So im in the middle of planning a rebuild on my 454 for my 1978 GMC C25 and am at a crossroads on weather to keep it carborated and add a edelbrock RPM airgap or switch over to efi with an edelbrock kit im working with a 1980's 2bolt main block and stock heads but plan to upgrade heads at a later date
been here longer than Liz
Re: EFI or CARB
Efi ftw
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
Truck and auto performance nut
Re: EFI or CARB
for a driver where mileage and a solid running motor w/o hiccups is more important then power....efi.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: EFI or CARB
+1 except depending on the carb and efi setup the power could be more with either one.
1999 Tahoe LT 4dr 1971 Torino 4dr 1954 GMC 100 5 window - Project |
Getting Old; Going Broke
Re: EFI or CARB
EFI and never look back.
Re: EFI or CARB
well most tests show more "peak" power with a carb up high... and in many cases down low...where as the efi is better in the midrange, where a street engine lives.
Re: EFI or CARB
EFI - it will take a bit of planing and work, but you will never look back.
//RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Garage wrench
Re: EFI or CARB
True, and well worth the time!
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
Re: EFI or CARB
The Edelbrock TBI - to - MPFI kit seems to work fairly well, but isn't very tolerant of big cams and heads (sort of like stock TBI). Haven't heard much about the Holley Pro-jection kits.
Megasquirt is more work up front, but is more tuneable, and being Windows - based, is a lot more user-friendly for most. |
Re: EFI or CARB
It depends on what you want to do with the truck.
EFI can work great - IF it's tuned correctly. Same can be said for a carb. Check out the price difference with tuning time included, then decide if it's worth it. How much the truck will be driven would determine it for me. |
Next project: 1970 K10
Re: EFI or CARB
Efi!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
Another Day, Another Dollar
Re: EFI or CARB
cARB!
BRAAAAP
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
#13 | ||
Conversion Truck Addicted
Re: EFI or CARB
i personaly love carbs but i dont mind EFI on a DD but again its down to if you have the money and dont care the price or if you want to save alot of $$$ in the years to come its a personal couise i think i have heard a EFI 454 only goes 15MPG tops on highway and maby 8-10 in town idk what a Carb does
Thomas Quote:
On a budget like Fred Sanford
Re: EFI or CARB
Coming from a guy who owns and tunes both:
If you're going to keep it relatively stock and/or plan all of the engine modifications at one time, then I'd go EFI. If you're going for a little more wild combo and/or plan to add modifications to the motor slowly over time as budget allows, then I'd go carb. Obviously carb will be significantly less costly. Every single change you make to an EFI motor requires changes in the tune. If you've got the software/knowledge to do this yourself then it's no big deal, but many people do not. Almost everybody can change jets in a carb and twist a distributor. ![]() There's new "self tuning" EFI solutions on the market now, although I have no direct experience with those so I can't do more than speculate.......I do have extensive late-model EFI experience, and a simple MAF based system with wideband o2 feedback *should* work just fine without much user input on mild-ish motors. But you gotta pay to play!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
#15 |
Re: EFI or CARB
here are some links.
cant go wrong here. im going with stock efi once i have to replace my motor (w/stock 350) http://www.affordable-fuel-injection.com/ Im hearing positive stuff from fast EZ-EFI® from FAST™ http://www.fuelairspark.com/ezefi/default.asp |
#16 |
Parts and more parts
Re: EFI or CARB
I have been considering the EZ EFI for my 383 stroker setup. I am just considering what would be the best way to connect the tanks with the fuel pump. I get 15 MPG with the carb, but the EFI should make that more efficient, not to mention a larger power band capability.
Frank |
#17 | |
Re: EFI or CARB
You mean MAP (Speed density) used on in early EFI systems. MAF sensors can temperamental and GM had hard time keeping early TPI cars running well. They ditched MAF sensor and switched to MAP (in F-Body) until MAF sensor technology matured to be robust enough. A stock BBC TB, with dynamic fuel pressure modification (VAFPR) and optimized ECM (EBL) tuning can provide enough air flow (about 640 CFM) and fuel (a pair of 80 or 90 lb-Hr injectors at 20+ PSI) to support up to about 360 to 370 HP. The problem with most stock BBC is that these engines were choked with tiny cams, puny heads and restricted exhaust systems from the factory. Like previous posters have stated - there is a learning curve associated with EFI tuning. But there is also a real world performance win since ECM tuning allows greater flexibility under a wide range of conditions. Also, camshaft and head selection is critical and careful consideration to an engine - drive line combination should be given before starting this project. It all depends what you plan do with your rig..... //RF
#18 |
Re: EFI or CARB
I just got my first EFI square, and it's EFI all the way for me.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
