Old 11-21-2010, 04:31 PM   #151
mooseknuckles
mooseknuckles's Avatar
Re: My 86 build
yeah, the salt trucks have been out here too... I've been washing my truck alot. hope to park it soon as I get new wheels....
mooseknuckles is offline   Reply With Quote
Old 11-30-2010, 01:36 AM   #152
Dudewith4x4
Momma Tried.
Dudewith4x4's Avatar
Re: My 86 build
How hard all in all was the dash? Would you recomend it?
Ross
1980 c10 4x4 project (Sold):http://67-72chevytrucks.com/vboard/s...d.php?t=377155
1999 F-150 4x4 (DD)
Saving up for a 64
17 and loving it.
Dudewith4x4 is offline   Reply With Quote
Old 11-30-2010, 01:32 PM   #153
mooseknuckles
Re: My 86 build
Wasn't hard at all...If you want a sweet looking custom dash for cheap, then I definitely recommend it. But if you don't like to do bodywork and block sanding you wont like it! The more time and effort that you put into it the better it will turn out. I have about 5-6 hours in mine and it looks one-hundred times better than it did or better than any replacement would, and its not even painted yet!
Old 12-07-2010, 04:23 PM   #154
mooseknuckles
Re: My 86 build
I parked my chevy for the winter....I'm gonna miss driving it, but I'm not gonna miss the cold-starts and fill-ups!
Old 12-07-2010, 06:20 PM   #155
motornut
78K & 79C Jimmys
motornut's Avatar
Re: My 86 build
yup stopped driving mine too
it's like winter snuck in this year
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 12-08-2010, 10:48 PM   #156
maxxxy
maxxxy's Avatar
Re: My 86 build
You have a really nice truck. Do you have any pictures or info on how you made your roll pan?
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 12-11-2010, 04:36 PM   #157
mooseknuckles
Re: My 86 build
I did have pics but my pos computer crashed! .......I had a piece of sheet metal left over from my shaved tailgate mod and cut it to length, bent a 90 in it on the work bench, then bent a few curves in it over a length of pipe to get the same shape. I welded it on and made a box for the licence plate and cut it in and welded it. It's not perfect but it was practically free!
Old 12-17-2010, 08:37 PM   #158
mooseknuckles
Re: My 86 build
Had some money saved up, then my PC died.... now that I'm starting to get out of the red again, I've been lookin at a few things....
Old 12-17-2010, 09:01 PM   #159
mooseknuckles
Re: My 86 build
only pics I have of the roll pan....
Old 12-17-2010, 09:54 PM   #160
notrailerqueens
notrailerqueens's Avatar
Re: My 86 build
got a question for you, ok a couple.
when you did your drop b4 your front bags, did you do a notch in the back or no? and if not does she bottom out bad? did you use a flip kit or just make your own? and also when u did your flip did you relocate your shock mounts or just go to the front shocks? how bout clearance in the front with ur 3inch drop spindles? did you have any probs after cuttin your coils? did you have "chevy lean" b4 your drop?
sorry i know i just asked you like a million questions. im tryin to figure this drop thing out and you have like my ideal stance so i figured id bug yah. thanks SO much in advance! and if youd already awnsered these ?'s in a previous post and i missed it when i read through sorry.
Lindsey Rae
85' chevy long box, built by a girl!
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=429956
notrailerqueens is offline   Reply With Quote
Old 12-17-2010, 11:21 PM   #161
mooseknuckles
Re: My 86 build
No prob......I made my own flip in the back by cutting the perches off and welding them on the bottom of the axle. I never notched it then, but I took the bumpstops off, The axle never hit the frame at all unless I had something in the back. Later when I lowered the back end more by moving the spring hangers, I made a c-notch out of some 6" tubing cut in half and plated the sides. Then I had to change shocks cause the ones I had on were bottoming out. Still same shock mounts but with a set of front shocks. The front wheels would rub on the inner fenders if I hit a good bump so I took them out. The coils were ok after I cut them, but I wanted it lower so I bought bags and made some mounts. It has a bit of a lean from one side to the other maybe 1/2" or more... right now its dropped 9" in the back and about 7" in the front and hardly ever scrapes the ground.
Old 12-17-2010, 11:28 PM   #162
notrailerqueens
Re: My 86 build
like your current pics are a 7/9? oh wow ok maybe i do wanna go lower than i thought
your flip gave you like 6 right? when you moved spring hangers did you do like a drop spring or what? how big was your notch? and your still static in the rear right?
Lindsey Rae
Old 12-17-2010, 11:39 PM   #163
mooseknuckles
Re: My 86 build
yeah its pretty low, lower than most cars.
still static in the rear for now, I cant really go any lower without a bigger notch, no drop spring, but I did take a few leafs out to soften up the ride. the notch is 3", if I didn't have it the axle would be right on the frame!
Old 12-18-2010, 12:12 AM   #164
notrailerqueens
Re: My 86 build
wow well i have mad admiration for you now! a 7/9 is crazy! especially static in the rear. it looks amazing though! and now you really got me thinkin that i should slam mine. lol which is impressive because untill about 6 mnths ago i never wanted a droped truck.
Lindsey Rae
Old 12-18-2010, 12:17 AM   #165
notrailerqueens
Re: My 86 build
oh one more thing. if you got one id love to see a pic with somebody standing next to her. just to get the full effect. total bummer that we live you know like at oposite ends of the continent cuz id love to see her in person
Lindsey Rae
Old 12-18-2010, 12:19 AM   #166
mooseknuckles
Re: My 86 build
thanks...
slam it now, you'll only want to later!
Old 12-18-2010, 12:21 AM   #167
mooseknuckles
Re: My 86 build
I'll see what I can do!
Old 12-18-2010, 12:22 AM   #168
notrailerqueens
Re: My 86 build
thanks!
Lindsey Rae
Old 12-18-2010, 03:14 PM   #169
mooseknuckles
Re: My 86 build
I picked these bad boys up this afternoon, hopefully get at that today or tomorrow. The fenders look like they will fit perfectly if I can mount them up high enough, without hitting the hood hinge..
Old 12-18-2010, 04:34 PM   #170
maxxxy
maxxxy's Avatar
Re: My 86 build
Cool! Those fenders will look sweet
Max
Max's bagged 81
Old 12-18-2010, 06:31 PM   #171
mooseknuckles
Re: My 86 build
Thinking of getting a 4 link set up like this or something similar. This one is from Extensive.
Old 12-20-2010, 11:25 PM   #172
mooseknuckles
Re: My 86 build
or this one....from suicide doors
Old 12-20-2010, 11:39 PM   #173
nbpro
Re: My 86 build
the one from suicide doors looks bada$$
nbpro is offline   Reply With Quote
Old 12-20-2010, 11:45 PM   #174
mooseknuckles
Re: My 86 build
Yeah........I'm just trying to find a little more info on it.
Old 12-21-2010, 01:13 AM   #175
SS Delux
SS Delux's Avatar
Re: My 86 build
what about a trailing arm setup from cpp or porterbuilt ? you can run wider tires
SS Delux is offline   Reply With Quote
