#26 | |
Re: C4 Dropmember and Trailing Arm Conversion Install
#27 |
I'm curious about one concern.... The 67-72's have the drive shaft loop extended higher (above the top plane of the frame rail) for clearance. The CPP 73-87 conversion piece has the c.member loop flipped & it's on the bottom. The top portion of the c.member does not extend beyond the frame rail.
I know on my 68 w/the stock TA c.member, the d.shaft was pretty close @ the top (~8" drop). My 74 has the top of the axle tube within 1" of the bottom plane of the frame rail so it looks to be several inches lower than Wild83C10's truck. I'm wondering what kind of clearance there will be @ my ride height? What ride height is the CPP 'kit' meant to be set at (2/4 drop; 4/6 drop, etc...)?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-04-2010 at 11:56 AM. |
#28 |
Still plays with trucks
With a long bed the 67-72 crossmember might work. The crossmember stops just in front of the bed. It might tuck into the raised section of the cab right behind the seat.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#29 | ||
Scoti, Here is the info I got from them when I called about the kit they installed on their '79. I dont think it is as low as yours. I think you will use a shorter drop spring than your current drop amount since the arms go under the axle? (I have shackle/hangers now for a 4", but I might have to use a 2" spring to get the same ride height?) That is the only way that having a 4" drop up front and a 3" out back sounds right to me..
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#30 |
Tot Roddin'
Nice looking install!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#31 | |
Active Member
Danny Nix CPP |
#32 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-04-2010 at 05:50 PM. |
#33 |
The wall thickness looks like .120, the OD is 1-5/8.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
#34 | |
lower brackets: C2047 (Competition Engineering) Upper brackets: TB103GBK (QA1) Crossmember: 7387TAC-LDL (CPP) Adj track bar: 6572DTBK (CPP) Coilovers: DR3855B (QA1) Springs: 7-450 (QA1) Just about anything is possible as long as you have the skills and time to modify the x-member I'm sure you can get it to work. My opinion is that the CPP x-member was worth it.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 03-04-2010 at 07:13 PM. |
#35 | |
Because my 74 has the HD rear set-up, that 8-leaf spring pack rides like a swb 3/4 ton on rough roads. I want them out of the way so I can run truck arms w/bags just like my 68 was set-up (ride quality was muuuuuuch better).
#36 |
Heres a picture of a 67-72 chevy truck frame. The light blue line is the x-member location. The red lines are the 73-87 frame profile. Obviously the lines aren't exact but just to give you an idea of how the frames are different.
#37 | |
That is exactly why I want to do it as well. With the heavy half package on mine it rides like crap unloaded. Now put about a ton in the bed and it rides like a caddy.... I took it for a ride sunday and hit a dip in the road and almost hit my head on the roof when the rear went over it. It was never very smooth riding unloaded as a long bed, but when I converted it to short bed it got waaayyy worse..
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 03-04-2010 at 07:53 PM. |
#38 |
Yeah, we looked under the frame & I could see where the 'initial' kick-up is vs how the 67-72 frame is (I have a 68 swb frame sitting on my trailer). The CPP dropped center is still higher than the bottom lower plane of the frame rail.
#39 |
I'm just glad to be here!
I also looked at a LWB mid 80's truck. There is a kick up in the frame rail about 1/2 way between the front cab mount and the rear cab mount. after that it is straight until just past the front spring hanger where it kicks up again to go over the rearend housing.
Does the SWB frame have the same kick up under the cab? I do not have one handy for a visual inspection...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#40 |
![]() Join Date: Dec 2008
yes it does and the crossmember goes in where the kick up is on the shortbed. that is part of the issue why it wont work on the longbed because the longbed calls for a crossmember to be located on the straight part of the frame which is higher than in the kickup
#41 |
in addition, when the arms are located that high up on the longbed (the pivot point).... due to the shape of the frame, when you swing the arms they want to hit the frame so you don't have much suspension travel. HRH is building me a crossmember that solves this problem for my longbed and pefects the geometry.
#42 |
I saw HRH install on a 3/4 ton on their site. I did not like how the crossmember was that much below the frame rail. But, it doesn't hang below the lowest part of the frame and is braced correctly, then it really does'nt matter...
I am lucky, mine is a '65 and I don't have to worry about it....I already have the trailing arms..
#43 |
I talked to the Steve at HRH and he said that one is that low because of the ride height the guy desired. The one for my truck will be a little less low but still lower than just sticking a stock 67-72 between the rails. As I said it has to do with the arm clearance and Steve says it has to do with the geometry
#44 |
Any progress on this truck?
#45 |
Wow! great work! im loving that coil over set up! when i buy my C4 DM i want coil over set up! and that anti-sway bar is just awsome! i always wondered what the DM would use for an anti-sway bar!
Keep up the good work! but keep us posted too!!! ![]()
51 Chevy 3100 Deluxe Cab(SOLD) ![]() 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD ![]() |
#46 |
I have all the suspension together and I drove it some this summer/fall. Doing some additional work this winter.
I'm bad with pictures, but I will post some up. Can't see much of the suspension work behind the turbo stuff though.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 02-14-2011 at 07:05 PM. |
#47 |
Ok here's some completed for now suspension pictures. Next upgrades: larger front swaybar, rear sway bar, frame stiffening and then a roll cage.
#48 |
Man.... That's quite the package of parts you have pieced together. I imagine you have an ear to ear grin when you're behind the wheel.
#49 |
Yes I do. I waited all this time for the suspension upgrades but the turbo seems to give me the biggest grin. I really haven't spent the time tuning the suspension yet though.
#50 |
that looks great! I bet that turbo motor is just to much fun.
How much travel does the rear suspension have? It looks like only a couple of inches of compression. Posted via Mobile Device
