07-20-2010, 10:03 PM | #126 |
Re: Mcgaughys Big Brake Kit
I didn't have any problems with the rear, it's just a bit labor intensive and requires a little machine work on the axles. For the price... A+.
07-20-2010, 11:34 PM | #127 |
anyone whos ever purchased a kit from me ive offered to turn there axles
griffman or steve one of the first guys to post on this thread bought his kit from me i turned his axles free of charge i offer it to anyone who wants to ship there axles to me and back. |
07-21-2010, 02:34 AM | #128 |
Wow, you are a good dude
07-21-2010, 10:56 AM | #129 | |
Active Member
Danny Nix CPP |
07-21-2010, 11:24 AM | #130 | |
X2!!! For the money you cant beat it. Nate Porter said it was "the best bang for your buck" when I picked the brakes up from his shop. I'd have to agree |
07-21-2010, 04:28 PM | #131 | |
Ed |
07-24-2010, 07:16 PM | #132 |
I finally got the front kit installed along with the rest of the new suspension and steering parts. I was hoping to finalize the install today, but ran into a small issue with the new corvette style m/c & p/v from CPP; the m/c uses a longer pushrod than the stock m/c and it didn't come with it...kinda disappointing, but hopefully I will be able to find one next week...Any suggestions on the application?
Here's a couple of pics of it sittin', can't move it yet I also included a shot of the Blazer prior to the new suspension just to give you an idea of the difference of before & after |
07-30-2010, 07:57 PM | #133 |
Did you ever find out what the deal is on this. Buying some DJM dropped spindles now and want to upgrade to bigger brakes later
Long live SLIM ------------------ At least try to buy American |
07-30-2010, 09:36 PM | #134 |
BMW & ASE Master Certified
McGaughys kits have the back of the spindle specially modified to accept a caliper adapter bracket. You could use any spindle, have it custom machined and have a custom caliper bracket made but McGaughys already has something put together.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
07-31-2010, 09:36 PM | #135 |
Welp, mine are on and moving and stopping. The pedal pressure isn't what I was hoping for, but I may have a small line leak that I couldn't find while crawling around in the dirt. I'll be taking it to a friends shop to double check everything on the lift...with a concrete floor under it .
07-31-2010, 10:10 PM | #136 |
[QUOTE=nlped;4116651]Welp, mine are on and moving and stopping. The pedal pressure isn't what I was hoping for, but I may have a small line leak that I couldn't find while crawling around in the dirt. I'll be taking it to a friends shop to double check everything on the lift...with a concrete floor under it .
Looks great! I ended up going with another setup for the front. What are you using for a prop valve? |
07-31-2010, 10:34 PM | #137 |
hey c10seconds... what did you do for a front setup... just curious
07-31-2010, 11:09 PM | #139 |
Happy to be here
Danny- I would support this 100% if CPP offered a 13" kit for the rear. Your front kit is very well engineered at an affordable price. We just want a rear kit to match.
07-31-2010, 11:16 PM | #140 |
^^^Exactly why I ended up with the stuff from McGaughy. I wanted the CPP stuff too, but couldn't get a matching rear. I bought the CPP kit at a swap meet, but ended up selling it to get the McGaughy stuff. I made good money on it
08-01-2010, 09:39 PM | #141 |
08-01-2010, 10:16 PM | #142 |
Well, I finally went to the boneyard and picked up a spare rear end. I even lucked out and got a 12 bolt. Anywhoo, Ive got the template laid out for the corvette calipers but I need to buy a set of calipers, or even 1 side. Anywhoo, the brackets wil be simple and cheap to sell once produced, but to get the ebrake.. the parts alone will cost about 250ish
I remember seeing a baer kit on a c-10... that was retarded looking. a 12" rotor with about (guessing) 2" of usuable rotor matched up to the old lt1 style ebrake bulit in caliper. Serioulsy looked like it was using 50% of the rotor. Atleast what I am working towards is a matching kit for the rears using real rear parts so ebrake could be an option. Anyway, Once I score a set or one side of corvette calipers I will start a seperate thread. Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 08-02-2010 at 04:12 PM. |
08-02-2010, 03:17 PM | #143 |
I'm just glad to be here!
I found an older (within the last year or so) issue of Custom Classic Trucks yesterday in it they did an install of a CPP kit for the front and rear that used Willwood calipers, and it had a e-brake for the rear. I believe that the fronts were 6 piston, 14" rotor and the rears were 4 piston, 13" rotors. The e-brake was inside the "hat" of the rear rotor kinda like a small drum brake. It was installed on a '79 I think...I will post the issue date/number after I get home.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
08-02-2010, 04:41 PM | #144 | |
clint
08-02-2010, 06:12 PM | #145 |
I looked into those...but not for long. The front kit is MUCHO expensive...in the neighborhood of $2k+, and the rear is only 12.19" in diameter and $650-$850 depending on options. The front price doesn't include the spindle either. One more reason why I went with this McGaughy kit. I spend less than $1200 for everything shipped to my door, and other than just machining the rear axles, it was a very straightforward install. I would certainly like to have "cooler" looking calipers, but for the money...It can't be beat!
Just my .02 |
08-02-2010, 09:19 PM | #146 |
didnt want to make another thread about front brakes, but dang, this is a huge brake setup for our trucks
does the McGaughys drop spindle look like this (back side) and thickness.... Im sure my stock McGaughys spindles wernt this thick in the area between the bolt holes.. maybe they were... if so, dang, I want to buy a set can anyone chime in that has bought the McGaughys front spindle brake kit? thanks Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 08-02-2010 at 09:26 PM. |
08-02-2010, 10:57 PM | #147 |
Happy to be here
aggie91 I have looked hard at Wilwood as well as all the other name brands. Even Baer makes a good looking reasonable priced rear kit. Unfortunately the matching front kit gets really pricey on all of them.
The CPP kit is a real bargain compared to the other brands. If they were to make a matching 13" rear, I would go that way. Since they don't (yet), I am leaning toward the McGaughys combo.
08-02-2010, 11:04 PM | #148 |
Anyone know a machine shop in Houston that could mill down axles, I will be searching yellow pages here shortly, but word of mouth is better IMO.
clint
08-02-2010, 11:53 PM | #149 | |
Do you happen to know which spindles are being used in the pics? Last edited by c10seconds; 08-02-2010 at 11:56 PM. |
08-03-2010, 12:59 AM | #150 |
Those are the 16" brakes that KP (Chris Alston's Chassisworks) offers... can you say $4Gs for front only. We will be doing a build starting in a month or so that's getting these bad boys.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
