Old 08-02-2009, 02:43 PM   #1
RUSSOM
What year or generation C10 is the lightest?
I'm looking at buying a truck to build as a hot-rod and I want to make sure I'm not starting off with something heavy. I like the style of the 67-72 trucks the best, 73-87, would be next, fleet or step swb on any, and I've done a lot of searching for accurate info. on what years are the lightest and I haven't been able to come up with anything defenitive.
Does anyone know?
TIA
Robert.
RUSSOM is offline   Reply With Quote
Old 08-09-2009, 03:35 PM   #2
RUSSOM
Re: What years & bed configuration C10 is the lightest?
Ttt
Old 08-09-2009, 07:21 PM   #3
jay6891
Car Knocker
jay6891's Avatar
Re: What year or generation C10 is the lightest?
Cant speak for everyone else. but my truck seems to get lighter every time I slam the doors. But it leaves little rust colored flakes on the ground also.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 08-09-2009, 10:03 PM   #4
knsmodels
I make Models
knsmodels's Avatar
I dont think there is any significant difference in weight between the yrs..(67-72 that is)....lightest I would say SWB fleetside......good luck with your project....
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 08-10-2009, 01:40 PM   #5
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Red face Re: What year or generation C10 is the lightest?
I agree with knsmodels. You could always get a fiberglass front clip and gut out the interior.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 08-10-2009, 02:00 PM   #6
Ackattack
Ackattack's Avatar
I would think it more depends on the options than the year
such as power steering, power brakes, transmission, and of course driver
Ackattack is offline   Reply With Quote
Old 08-10-2009, 02:40 PM   #7
RUSSOM
I've now seen 2 sources with info. that is similar so I'm going to assume it is correct...although it doesn't make sense to me as to why a stepside would be lighter. I have to wonder where is the extra weight in a fleet? I wonder if the bed floor in a fleet is thick steel, or multiple layers of thick steel therefore being much heavier than the wood in a step, and if the floor was removed out of both, which one would actually be lighter? At this point I doubt anyone will have gone to this length, but who knows, a lot of people remove the bed flooring in these trucks and a lot of people race them so maybe the answer does exist.
Here's the info I have:
Official numbers from GM for '69 model
CS10704 -- (C10, 6 cyl, SWB, stepside) = 3447#
CS10904 -- (C10, 6 cyl, LWB, stepside) = 3536#
CE10704 -- (C10, 8 cyl, SWB, stepside) = 3570#
CE10904 -- (C10, 8 cyl, LWB, stepside) = 3643#
CS10734 -- (C10, 6 cyl, SWB, fleetside) = 3527#
CS10934 -- (C10, 6 cyl, LWB, fleetside) = 3631#
CE10734 -- (C10, 8 cyl, SWB, fleetside) = 3651#
CE10934 -- (C10, 8 cyl, LWB, fleetside) = 3743#
Per a 1977 issue of N.A.D.A Used Car Guide:-
1972 Ship Weight
C10 - Pickup Stepside 6/12' ..........................3560
" " FleetSide 6 1/2' ........................3630
" " Stepside 8' ..............................3640
“ “ Fleetside 8' ............................. 3720
C20 - " " Stepside 8' ..............................3940
" " Fleetside 8' ..............................4030
" " Longhorn 8 1/2' .........................3950
The ship weight
is defined as the shipping weight less fuel, coolant and lubricants.
weights per gallon ( lbs per gallon) fuel - 6; oil - 7; water 8.
1968 GM Restoration Guide Curb Weight No Rear Bumper heaviest entry, each class...
C10 SWB 3640 lb CE10734
C10 LWB 3745 lb CE10934
C20 LWB 4133 lb CE20934
C20 Longhorn 4195 lb CE21034
C30 Longhorn 4357 lb CE31034
Old 08-10-2009, 03:41 PM   #8
cdowns
cdowns's Avatar
stepsides are only one layer of metal fleetsides have inner and outer skins on the beds// tailgate alone is alot more weight on a fleet
racers who are smart and in the know go for fleets because of the important extra weight is put where it's needed over the rear wheels then they work on removing weight off the front wheels
Old 08-10-2009, 04:32 PM   #9
RUSSOM
Good info.
So with that being said, are you, and other racers of the opinion that maybe a LWB fleet would be even better, not just b/c of the extra wheelbase, but because of the extra weight as well?
Old 08-10-2009, 05:04 PM   #10
'72customdeluxe
Another good thing about the 67-72's compared to a 73-87 or such is the trailing arms. They are a good drag suspension when setup right. Better than leaf springs
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 08-10-2009, 05:49 PM   #11
mclairmo
You need weight over the rear or forget about hooking up. The more weight over the rear, the better. You don't have to go for a long bed just for that reason. You can always add ballast to the rear, move the battery to the rear, move the gas tank to the rear, etc.
mclairmo is offline   Reply With Quote
Old 08-10-2009, 06:01 PM   #12
sick69
sick69's Avatar
Not to mention the extra space the fleet gives you to move more weight over or behind the axle. Stuff like the fuel tank and battery. Also alot less cutting to put more rubber back there. Doing a mini tub will allow a 16.5"(right at 13" or tread on the ground) wide tire just by cutting the floor to the frame and widening the wheel wells.
The trailing arm suspension is not much different than an aftermarket ladder bar suspension,just alot longer, that guys pay alot of money to put in. Although if your putting massive power down you may need to reinforce them.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 08-12-2009, 09:24 PM   #13
Trucks weights are all very close.It`s all about horsepower with trucks.If you want light,go with a smaller vehicle.
Old 08-12-2009, 09:53 PM   #14
70k52wd
Blaze-Air
70k52wd's Avatar
I don't race, but I was thinking air flow over the fleet may be better. Maybe use a 67-68.
70k52wd is offline   Reply With Quote
Old 04-12-2010, 01:52 PM   #15
1968CHEVYC10
1968CHEVYC10's Avatar
those numbers sound pretty good, my '68 350 lwb fleetside weighs 3700lbs
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 04-12-2010, 05:50 PM   #16
Fitz
Does anyone know?
TIA
Robert.
If the '69 numbers above are correct the 67 C-10 is the lightest
Model Body Body Type Price Weight Total Production
1/2 Ton - Model C - Series 10 - 115 in wheelbase
CS10703 - Chassis & Cab $2,223 2,914 lbs 2,790
CS10734 - Fleetside 6.5 ft. $2,371 3,333 lbs 43,940
CS10704 - Step-Side 6.5 ft. $2,333 3,255 lbs 45,606
1/2 Ton - Model C - Series 10 - 127 in wheelbase
CS10903 - Chassis & Cab - - 39
CS10934 - Fleetside 8 ft. $2,408 3,440 lbs 165,973
CS10904 - Step-Side 8 ft. $2,371 3,345 lbs 19,969
CS10905 - Panel $2,742 3,502 lbs 3,827
CS10906 - Suburban $2,986 3,670 lbs 5,164
Fitz is offline   Reply With Quote
Old 04-12-2010, 08:59 PM   #17
BOZO
Old School
BOZO's Avatar
Something else to think about if you are gonna build from the ground up, the 3/4 ton frame is .050 thicker than the 1/2 ton frame. The 3/4 ton frame could be used to back half your truck. It is stronger and the weight is where you need it.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
Old 04-12-2010, 09:22 PM   #18
'72customdeluxe
yep, I believe a 3/4 ton has more braces aswell. If you're lucky you could get one with a dana 60, perfect. Just swap out to 5-lug aftermarket axles
c10, curb, hot-rod, swb, weight
