07:45 PM   #10
SCOTI
SCOTI's Avatar
Danny Nix
CPP
The installed height he has it @ currently looks pretty level (which is optimum??). Wouldn't moving the frame side bracket up closer to the frame cause it to be out of that "parallel to the ground @ ride height" optimum range or do you offer different brackets for each end of the Panhard bar that are specific to the 73-87 conversion?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-03-2010, 07:46 PM   #11
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm really diggin the whole concept. However, the tabs for the rear coil overs don't look like much. Is there a way you can touchen up the upper and lower mounts?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 03-03-2010, 09:06 PM   #12
Wild83C10
Wild83C10's Avatar
Took some measurements, I can move the x-member back about 1.75" and forward maybe an inch. My install was about 1.5" forward of where CPP had placed their x-member on their '79 build. The rear cab mount and the cab floor are the two limiters. See pictures.
Kind of hard to see but the cab floor does go below the frame/x-member.
Here is the rear of the x-member and the rear cab mount.
turbo=
Old 03-03-2010, 09:10 PM   #13
Wild83C10
Wild83C10's Avatar
That is a stock C4 sway bar (24mm) with some energy suspension mounts. I plan to upgrade to at least a 1.25" later. I put together the end links from parts that I ordered from McMaster-Carr.
You can buy a C4-C5 adapter bracket and hardware. This will also allow you to bolt up the C6 brakes as well, which I will most likely upgrade to at some point if I end up taking it to a track once and a while. The C6 brakes are still a bit expensive though.
turbo=
Old 03-03-2010, 09:12 PM   #14
Wild83C10
Wild83C10's Avatar
Danny Nix
CPP
Does it move both sides up or just the one side that attaches to the frame? I made the bracket based on the ride height and it sits parallel right now.
turbo=
Old 03-03-2010, 09:16 PM   #15
DKN
Active Member
The track bar assembly for the 73-87 conversion mounts both ends of the track bar up higher. He used the 63-72 track bar mount under the axle, but you can see the frame side has a temporary lookng mount. The extended bracket off the frame shows how different the 60-72 frame is; the early frame would be down as low as the track bar without an extended bracket.
Danny Nix
CPP
Old 03-03-2010, 09:19 PM   #16
Wild83C10
Wild83C10's Avatar
If the rest of the rear suspension does it's job then there shouldn't be too much stress on the brackets. Just the vertical forces from the weight/g-forces under hard acceleration. The brackets are made for drag racing setups by QA1 and Comp. engineering. As long as the welds are good they should be fine. I may add a gusset from the upper bar to frame just because it's cantelivered a lot.
I plan on testing them plenty with my 650-700hp turbo motor which will eventually be 1000+hp turbo motor.
turbo=
Old 03-03-2010, 09:21 PM   #17
DKN
Active Member
Thumbs up Re: C4 Dropmember and Trailing Arm Conversion Install
The build is looking good. Nice Pictures too.
Danny Nix
CPP
Old 03-03-2010, 09:22 PM   #18
Wild83C10
Wild83C10's Avatar
Danny Nix
CPP
I had bought the track bar 4 years ago with the intentions of doing the conversion then, but it kind of slip a bit. I don't think you had the 73-87 conversion back then. I will have to check out the 73-87 track bar setup that you have.
turbo=
Old 03-03-2010, 10:46 PM   #19
tomtuna1978
i like how you put the rear coil over outside the frame on that tube you put threw the frame ! what wall thickness is that tube ? and od ? thats what i wanted to do on my 4x4(shocks only) 79 c10.
tomtuna1978 is offline   Reply With Quote
Old 03-03-2010, 11:49 PM   #20
SCOTI
SCOTI's Avatar
Danny Nix
CPP
Good info to know. Thanks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2010, 02:30 AM   #21
bluex
bluex's Avatar
Thanks for the Info. I'll cancel my search for the stock xmember and put that $$ towards the CPP kit. Its just taking me a while to save up my lunch money.
When you going to get that beast on the road? What was the reason you had to move it forward from CPP's location?
Old 03-04-2010, 07:17 AM   #22
Wild83C10
Wild83C10's Avatar
I am shooting for the end of March but not sure I will make it, but shouldn't take me much longer then that.
I placed the c-member based on the location of the rear. I measure the location when the leafs where on and made sure it was centered on the wheel wells.
Good luck with your conversion.
turbo=
Old 03-04-2010, 09:34 AM   #23
djracer
djracer's Avatar
Sweet lookin setup I'll have to watch this one.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-04-2010, 10:03 AM   #24
N2TRUX
Happy to be here
N2TRUX's Avatar
This thread will answer a lot of questions on this conversion. I see members ask about Dropmembers with coil overs. Your install should I show the feasabilty of the application.
I also see the questions about converting 73-87 to trailing arms. This is encouraging to those that are considering the conversion.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-04-2010, 11:09 AM   #25
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Danny Nix
CPP
Danny - I am planning on swapping my 85 to trailing arms also. I called a couple weeks ago, but don't remember who i talked to. I asked about buying just the 73 and up crossmember, but was told that only the 67-72 crossmember could be sold separately. True, or did I get bad info? I plan on fabbing my own crossmember, unless you guys would be willing to sell the 73 and up member as a separate item. Whatcha say?
Wild83C10 - Looks very nice! Could you post some info on the coil-over brackets on the rear end, link or part numbers please? Also, do you think a 67-72 crossmember could be modified to resolve the floor interference problems?
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
