Old 05-28-2010, 05:23 PM   #1
sweet70beast
sweet70beast's Avatar
I noticed something yesterday
I was out doing some welding on my Panel yesterday and noticed some more small differences that could help narrow down the "What year do I have?" questions.
My panel is missing the ribbed H pattern above the steering column on the fire wall where as both my 50 3100 and 54 Suburban has it.
Here is the 50
[IMG][/IMG]
Here is the 48 Panel
[IMG][/IMG]
Also the sway bars are different
The 48
[IMG][/IMG]
[IMG][/IMG]
The 50
[IMG][/IMG]
[IMG][/IMG]
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 05-28-2010, 06:46 PM   #2
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Re: I noticed something yesterday
It may actually be a '47. The absence of stiffening in the firewall and the presence of the multi-fuse fuse box are both '47 things. I usually look next at the transmission but you don't appear to have one so that's out.
The torque tube length is unique on a '47 if it still has the tube you might measure and compare the length to your later truck.
I have a '47 AD COE waiting for someday. Its cool to have a unique truck.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 05-28-2010, 07:46 PM   #3
mr48chev
mr48chev's Avatar
Yep, having or lacking those ribs is one of the identifying signs of what year the cab actually is.
The break must be between 49 and 50 as I have a 49 cab with the flat firewall and a 51 and a 53 cab with the ribs.
The 49
The 53
Old 05-28-2010, 11:23 PM   #4
BlueJeep
BlueJeep's Avatar
My 49 doesn't have the ribs.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 05-29-2010, 12:46 AM   #5
Steve@OldSub.com
Mr48 that cab you call a '49 appears to have the multi-fuse fuse panel that I've never seen on a truck later than '47. I don't know with certainty that it couldn't be a '49 but it makes me wonder.
Steve@OldSub.com
Old 05-29-2010, 11:39 AM   #6
sweet70beast
I never really knew what year the panel was because the vin number crosses to a 48 3/4 ton which is obvously not the right vin. I new it was a pre-49 because of the knee action shocks. Unfortunately the torque tube and axle are gone.
Does anyone know if the sway bar style is 47 only or did they use them up to 49?
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 05-29-2010, 01:03 PM   #7
T Hilde
First one I have seen with a sway bar.
T Hilde is offline   Reply With Quote
Old 05-29-2010, 03:21 PM   #8
Steve@OldSub.com
I know I've seen the answer to this but with a little searching I've not been able to recall where.
There is some logic to '47 only but just because it makes sense doesn't mean that's the way they did it.
There is also a school of thought that says each factory used up the old parts instead of making a clean change-over on some date. Don't know if that's accurate either, but it does muddy the waters a little. Having been born after the last of these trucks left the factory does mean I didn't see any of them being built...
In researching the sway bar be aware that GMC used a similar but different bar. The mounts are different and they do not easily interchange. In fact it may be a GMC sway bar discussion that I'm remembering that explained the change-over from early to late. If that is the case it was probably on OldGMCTrucks.com and might be found by searching there. Of course then the information may be different than for a Chevy....
Steve@OldSub.com
Old 05-29-2010, 03:30 PM   #9
Steve@OldSub.com
Well looking for something else I just stumbled on an Internet page that says the large fuse block was used through '49. I don't believe everything I read on the Internet but in this case it may be that my own experience does not match what GM was doing...
Steve@OldSub.com
Old 05-29-2010, 06:14 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
I have a 49 with a large fuse block aqnd a 50 with a small block. 49 should have lever shocks
